12-22-2011, 02:36 AM | #1 |
Member#: 283048
BAIC
Vehicle:2011 WRX Ltd Hatch SWP |
UOA: 11 WRX, 3296 mi, 5W-30 Castrol Edge Syntec
2011 WRX, 3296 mi on 5W-30 Castrol Edge with Syntec (black bottle).
Looks like I'll be sticking with this oil. FYI first oil change was factory fill. Second oil change was 5W-30 Castrol Edge with Titanium. Funny how the cheaper Syntec stayed in grade better and had a higher flashpoint. Don't believe all the marketing hype.
12-23-2011, 10:11 AM | #2 |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
Nice TBN in your NASCAR 20 weight qualifying oil, but you're probably smart to not to run it much past 3k miles. Good moly level in this stuff and that magnesium is way high! I guess this is to help meet the GF5 requirements for piston cleanliness. I wish GF5 also spec'ed improve wear control. I'll be interested in seeing a trend to see if your wear levels remain the same on this N. American Syntec.
-Dennis Last edited by bluesubie; 12-24-2011 at 07:31 AM. |
12-24-2011, 01:03 AM | #3 |
Vehicle:OK buy Nates beans westcoastroasting.com |
no 5w30
just no....as in none |
12-24-2011, 02:21 PM | #4 | |
Member#: 41070
Vehicle:2005 Black Tiger (Black Turbo Baja) |
I must've recollected the specs incorrectly. I had recalled that the last spec or two tightened wear control requirements noticeably. Not directly, but by making the test tougher while keeping the wear limit the same. Am I thinking of a different spec? |
12-24-2011, 11:09 PM | #5 | |
Member#: 767
Wear control for GF5 appears to be the same. http://www.gf-5.com/the_story/performance/ -Dennis |
12-24-2011, 11:45 PM | #6 |
Member#: 132400
Vehicle:2006 WRX |
care to explain? one guy on a forum vs. a car company full of engineers and hundreds of thousands of Subaru's around the world running 5w30. GO!
You may have had a bad experience but that doesn't mean everyone will. I know guys with early model Subaru's pushing 150k and get their oil changed at quick lube places when every they so happen to remember its time to change their oil. No need to clutter threads up with half (blank) advise that is not properly supported or elaborated on. Not to mention this poor newb just wants to advice as he is probably new to the scene and your just confusing him even more which in turn will make him create a new thread like "what oil weight should i use" and im sure you would love that! |
12-25-2011, 12:33 AM | #7 | |
this has been covered, HERE, more times than the Kennedy assassination and im NOT gonna ****ing go over it again |
12-25-2011, 04:46 AM | #8 |
Member#: 132400
Vehicle:2006 WRX |
car burns no oil, runs strong, oil temp is in proper range, subaru recommends it, my uoa's are great according to blackstone, oil change intervals followed closely, stage 2 at 18psi for the last 80k...Uncle Scotty says im wrong!
I give up! |
12-25-2011, 08:30 AM | #9 | |
YOU got lucky.....maybe because you change it too often for it to get too thin others arent that smart...... weiner....weiner!!!!!!!!! you just won the short bus trophy....next up......the 'I spent too much on oil changes because I think I'm doing it right' what the **** ya want??? a ****ing cookie???? |
12-25-2011, 08:40 PM | #10 |
Member#: 132400
Vehicle:2006 WRX |
Merry Christmas cool guy
12-25-2011, 08:46 PM | #11 |
Member#: 22605
Vehicle:2002 JDM STI/WRX WRB |
I run German Castrol which is 0w30
12-25-2011, 09:16 PM | #12 |
Member#: 73043
Vehicle:2019 STI/370Z/Jeep Black/Black Cherry/Green |
^^ Can't even start to compare this with most 5W-30's. It's in it's own class. RP
12-25-2011, 09:45 PM | #13 | |
Member#: 22605
12-26-2011, 01:31 AM | #14 |
which brings up another point......with SO MANY readily available oils that are SO VASTLY SUPERIOR TO VIRTUALLY EVERY 5W30 that one could buy and use, instead......and suffer NO ill effect what so ever.....and with which you could at LEAST double your oci....which would make BETTER OIL cheaper overall....
why the hell would you want to buy and use inferior oil at all this baffles me to no end |
12-26-2011, 02:03 AM | #15 | |
Member#: 22605
12-26-2011, 05:05 PM | #16 |
Member#: 132400
Vehicle:2006 WRX |
This comment is not intended to start any arguments or debate wars!
... Shouldn't all these opinions on oils be in the least supported by UOA's? Unless you know all the specific specs and tolerances of your motor how can you properly tell if your car runs best on a particular weight? And if its burning oil or not is a poor answer because that could be a handful of other issues. |
12-26-2011, 06:42 PM | #17 | |
there are many-MANY uoa's posted here and on the bitog site they all tell the same story.... 5w30 is, almost universally, bad....mmmmkay?? |
12-26-2011, 10:20 PM | #18 | |
Member#: 41070
12-27-2011, 02:25 AM | #19 |
Member#: 283048
BAIC
Just posting this for community information. This 5W 30 does work when changed at 3300 mi intervals. No abnormal wear and good TBN. I'll probably switch to 5W 40 Rotella T6 in the summer.
12-28-2011, 12:35 PM | #20 |
Member#: 172919
Vehicle:2002 wrx hybrid psm |
my turbo's been drinking my shell rotella t6 5w40. it's pissing me off. it's getting cold so i need to switch to a thinner oil. do they all end up drinking oil?
12-28-2011, 06:13 PM | #21 | |
Member#: 767
If you still want to go thinner than RT6, there's M1 0W-40 or GC 0W-30. Oil consumption is a mysterious thing and thicker viscosity doesn't always mean less consumption. -Dennis |
12-28-2011, 06:50 PM | #22 |
Member#: 60142
Vehicle:2011 WRX Grey |
If my car was "drinking" any oil, I'd be looking elsewhere for the problem. Moreover, we see temps here down to -10f, and I run T-6 all year. No cold crank issues at all, none.
12-28-2011, 06:55 PM | #23 |
Member#: 41070
Although it's heresy to most, RT6 was consumed by my Baja every bit as fast as any 5W30 ever has been. It also DESTROYED my mpg. 'Regular' 10W30s are not consumed so fast in my Baja as RT6 was, and they give distinctly better economy; it (RT6) was very disappointing. So, YMMV.
12-28-2011, 07:01 PM | #24 |
Member#: 141672
12-28-2011, 07:02 PM | #25 |
Member#: 141672
double post
Similar Threads | ||||
UOA: 2011 WRX @ 25K mi - Subaru Synthetic 5W-30 | kingme | Service & Maintenance | 25 | 10-26-2012 01:37 PM |
UOA: 05 2.5RS, 5124 mi, 5W-30 Pennzoil Platinum | ScottyB | Service & Maintenance | 4 | 12-21-2011 11:21 PM |
UOA: 11 WRX, 3182 mi, 5W-30 Castrol Edge Titanium FST | furiouswrx | Service & Maintenance | 8 | 10-31-2011 01:08 AM |
UOA: 2003 WRX 150k Castrol Syntec | foxboroxt | Service & Maintenance | 5 | 03-31-2008 09:13 AM |
UOA: 2006 WRX 5MT Castrol Syntec 5w-30 | Mind | Service & Maintenance | 18 | 03-08-2007 09:29 AM |
