Old 06-11-2012, 07:42 AM   #1
Jawnzard
Member#: 306471
1998 Impreza
Default Need Help Deciding On Internals
So I know the title would make you think this doesn't belong in this forum, but hear me out. I have an engine (factory NA) that I'm building and I'd like to run forced induction. I've done my homework on swapping internals around between engines but I can't decide which pistons to use. One of the options is the pistons of an EJ22E and the resulting compression ratio will be around 8.5:1. So my question is this: with a low compression ratio like that, could the stock EJ22E cast pistons withstand 15psi of intercooled boost? Assume I'm going to be getting a tune as well.
The other option is EJ22T pistons but those will drop the compression ratio down to 7.3:1 and I'm worried that might be too sluggish off-boost.
Any thoughts?
Jawnzard is offline   Reply With Quote
Old 06-11-2012, 09:39 AM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
You "could" use the stock 22E pistons for 15 psi. intercooled, since many others have done it before you. But I just don't trust it, but that's me, other people would run that without a second thought. On the other hand, the EJ22E is so plentiful and cheap, you could almost go through 2-3 engines before you approach the cost of forged pistons.
The easiest way for you to lower your CR for boost is EJ25 heads. If your impreza has throttle body IAC, then use sohc EJ25 heads. If not, use EJ25D heads. That won't get you around the cast piston issue, but it should be fine for good DD power levels.
If you swap in EJ22T pistons, you get the same CR as the 22T, 8.0:1
~Josh~
ballitch is offline   Reply With Quote
Old 06-11-2012, 09:47 AM   #3
Jawnzard
Member#: 306471
1998 Impreza
~Josh~
I should have prefaced my questions by saying this is actually for an H6, so the compression ratios are a bit different than the 4-bangers. Thank you for the input Josh, I apologize for forgetting to give you one of the most important pieces of information.
Old 06-12-2012, 09:38 AM   #4
ballitch
Member#: 74907
98 cam'd EJ251
I don't know the piston dish of the EG33 pistons, or the chamber volume.........or the stroke.....
I guess i'll have to enlighten myself. I guess you could use any EJ22 piston as long as it has more dish. Since you stated that the EJ22E piston will drop you to 8.5:1, I say go with that. Other than that, forged aftermarket is going to be your best bet, but also more expensive.
~Josh~
Old 06-12-2012, 09:44 AM   #5
Jawnzard
Member#: 306471
1998 Impreza
~Josh~
I have a complete EG33 dismantled in my garage. I used brake fluid and a graduated pipet to measure combustion chamber volume, I had a machine shop measure piston protrusion, and I know bore/stroke, and gasket thickness. Using all that, I got a rough estimate of piston dish.
Anyway, long story short, my compression ratio numbers are more or less correct, assuming the piston dish info I got online for the EJ22E/T engines were correct.
Also, if anyone wants some cheap high-compression EJ22 pistons, the EG33 pistons should raise your compression ratio up between 11.5 and 12
Old 06-12-2012, 08:33 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
EJ22T piston dish is 28cc's, EJ22E is 12cc's. Unless the EG33's dish is 0, I don't know how much they would raise the EJ22's CR.
Spill the beans, I want to know what the stroke is , I know the bore is pretty much the same as the EJ22E.
~Josh~
Old 06-12-2012, 08:59 PM   #7
Jawnzard
Member#: 306471
1998 Impreza
~Josh~
According to my research, the EJ22E (2.2L 1996 and earlier) has 14cc of piston dish and EJ22EZ (2.2L 1997 and later) has 12cc of piston dish. I can't personally confirm this, but I spent months collecting data from every source I could find and a couple sites confirmed the slight differences in the 2.2L engines. I compiled it all on my local club's site here.
I calculated the EG33 piston dish to be about 8cc. I just ran it through a compression calculator and it would raise your EJ22E compression ratio up to 11.8 unless I was wrong about the piston protrusion on the 2.2's.
Last edited by Jawnzard; 06-12-2012 at 09:11 PM. Reason: Edit for EG33 piston dish
Old 06-17-2012, 08:24 PM   #8
thorne
Member#: 130063
2003 WRX
Silb
I built a 205+22e setup that lasted for a descent amount of time at 365+awhp(18g) being beat on.
I ran 26psi on a stock bo (spiked it and let it fall) 315tq 265awhp I was not nice i'd wager she would have held together had i kept her at 300.
thorne is offline   Reply With Quote
Old 06-19-2012, 08:26 AM   #9
Jawnzard
Member#: 306471
1998 Impreza
What other supporting/protective mods did you have? ECU tune, alcohol injection, intercooler, anything else? If I could get by with the 22E pistons with just an intercooler and a tune, that'd be perfect.
Old 06-19-2012, 10:54 AM   #10
geronimo81
Member#: 154586
1996 ej22 Outback
I think 15psi on 22e pistons at that comp ratio will be fine. An EG33 at 15psi would be an absolute blast!
geronimo81 is offline   Reply With Quote
Old 06-19-2012, 10:57 AM   #11
Jawnzard
Member#: 306471
1998 Impreza
That's what I'm hoping Eventually, I'd like to pull the engine again, have it bored out to 99.5mm, sleeved, then run stock STi pistons in it. It'd be a 3.5L beast. So right now it's kind of "stage 1" of the build. If it goes pop, it won't matter too much as all of my parts have not amounted to more than $350 so far. I will eventually post a build thread for others interested in following this route.
Need Help Deciding on Lowering Springs on 2002 Wagon.. NEED PICS! Cain0023 Member's Car Gallery 22 03-03-2010 05:12 PM
need help deciding on wheel color theWeRX Interior & Exterior Modification 1 06-05-2002 10:27 PM
Need help deciding on wheels. AustTXwrx Brakes, Steering & Suspension 7 01-16-2002 09:34 AM
('93-'01) Need help deciding on car... KimchiHo Impreza Forum 15 07-07-2001 01:40 AM
Need help deciding on tires HydeX Brakes, Steering & Suspension 5 02-19-2001 12:51 AM
Message Board Statistics All times are GMT -4. The time now is 08:24 PM.
