02-23-2004, 08:51 AM | #1 |
Member#: 21657
Vehicle:02 wrx mbp |
Cusco rear sway with stock end links?
I have a bunch of clunking and squeeking sounds coming from the rear of my car when I go over bumps. The clunking almost sounds like a metal panel (like on an oil drum) popping in and out.
The only modification I have to the suspension is a Cusco swaybar with Kartboy end links. I did a search and have come to the conclusion that it's the end links causing all the commotion. I am thinking about swapping the stockers back on to see if that helps quite it up. Problem is, I don't know it they are up to handling the extra load. Does anybody have this setup and/or heard/experienced of any failures as a result? I'm worried a link might fail in a turn, upsetting the balance of the car, and causing an unsafe condition. TIA, Ross
02-23-2004, 06:28 PM | #2 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
did your sway bar come with polyurethane grease for the bushings?
poly bushings will squeak alot if they are not properly lubed. Jay |
02-24-2004, 10:57 AM | #3 |
Member#: 44089
Vehicle:2007 STi #744 No touch my vagina! |
OT
I ALWAYS use polyurethane grease on MY bushings!!!
Lube= -DriftRS |
02-24-2004, 05:00 PM | #4 |
Member#: 23260
BAIC
Vehicle:Patr ick Willis for Rookie of the year |
I have that setup. No problems unless I go over a large bump then it squeaks a little bit.
FS: NJ 2005 STi stock rear sway bar and end links | GeLLo_Boi | Suspension/Brakes/Handling | 8 | 07-01-2009 02:22 PM |
SoCal:04' WRX stock rear sway bar w/end links & mounts | sjrhee | Private 'For Sale' Classifieds | 0 | 06-15-2005 12:36 AM |
Stock WRX 20mm rear swaybar with KartBoy End Links | spelk3 | Private 'For Sale' Classifieds | 1 | 10-16-2003 11:26 PM |
Torque settings - rear sway bar and end links? | Moses | Brakes, Steering & Suspension | 3 | 05-19-2003 10:42 AM |
FS: never used cusco rear sway and mrt end links... | wrxxtc | Tri-State Area Forum | 2 | 09-30-2002 10:03 PM |
