01-31-2012, 07:00 PM | #8151 |
Member#: 281964
Vehicle:96 Integra Green |
i am really getting into photography, any suggestions of which camera to get i am looking to spend around $700-800 on a camera and equipment. what is best recommend to get started?
01-31-2012, 10:20 PM | #8152 |
Member#: 280744
South East
Vehicle:2009 CTSV 1,216whp Black Raven |
I know I have been pic whoring a little bit lately...but here is one of a pulled and partially disassembled GT-R motor getting ready to be built.
Cammed by rsutton198, on Flickr |
02-02-2012, 02:00 PM | #8153 |
Member#: 248640
Vehicle:2002 WRX WRB |
Tripod came in, but i know different location would help also.
02-02-2012, 05:06 PM | #8154 |
Member#: 151739
NESIC
Few from a set I took today:
2012 Buick Regal GS Last edited by DNut; 02-06-2012 at 02:36 PM. |
02-02-2012, 05:39 PM | #8155 |
Member#: 173013
RMIC
Vehicle:..08 AwwGrr FTW! 370wtq@5000+ft ^sea level |
So today I decided to upgrade my camera bag some.....Nikon D90, 16g card, 18-105mm and the 50mm D 1.8
This should help my quest some! If any body is interested or knows anybody looking, I'm selling my D3000, 18-55mm 3.5, 55-200mm 4.0, 2 batteries, 1g memory and nikon bag with all the orignal boxes! pm me if there is any interest |
02-03-2012, 08:07 AM | #8156 |
Member#: 151739
NESIC
The 50mm f/1.8 is a great lens, especially for the money.
I need to upgrade my equipment soon; Still working with a D70s, the 18-70 f/3.5-4.5 kit lens and the 55-300mm f/4.5-5.6 VR. Love to have a D300, but I might settle for a D200 as the budget option and invest in better glass. |
02-03-2012, 01:14 PM | #8157 | |
Member#: 229343
Vehicle:12 WRX SWP sedan 09 LGT RIP |
2. Yes, I was using a tripod. I use it quite often because if I don't photos are more likely to be out of focus despite faster shutter speeds. I've learned that I can't hand hold much lower than 1/160. 3. No, I didn't think I would need a remote or timer. 4. Yes, I did apply a slight bit of sharpening in Lightroom, bumped the slider from 25 to 45 and I'm not sure it made much difference. Can I send you the jpeg or raw files to see how bad it really is? |
02-03-2012, 05:23 PM | #8158 |
Member#: 205845
NWIC
I just want to say I'm ready for some summer shooting already!!
What do you think Armin, bit of an upgrade? |
02-03-2012, 06:28 PM | #8159 |
Member#: 248640
what tripod/scaffold are you going to trust to hold that thing up?
02-03-2012, 06:48 PM | #8160 |
Member#: 15341
NWIC
Vehicle:2012 Borderline Pro Photographer of the Year |
This question comes up a lot, but my answer is always the same: the entry-level offerings from both Nikon and Canon are very good...you really can't go wrong either way. Try them both out in person and see which one feels the most comfortable in your hands, and which controls make the most sense to you. You want to be comfortable with what you shoot with, and you won't see any real major differences in image quality until you go higher up the range in camera bodies. Starting with the kit lenses is totally fine too, but if you have the extra money, pick up a 50mm ***402;1.8 or even a 35mm ***402;1.8.
02-03-2012, 06:49 PM | #8161 |
Member#: 15341
NWIC
Nice sharp photo, and good composition. I'm not sure how I like the desaturated colors in this case. The color saturation is so low that I'd even just go full conversion to black and white at this point.
02-03-2012, 06:52 PM | #8162 |
Member#: 15341
NWIC
Yeah, definitely need a different location, but the tripod has definitely helped in getting sharp photos. Your compositions are getting better as well. However, the exposure is still a bit on the dark side for each of them. Make sure you look at your histogram to make sure you're getting proper exposure (this is something that I'll be adding when I revise this thread).
02-03-2012, 06:54 PM | #8163 |
Member#: 15341
NWIC
Not bad at all! They're all just a tiny bit underexposed, and the white balance looks to be a bit too much on the cooler side, but each of your compositions is pretty damn good. I think you could've moved the frame a little more to the left on the interior shot (so the steering wheel isn't so close to the edge), but otherwise you've done pretty well.
02-03-2012, 06:59 PM | #8164 | ||
Member#: 15341
NWIC
02-03-2012, 07:01 PM | #8165 | |
Member#: 15341
NWIC
02-03-2012, 07:09 PM | #8166 | |
Member#: 15341
NWIC
No pressure Any decent tripod and head (worth $250+ for the combo) will hold that combo just fine |
02-03-2012, 07:27 PM | #8167 | |
Member#: 151739
NESIC
Thanks! Yeah, that interior shot was WAY underexposed and I had to bump up the exposure a ton to even get it to that point without adding too much noise. I also made the mistake of only using my 50mm at that point instead of the 18-70. Lesson learned, eh? Funny about the white balance, as I have it set to "sunny" when shooting and actually tried to warm it even further by setting it to "cloudy" when editing the raw file. As blue as the photos are now, they were even more so originally. Thanks as well for the advice about the D300. I've heard that the D200 is a big drain on the battery as well (bythom.com and a few others mention that they only got 200-300 shots on a full charge...). Is the D300 any better in regards to that? Right now I can easily shoot double that number without worrying about the battery. |
02-03-2012, 07:39 PM | #8168 |
Member#: 151739
NESIC
Here's a quick and dirty temperature change:
A little better? Last edited by DNut; 02-06-2012 at 02:37 PM. |
02-03-2012, 07:39 PM | #8169 | |
Member#: 15341
NWIC
And yes, the D200 battery drain kinda sucks, which is why I ended up bringing 6 batteries with me to France, with 2 batteries always in (with my battery grip). The D300 is WAY better...I'd say back to the levels of your D70s. |
02-03-2012, 07:41 PM | #8170 |
Member#: 15341
NWIC
02-03-2012, 07:45 PM | #8171 | |
Member#: 151739
NESIC
Yeah, I was going for depth of field with the 50mm: (I had to sit in the back seat and shoot through the headrest to even get this much of the steering wheel...Should have been a sign. ) Thanks again for all of the advice! It's definitely appreciated as I've been following some of you guys for years and I finally have the chance to do some freelance work for an automotive web site, so I'm soaking this all in and trying to improve as much as possible in a short amount of time. Last edited by DNut; 02-06-2012 at 02:37 PM. |
02-03-2012, 07:48 PM | #8172 | |
Member#: 151739
NESIC
Honestly? Microsoft raw photo editor and GIMP for straightening and some minor work with levels. I think I'm finally going to purchase Lightroom this year now that I'm shooting on a much more regular basis. |
02-03-2012, 08:49 PM | #8173 |
Member#: 280744
South East
02-03-2012, 09:55 PM | #8174 | ||
Member#: 205845
NWIC
I have a Manfrotto 055XB, 498RC2 Ball Head combo, rated for 18 pounds or so. They seem to work great! Quote:
And thats just not fair!!! Haha |
02-03-2012, 11:45 PM | #8175 |
Member#: 147637
International
Vehicle:HJ's Ask Hobbs. He knows. |
I had owned my camera for 6 months, and the 70-200 for 4 when that shot was taken. Totally fair!
Koji's Quick and Dirty DIY Guide (AKA Tips for the adventerous DIY newbie) | Koji | Interior & Exterior Modification | 30 | 04-11-2009 11:31 AM |
EJ25 to EJ25 swap, first time, good tips and tricks to know? | Patrick Olsen | Subaru Conversions | 8 | 11-27-2006 10:14 PM |
Tips & Tricks to a clutch install | MRF582 | Transmission (AT/MT) & Driveline | 12 | 11-05-2005 03:39 AM |
Band photography, tips and tricks? | Matt A | Off-Topic | 7 | 08-18-2004 04:50 PM |
Quick and dirty way to extract pdf files to word or publisher? | ChosenWon | Off-Topic | 10 | 12-17-2003 10:18 AM |
