01-13-2004, 03:59 PM | #1 |
Member#: 44452
Vehicle:2002 WRX Aspen White |
Speedometer problem...
My speedometer jumps all over the place when my car is running. Even it idle it jumps all over... Also the cruise control dosent really work, and sometimes the brights dont and neither does the foglight button.I have a stage 4 setup with a unichip. What the heck is wrong with my car?
01-13-2004, 05:56 PM | #2 |
Member#: 34436
SWIC
Vehicle:2018 Jeep Wrangler |
could be a blown fuse
01-13-2004, 08:14 PM | #3 |
Member#: 44452
ive allready checked all my fuses that i know of and theres nothing...
01-13-2004, 08:16 PM | #4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Check your connections at the battery terminals, be sure they are clean and tight.
Put a voltmeter on the battery when the engine is running to check that the alternator is charging properly, it should read 13.5-14.5V. With the engine not running the battery should read about 12.5V, any less and it may be weak. It's also possible for the alternator to have a bad diode, if this happens it will still charge at a reduced capacity and also its output will be "dirty" with spikes that may cause malfunctions like you are having. |
Speedometer Problems | itschasethebaby | Newbies & FAQs | 1 | 02-19-2008 09:37 AM |
'06 Forester XT - Speedometer Problems | Chuu | Forester Forum | 6 | 06-24-2006 12:28 AM |
Speedometer problem | MikeD909 | Transmission (AT/MT) & Driveline | 0 | 01-08-2006 12:30 AM |
97 Legacy GT speedometer problem | Flipperone | Electrical & Lighting | 0 | 03-13-2005 11:51 AM |
Speedometer problems | Hank3 | Warranty Issues & SOA Problems | 1 | 04-12-2002 07:38 PM |
