08-15-2005, 03:16 AM | #1 |
Member#: 78658
Vehicle:2005 LGT Limited Black/Black |
question on my hybrid plans
so far the setup is EJ22T block mated to 2.5RS (sohc) heads, e-manage for now. My question concernes which headers/up pipe/down pipe combo I can use. will the stock EJ22T exhaust plumbing and turbo work or will there be clearance issues? what about the stock exhaust setup from a wrx.
08-15-2005, 10:28 PM | #2 |
Member#: 16847
Vehicle:2000 impreza rs 2.5 mach I maroon |
You are currently running this setup or are still building? Love to see EJ series hybrids, so many people cop out and throw down big cash for STI swaps, lots of good power options with non sti EJ series blocks and heads.
As far as the exhaust goes what car is this setup in? If your using Legacy cross member or wrx you should be fine with stock EJ22t plumbing, I'd suggest gutting what you can to gain some HP. |
08-16-2005, 04:57 AM | #3 | |
Member#: 78658
08-16-2005, 09:15 AM | #4 |
Member#: 16847
WRX or legacy exhaust manifold should be fine with your WRX cross member keep me posted, I am building now also, not sure what heads I wanna use, the RS heads flow more than the legacy and WRX, but you loose compression, which can be regained with head gaskets, although this may be a good thing low Compression = High Boost capabilities,
08-17-2005, 03:06 AM | #5 | |
Member#: 78658
08-17-2005, 12:18 PM | #6 |
Visiting NASIOC Timeout
Member#: 9093
Vehicle:1995 RHD STi RA Ver2 swap starr |
if you need piping for a 99 RS SOHC heads + turbo, i have a friend who's got a kit off a 2000 for sale. pm me if you want his info-
the SOHC heads will NOT fit up the EJ20 wrx turbo exhaust manifold from what i recall. ask matt monson, he knows this stuff |
Question on a Hybrid STI Head setup with STI 2.5L block running with WRX ECU. | TRDRacer | Built Motor Discussion | 24 | 01-14-2010 02:03 PM |
Questions about my hybrid | Dpsneeka | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 10-15-2009 03:29 PM |
A couple quick questions on my hybrid RS-T build | silentt | Normally Aspirated with bolt-on Forced Induction Powertrain | 5 | 06-23-2007 10:34 PM |
few questions on my hybrid build... | NicFunkadelic | Normally Aspirated with bolt-on Forced Induction Powertrain | 25 | 02-16-2007 04:57 PM |
question on my suspension plan.. | RChampion | Brakes, Steering & Suspension | 0 | 05-31-2003 01:59 AM |
