01-22-2013, 05:57 PM | #1 |
Member#: 343014
Vehicle:2012 Wrx OBP |
2012 WRX stage one Datalog
Just wanted to see what your opinons are on how the car is running, just reflashed the ecu with stage 1 93oct map with the sf intake. Car seems to run great just wanted to double check and see what you all think, since your the experts haha
https://docs.google.com/file/d/0B1wv...1BLWxfYzQ/edit hope i did this right, im a nooob
01-22-2013, 07:23 PM | #2 |
Member#: 343014
think i messed the link up, this should be right
https://docs.google.com/spreadsheet/...TNLRkJRRnV5Q3c |
01-22-2013, 07:44 PM | #3 |
Member#: 321409
SWIC
Vehicle:2003 Big Effing Van 7.3L powerstroke diesel |
AF Learning is good, no knocks, hitting target boost, no boost creep.... Looks like your car likes the tune IMHO and sounds like you do too
01-22-2013, 07:59 PM | #4 |
Member#: 343014
is it normal to get some knocks during normal driving here and there within 1.5?
01-22-2013, 08:12 PM | #5 |
Member#: 321409
SWIC
Mehhh depends. If you are seeing the occasional FLKC (-1.4 or less) or FBKC (-1.5) at low loads and lower rpms that's normal. Sometimes you will get some false knock by rapidly changing engine loads (slamming down the gas pedal) or even between shifting. I'd watch out for FBKC (feedback knock) at higher loads and higher rpms or knock that keeps showing up at particular rpms or repetitive knock FBKC or FLKC that keeps pulling additional timing or reduces DAM. It would be nice to log Sensor #1 (front O2) during normal driving if you keep seeing it. Better yet in the long run invest in a wideband sensor so when you go stage 2 you will be ready to monitor things.
01-22-2013, 08:50 PM | #6 |
Member#: 321409
SWIC
OP for your reading enjoyment
https://static.cobbtuning.com/cobbtu...20FAQ%20v2.pdf http://www.romraider.com/forum/topic1840.html |
01-22-2013, 09:17 PM | #7 |
Member#: 343014
Thanks guys just wanted to make sure im running okay and not going to mess anything up
01-23-2013, 08:43 AM | #8 | |
Member#: 4803
As far as occasional feedback or fine knock correction, that is normal as long as it is single count (-1.4) or the occasional double count (-2.8), especially at lower load or when throttle is rapidly changing (either getting on or lifting off the throttle). That is generally just noise. You want to watch for consistent knock during your WOT run (other than reported knock when you mash the throttle or lift off at the end). You also want to look to make sure that once the dynamic advance multiplier (DAM) learns up to 1.0 (for 2.5L cars) that is does not drop from that value (may drop to an initial value with some maps/cars after map reflash/ecu reset/etc and that is normal). Bill |
01-23-2013, 09:20 AM | #9 |
Member#: 343014
Thanks Bill, this question has probably been beat to death but just curious though that with the setup am i putting anymore stress on the engine at all?
01-23-2013, 09:37 AM | #10 | |
Member#: 4803
If you don't abuse the car with hard launches/shifts, etc. and you keep up on all your maintenance (we recommend a high quality synthetic oil and check oil levels every time you fill up with gas), and use good quality gas, you should get many years of reliable service out of a stage 1 or stage 2 set-up. In fact, I would argue that you would, generally speaking, get the same lifespan out of the stage 1/2 car as you would with a bone stock car if those guidelines are followed (my opinion). Bill |
