01-08-2015, 10:38 AM | #4401 |
Member#: 293838
South East
Vehicle:2011 wrx 5dr silver |
Never thought that if need it down in Florida but the line from my compressor to the air tank froze up today, godly they carry that antifreeze around here
01-08-2015, 12:32 PM | #4402 |
Member#: 341024
01-09-2015, 11:49 PM | #4403 |
Member#: 333151
Vehicle:2015 WRX CWP |
First bagged my15 in Australia
01-10-2015, 02:14 PM | #4404 |
Member#: 159478
HIIC
Vehicle:06 STi Aspen white |
Dope! ^
Sent using NASIOC |
01-10-2015, 11:49 PM | #4405 |
Member#: 338724
Vehicle:2014 WRX Hatchback World Rally Blue |
What color do you guys usually do your tanks in close wise besides the polished or raw look.
01-11-2015, 12:01 AM | #4406 |
Member#: 327872
Vehicle:2005 Legacy GT wagon Black |
My 8.5gal is flat black crinkle coat.
5 gal is polished aluminium |
01-11-2015, 05:40 AM | #4407 |
Member#: 259591
Vehicle:2011 WRX sedan WR Blue |
01-11-2015, 07:00 AM | #4408 |
Member#: 325249
Vehicle:2012 wrx dgm |
candy red
Sent from my iPhone using NASIOC |
01-11-2015, 07:30 AM | #4409 |
Member#: 333151
01-11-2015, 10:49 AM | #4410 |
Member#: 345926
Vehicle:2002 WRX Wagon White |
01-11-2015, 10:49 AM | #4411 |
Member#: 345926
01-11-2015, 05:45 PM | #4412 |
Member#: 341024
does anyone have squeaky front struts? mine don't stop squeaking when im driving, loud and annoying. all 3 top nuts in each side are tight
01-11-2015, 05:48 PM | #4413 |
Member#: 259591
01-11-2015, 05:49 PM | #4414 |
Member#: 341024
01-11-2015, 05:54 PM | #4415 |
Member#: 328682
i did when i got mine, 13 wry airlift struts but only on the driver front, replaced the strut and it went away for about 3 months now its back
01-11-2015, 05:54 PM | #4416 |
Member#: 328682
01-12-2015, 09:02 PM | #4417 |
Member#: 338724
Anyone here from Michigan
01-12-2015, 09:44 PM | #4418 |
Member#: 341024
Best Endlinks?
I heard OEM snap easy Sent from my iPhone using NASIOC |
01-13-2015, 04:55 PM | #4419 | |
Member#: 269076
Vehicle:2012 Wrx SWP |
Subys on Air Ride!
Assuming you're on Air Lift Performance suspension try adjusting your damping, it may be set too soft. Also check the two nuts that hold the upper mount onto the strut rod, there is a rod nut (first one you put on) and a jam nut (second one). The rod nut has a torque spec of 25ft lbs, jam nut is 40ft lbs. Sent from my iPhone using NASIOC |
01-13-2015, 06:52 PM | #4420 | |
Member#: 325249
my driver i think just started to squeek. not sure Sent from my iPhone using NASIOC |
01-13-2015, 11:15 PM | #4421 |
Member#: 338724
Is there any advice you guys can give for install. I'm making notes for when I install mine.
I hate the below notes: Run wires through grommet on the firewall just like boost wire is ran through the firewall. Adjust rear bags at 0 psi to make exhaust not touch. SMC water trap is ran off tank to management where most water can be caught. If you have squeaky struts try adjusting your damping, it may be set too soft. Also check the two nuts that hold the upper mount onto the strut rod, there is a rod nut (first one you put on) and a jam nut (second one). The rod nut has a torque spec of 25ft lbs, jam nut is 40ft lbs |
01-13-2015, 11:38 PM | #4422 | |
Member#: 259591
01-14-2015, 12:11 AM | #4423 | |
Member#: 325249
i second this Sent from my iPhone using NASIOC |
01-14-2015, 01:39 AM | #4424 |
Member#: 368976
HIIC
Vehicle:2014 STi Hatch PBP |
Miss these wheels |
01-14-2015, 02:14 AM | #4425 |
Member#: 410875
Really beautiful builds.I Hope to have mine as well put together eventually.
Air ride/air bag shops in the NW? | Mr. Sadface | North West Impreza Club Forum -- NWIC | 12 | 12-30-2016 04:21 PM |
FS : WI: BMW 740il on Air ride | Jester of Paint | Private Vehicle 'For Sale' Classifieds | 9 | 04-16-2012 07:49 PM |
Suby high speed ride? | ProvenPSI | General Community | 60 | 08-22-2007 08:40 AM |
Tahoe on 20" wheels, and Air Ride ON EBAY!!!! | airbags98 | Private Vehicle 'For Sale' Classifieds | 6 | 11-19-2005 10:08 AM |
All Subies on the Marine Corp air station | redgrocerygetter | South East Region Forum | 8 | 08-29-2003 05:26 PM |
