04-08-2001, 09:18 AM | #1 |
Member#: 4966
Vehicle:99 2.5RS Rally Blue |
Just finished 'sound proofing' my doors.
I didn't have money for dynamat, so I was looking for an alternative. I work in the construction field, so I am in contact with various materials of different natures. What I came across was "Ice and Water Shield'. What it is a thick self- adhesive tar sheet (3 foot wide). I ended up getting about 8 feet for free from a job we did, and decided to install it inside my door panels (looking for less squeaks and rattles, improved speaker sound, and quieter at cruising speeds).
I took apart me door panel (takes only a couple of minutes), Ripped off the poly that was underneath, and exposed the inside of the door. I had to wipe down the inside since there was some moisture that had collected due to the snow storm I was driving in yesterday. I had a can of Rust Check and decide to spray the bottom and side seems of the door, since it was exposed. The ice and water shield was easy to cut. I managed to cover about 85% of the inside of the outer skin. I used about 3-4 pounds of material total for both doors. TEST: I noticed that the doors sound a bit nicer when closing... They feel considerably heavier. Speakers can be at a lower volume at cruising speed. Noticeably quieter at cruising speed! No more squeaks and rattle (I also used little self adhesive felt pieces in-between the interior door skin and the door itself to combat rattles.) I recommend this to everybody... bye
04-08-2001, 10:49 AM | #2 |
Member#: 1391
E. Canada
Vehicle:1997 GF - silent ed. [email protected] untuned |
Great stuff! When you come down next weekend we'll work on my doors together ok? I'll bring the heat gun and the dynamat, with your help we'll be done in no time... just kidding
04-08-2001, 10:53 AM | #3 |
Vendor
Member#: 3600
Look into Cascade also. It is vinyl based instead of asphault based. MUCH lighter yet works wonders. I used it in my old GSR.
04-08-2001, 11:51 AM | #4 |
Member#: 4966
What's cascade?
04-08-2001, 07:52 PM | #5 |
Member#: 5075
Vehicle:98 v7 OBSTi white/grey/gold |
Is this Ice and Water Sheild stuff available at a local store (Home Depot, Menards - they are "home improvement" stores, dont know what you have in Canada), or only for construction sites? If its available at stores, do you know the general price?
Also, how much is that Cascade stuff? Is it made for car sound deadoning, or just something you found to work? |
04-08-2001, 08:28 PM | #6 |
Member#: 2163
Cascade Audio Engineering is the full name of the company you should be able to get this stuff at your local shop but if not try e-mail: [email protected] tel:541 389-6821 or fax:541 389-5273 Cascade is good and it also comes in a spray
04-09-2001, 03:59 AM | #7 |
Member#: 4966
Ice and water shield is used here in canada often on new houses...So you might have some luck asking at job sites for some left over (i used about 6-7 feet @ 3 feet wide).
It also should be available at home depot, but probably only comes in big rolls (50-200feet), maybe get a bunch of guys and pitch in or something....or try cascade, but i never heard of it....might be good good luck! |
Just finished waxing it. My WRX | ultraspdWRX | Mid Atlantic Impreza Club -- MAIC | 21 | 08-31-2008 11:53 AM |
Just Finished my 05 STI interior swap in my 02' Bug! | kscasper13 | Member's Car Gallery | 27 | 11-11-2007 01:52 PM |
whats up YO, just finished blinging out my STI!!! | jmanny152 | Off-Topic | 36 | 03-07-2005 01:33 PM |
Just finished my project... my RX Turbo that is... | Stime187 | South East Region Forum | 24 | 11-19-2003 10:43 PM |
Just finished my grille project... | Delicious Tuning | Bay Area Impreza Club Forum -- BAIC | 7 | 03-12-2001 06:48 PM |
