06-26-2008, 04:14 PM | #1 |
Member#: 181994
SCIC
Vehicle:2008 Imp 2.5i PP 5dr Silver |
Why did Subaru not equip 2.5i's with a rear sway bar?
Dealer has no clue, said something about only WRX models get it because they're "performance" oriented. I don't think that's a valid reason. Certainly, with the rear bar, the 2.5i will be a better-handling car. What do you guys think?
Thanks,
06-26-2008, 04:26 PM | #2 |
Member#: 155025
Vehicle:2004 WRX |
Cost most likely.
Even the WRX has only tiny 15mm I think. |
06-26-2008, 05:32 PM | #3 |
Member#: 202642
RMIC
Vehicle:08 Impreza,80Vette 68 Impala, 15 SantaFe |
Most likely it is due to cost and that the target audience for the 2.5i would not really notice the rear sway bar, so why include it. I would actually agree that the 08 WRX model is more "performance" oriented than the 2.5i. i.e. the steel rims with hubcaps on the base 2.5i. The 2.5i is marketed as an economy car with AWD. It appeals the "broader audience."
It's easy enough to add the rear bar anyways. This is where an STi varient of the 2.5i would be needed. Performance minded but without the power. Actually, the 15mm sway bar on the WRX is stiffer than the 19mm bar on the outgoing model. http://forums.nasioc.com/forums/show....php?t=1370917 |
06-28-2008, 05:46 PM | #4 |
Member#: 174968
Vehicle:2008 Impreza 5sp White |
Keep in mind that a sway bar transfers more vibrations and sounds from the rear wheels. For an average driver it would be better to have a quiter drive than have tighter cornering.
07-09-2008, 04:14 PM | #5 |
Member#: 184131
Vehicle:2008 Impreza 2.5i Grey |
Really? I thought they just have some really thin sway bar. anyone got a picture of the rear end?
07-09-2008, 11:50 PM | #6 |
Member#: 170104
Vehicle:2008 Impreza-5 2.5i Spark Silver Metallic |
I personally think the better feel and ability to corner would be helped most by a racing seat and harness. Suspension components aside, it's awfully hard to control the car when you're pulling massive g's at 30mph and your seatbelt locks and your seat has no side supports.
Of course, not all of us have spouses who would remotely appreciate the cost let alone the feel of putting on a full harness as a passenger let alone a driver. |
07-10-2008, 11:48 PM | #7 |
Member#: 146216
South East
Vehicle:2007 Impreza 2.5i SE Newport Blue Metallic |
I <3 my 20mm rear wrx bar on my 07 2.5i Best mod ever. Thats a shame the new 2.5i's dont have rear bars...
07-10-2008, 11:52 PM | #8 |
Member#: 120152
Japan and Australia (IIRC) get an "Impreza, tuned by STI" model which is exactly what asesls was talking about needing. It comes with a unique color, different wheels (brakes?), exterior mods, different interior stuff.
07-11-2008, 03:19 PM | #9 |
Member#: 183894
Vehicle:2007 Impreza 2.5I Crystal Grey Metallic |
Hey guys I have a 07' 2.5I am currently trying to upgrade my suspension but not go overboard as this is just my daily driver. I just picked up a factory Subaru 20mm rear sway bar off a fellow member and I'm waiting for that to come in so I can throw that on. Has anyone swapped out the sway bar bushings with aftermarket ones by chance? If so, did it make a big difference or not? Thanks
07-11-2008, 03:44 PM | #10 |
Member#: 167943
NWIC
yes it worth the money to do it while you are doin it
12-31-2008, 04:49 AM | #11 |
Member#: 175436
Vehicle:2008 2.5i 5-Door Newport Blue |
Sorry to dig up this old thread but I didn't really feel it was necessary to post a new one for this.. This is the first car I've actually had the ability to do any work on (first one I've owned), so a lot of this is new to me. I've been looking at adding a rear sway bar to my 08 2.5i for some time (I'm tired of the hideous amounts of body roll the car has and from what I've read this mod will fix that to a point). I've been keeping an eye on the FS forum but I haven't seen anyone selling any 08 wrx or sti rear sway bars, plus I don't have any of the mounting hardware (endlinks, etc.) which are even harder to find. I found this: https://www.subarugenuineparts.com/p...oducts_id=1412
It seems like a decent price to me since it includes everything you need but I was looking for a 2nd opinion to make sure I'm not being an idiot noob (again, I've never done stuff like this before so I want to make sure I'm doing it right). So, yay or nay? |
12-31-2008, 10:49 AM | #12 |
Member#: 165121
VIC
Vehicle:15 500 White |
08 wrx sways should fit the 2.5i so you have a few choices depending on what size you want. All you have to order is the oem mounting bolts and aftermarket endlinks(usually stronger then stock). The sway should come with the mount bushings and bracket.
12-31-2008, 03:52 PM | #13 |
Member#: 194990
Vehicle:2008 OBS Steel Silver/Spark Silver |
I bought an STI sway from a member on here for $60, bought rallitek endlinks for $60 and less than $20 for the the Subaru RSB mounting brackets.
If you can find someone to sell you a used one from their WRX or STI, you'll be in fat city. The Subaru endlinks are like $40 bucks a piece; I got the heavy duty Rallitek ones for $60 for the pair. Car handles SOO much better! |
12-31-2008, 03:56 PM | #14 | |
Member#: 175436
12-31-2008, 09:05 PM | #15 |
Member#: 194990
Here's some part no's:
bushing clamps (part# 20466FG000) The bolts for those clamps (part# 010108200) The bolts on the other end of the link that connect the link to the control arm (part# 901000221) |
01-01-2009, 02:52 PM | #16 |
Member#: 198894
Vehicle:1998 Forester White |
Cause the 2.5i's an economy car.
01-01-2009, 03:45 PM | #17 |
Member#: 175436
01-02-2009, 01:16 PM | #18 |
Member#: 173983
Vehicle:08 2.5i wagon silver |
Put the WRX sway bar on mine and it leveled it out quite a bit in the corners.
My other car is a C6 Vette and the body roll in the Sube really bothered me. I feel the car is much more balanced now |
01-03-2009, 09:49 PM | #19 |
Member#: 165031
Vehicle:2008 Impreza 2.5i DGM |
Put rallitek,s Anti sways on front and back with rallitek rear and AVO solid front endlinks. It holds realy well, but shows even better how terrible stock tires are lol
01-24-2009, 01:44 PM | #20 |
Member#: 187834
Vehicle:06 2.5i impreza Red |
don't know what your talking bout mine came with them..there just really thin compared to a wrx..waiting on my cusco 22m complete kit that"s end links front and rear sway bars front and rear top and bottom...and tein s-techs with the camber kit from rallitek. Also some Tenzo-R 18's type-m with 225's for now..and raptor SC kit she's gona be a sleeping beast.
01-24-2009, 03:54 PM | #21 | |
Member#: 171948
Vehicle:19 Sti Crystal white |
02-03-2009, 02:22 PM | #22 |
Member#: 191050
South East
Vehicle:2008 Impreza 2.5i 5d Dark Gray |
2.5i w/o Rear Sway Bars
The Reason... $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
* The average run of the mill car buyer does not care. The stock 2.5i handles well. It handles better than the Civic and Corolla (both I think have rear sways). The problem is that most 2.5i owners are envious of the WRX. We know besides the DOHC turbo, our 2.5i shares 90% of the same parts as the WRX. And whether it is the $25k price tag or just not wanting to deal with a turbo, we ended up with the 2.5i. IF I did not drive the WRX and see what a little sway bar and spring upgrade made I would be happy with the 2.5i suspension. It is really a lot like the tilt/telescope steering wheel. It is a nice feature, but in the grand scheme of things, it does not make or break the sale, and when you are dealing with the 2.5i that is already more expensive than the competition, you have to remove cost someplace. Also keep in mind that the Impreza has a lower ground clearance and center of gravity which negates some of the need for the sway bar. If anything I am shocked that the WRX has a rear sway bar because every WRX owner replaces them once the car rolls off the lot. |
02-04-2009, 09:12 AM | #23 | |
Member#: 44501
NWIC
Vehicle:that 's, like, your alternate facts, man. |
Don't neglect the front bar. Due to way Subarus lose so much camber up front when rolling side to side, a larger front swaybar actually increases the car's overall grip.
The majority of the car's weight is on the front axle.. you cannot tame roll with a rear swaybar. Also, because of the AWD, you cannot put power down coming out of a turn if your inside rear wheel is completely unloaded. Here is my post about putting a very large FSB on my RS years ago: Quote:
03-06-2012, 02:24 AM | #24 |
Member#: 273127
Vehicle:2007 impreza 2.5i Black |
My 07 2.5i came stock with a light weight one. I had no idea until a month ago when my buddy gave me his old wrx sway bar..what a difference that made
03-17-2012, 02:01 AM | #25 |
Member#: 312892
Vehicle:2007 Impreza 2.5i Black |
I was under the impression I didn't have one but while rotating my tires for the first time since I bought the car I noticed I do have a rear sway bar. A small one. It will soon be replaced with a bigger one. Any suggestions on recommended size????
FS!2.5i sedan stock rear sway bars,front & rear endlinks,rsb mounts & Springs | 07impreza2.5i | Suspension/Brakes/Handling | 8 | 12-12-2009 07:23 PM |
Why did Subaru use the 2.5L in the new WRX? | bmw50021 | General Community | 90 | 01-29-2007 02:32 PM |
FS: HKS Hipermax 2 Coilvers and Cusco Rear Sway Bar | 02BlackWRX | Suspension/Brakes/Handling | 4 | 09-18-2006 02:11 PM |
FS: 99' 2.5RS Front & Rear Sway Bars w/ Endlinks! | Structure828 | Private 'For Sale' Classifieds | 3 | 06-29-2004 10:37 AM |
Rear creaking sound with Cusco Rear Sway Bar? | Tinman | Brakes, Steering & Suspension | 6 | 04-10-2002 10:51 PM |
