01-15-2005, 01:26 PM | #1 |
Member#: 56061
RMIC
newer model dash into gc
I have seen this done several places and am just wondering how dificult it is to put a 2002+ impreza dash into a gc, is thier much cutting involved and is it worth it? thanks
mike also i have seen door cards from newer models used as well.
01-15-2005, 01:51 PM | #2 |
Member#: 33782
MAIC
Vehicle:96 3MI Racing search FIRST, then PM!!! |
yes, there is much cutting and fitting and molding etc...you should do some searchs and see what you find...I know that aerosim just finished one...
01-15-2005, 03:43 PM | #3 | |
Member#: 17751
SCIC
01-15-2005, 03:51 PM | #4 |
Member#: 43128
Vehicle:92 RWD, 96 FWD 05 AWD |
meh...mike you know that kid who put EVERYTHING from a sti into his rs... if he can do it im pretty sure you could.
Rick |
01-15-2005, 03:52 PM | #5 |
Member#: 33782
MAIC
I saying from what I have read from those who have done it...you need the wrx climate stuff...heater core, etc...
01-15-2005, 03:55 PM | #6 |
Member#: 17751
SCIC
Its a drop-in cept you have to do a lil' fitment for the hvac. The rs dash beam is too narrow for the wrx hvac. And um, duh of course you need the wrx hvac equipment that goes without saying. The main point is, the wrx dash BOLTS ON to the rs beam.
Also, it actually makes it an easier swap using the wrx dash. You then don't have to do as much re-wiring. |
01-15-2005, 04:35 PM | #7 |
Member#: 43128
actually it would be worse for him casue he is swaping in a 94 wrx engine...lol
rick |
01-16-2005, 08:54 AM | #8 |
Member#: 2818
MAIC
Vehicle:2000 2.5RS |
Now what about an 05' dash?
01-19-2005, 03:25 PM | #9 |
Member#: 75638
NWIC
Vehicle:new metalocalypse is effin funneh |
so whats the verdict on this if you just want to change the dash and the center console area? i might just buy new gc8 parts ..since these are scratched..
01-20-2005, 12:48 AM | #10 |
Member#: 46278
South East
Vehicle:96 Impreza "brighton" |
I'm not sure about the RS'es, but when I swapped a WRX dash into my L, quite a bit of trimming was involved. I used the WRX beam, which had to be cut and welded to fit right, the HVAC stuff was a pretty close fit, and the dash itself is fastened a lot differently. The two different firewalls are not even close for a bolt-in fit, unless my car was an exception. My dash is different from an RS'es, after all...
It's not impossible, just a whole lot of work, trial, and error. But, once you get the fastening points set right, everything bolts in pretty close. The only plastic piece I had to cut was a little trimming on the console to get it to fit. I don't know any right or wrong way to do it, but maybe there is a better way. |
01-20-2005, 09:20 AM | #11 |
Member#: 3362
Vehicle:2001 I've wired a Few cars in my day |
Why would you want to do this, the new dash looks so lame. Not to mention the fitment won't be that great no matter how much work you do.
Z |
01-20-2005, 09:43 AM | #12 | |
Member#: 33782
MAIC
01-20-2005, 01:20 PM | #13 |
Member#: 47636
MWSOC
Vehicle:01 rsti v7 blue |
Similar Threads | ||||
05 STi+ Dash into GC | Jubert69 | Interior & Exterior Modification | 4 | 12-06-2008 03:10 PM |
USDM wrx dash into GC body? | zerogt86 | Subaru Conversions | 15 | 12-17-2007 09:38 PM |
GD dash into GC chassis | darksc00by | Subaru Conversions | 37 | 05-20-2007 11:52 AM |
Question for you GD dash into GC swappers | Lachlan | Interior & Exterior Modification | 1 | 01-08-2006 11:24 PM |
02' WRX engine stronger than newer models? | WReXinEfX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 01-28-2004 07:41 PM |
