04-05-2001, 07:05 PM | #1 |
Member#: 67
SCIC
Vehicle:1999 Outlasting the competition. |
Blown Tranny Questions
i have a few Questions to people who've blown their trannys.
1. What Clutch were you running? ACT 2. How many pounds of Boost? 8# 3. What gear went? Second gear thanks [email protected] [This message has been edited by kartboy (edited April 05, 2001).]
04-05-2001, 07:15 PM | #2 |
Member#: 4866
from SCC and other people the majority is second gear. People say that the gears strip is because there is to much torqu the tranny casing moves very little when you rev but enough to get the gears to seperate a little causing the gears to strip usually 2nd gear. never happened to me just going of other posts and previous readings.
peace |
04-05-2001, 07:19 PM | #3 |
Member#: 114
Vehicle:'03 Evo, Rice White '01 Erion CBR 929 |
2nd gear goes because the % change is the greatest and you're accelerating HARD frequently. Sorry for the OT post, Tom.
[This message has been edited by ColinL (edited April 05, 2001).] |
04-05-2001, 07:28 PM | #4 |
Member#: 2621
Vehicle:2001 Impreza RS Blue Ridge Pearl |
From the posts I have been reading the MOST boost you should try to get w/o killing your tranny is 5-7. Also with that ACT clucth it prob. is too good of a clutch and doesn't give as much as the stocker does. Anyone like to disagree with me? If I am wrong in my thinking please let me know.
Chris |
04-05-2001, 10:45 PM | #5 |
over boosted again
Moderator Member#: 1458
RMIC
Vehicle:2017 WRX Limited 15 Forester XT, 21 Ascent |
ACT pressure plate with stock friction plate
9 lbs boost (I now stay at 4-7lbs) 2nd gear <IMG SRC="http://www.imprezars.com/images/2ndgearbad.jpg" border=0> Larry www.ImprezaRS.com |
04-06-2001, 01:30 AM | #6 |
Member#: 420
SCIC
Vehicle:2001 Cr-V Silver |
OH ****!
04-06-2001, 04:53 AM | #7 |
Member#: 957
Vehicle: |
This is an odd one and maybe does not relate but...
2000RS with 25000 miles on it. Stock Clutch Non-Turbo 1st and 2nd Moral: To many redline dumps will ruin a stock tranny, as if you didnt know... suby |
04-06-2001, 05:25 AM | #8 |
Member#: 296
Larry...
Thats sweet man.. But you left some teeth on the other gear J. |
04-06-2001, 09:02 AM | #9 |
Member#: 585
Vehicle:02 WRX WR Blue |
1) ACT (Street disk)
2) 7 (maybe 6) psi 3) 2nd (and maybe 1st, I don't know for sure yet) I put that poor tranny through some seriously hard launches [at 3 psi] during the 2000 Solo2 season. The post season hard driving @ 7psi didn't help either. |
04-06-2001, 10:58 AM | #10 |
Member#: 135
Ouch! So what are you guys typically paying for this repair?
I see the shop manual prescribes about 6 hours just for installation and removal of the tranny. [This message has been edited by kelley nelson (edited April 06, 2001).] |
04-06-2001, 02:18 PM | #11 |
Member#: 961
Vehicle:1999 RS-Tw/ CobraMAF Custom Rallispec kit/IC#1 |
Another question (please!):
How long did it take after turbo install before the tranny went? (or how many hard launches did you have?) |
04-06-2001, 03:01 PM | #12 |
The Emperor Protects
Moderator Member#: 13
SWIC
Vehicle:2019 Kia Stinger, 20 Bolt EV, 23 Jeep GC |
1) ACT Street Clutch and Pressure Plate
2) NO Boost - Normally Aspirated 3) 2nd Gear and Main. Basically, after the tranny blew, I had *no* gears. Launching hard never blew any of my gears, it was always the clutch drop from 1st to 2nd at redline that probably caused my problems. Its still neat to feel the car jump on the switch to 2nd gear, but now I know its slowly weakening the gear. And knowing is half the battle. -Dan |
04-06-2001, 07:10 PM | #13 |
Member#: 67
SCIC
interesting.. i think the ACt is just a bit too harsh on the trannys . after the Dogbox is installed i think i'll be using the ASR clutch and flywheel
if you still have the ACTgo easy on the 1-2 [email protected] |
04-06-2001, 10:02 PM | #14 |
Member#: 526
Vehicle:1995 Supra Turbo Red |
Kevin...well said. The Clutchmasters Stage III clutch is the way to go. It is honestly the best aftermarket clutch I've ever felt. It feels near identical to the stock clutch, yet holds 370hp in the 2.5RS.
Sean |
04-07-2001, 12:44 AM | #15 |
Member#: 2038
Vehicle:2000 RS-T Silverthorn Metallic |
And yet I still can't get any one to join thr Clutch Masters stage 3 cutch group buy??? http://www.i-club.com/ubb-files/Forum2/HTML/003441.html
[This message has been edited by Kcz (edited April 07, 2001).] |
04-07-2001, 12:51 AM | #16 |
Member#: 526
Yeah, I don't understand it. I have experienced quite a few aftermarket clutches, and the Clutchmasters Stage III is the best, by far. No one, to my knowledge, has broken a transmission using one of these. It's nearly always caused by the ACT clutches...yet people still buy the ACT clutches. Weird.
Sean |
04-07-2001, 12:57 AM | #17 |
Guest
Member#:
Get the clutch-masters kit. It is WAAAY less harsh on your tranny!
Kevin |
04-07-2001, 06:22 AM | #18 |
Member#: 670
TXIC
I think you see more transmission breakages from people using ACT clutches primarily because there are simply more people with higher HP cars using ACT.
That skews our numbers a bit, and gives us a perception of ACT = broken tranny, which I don't think is completely true or fair. That's also like saying it's purely torque that's breaking them. We've rebuilt well over 10 transmissions in the last month and a half alone. The vast majority were 2nd gear failures resulting in transmission SHOCK. It's visually easy to tell the difference between a gear that's been twisted off from pure torque and one that's been shattered from shock. Most of the people running pretty decent power on the street could get away with using the stock transmission without problems. You just have to drive it intelligently. For example, make sure it's full engaged in gear before applying full throttle, refrain from speed-shifting, and don't pop the clutch out hard. Of course, if you want to drive it hard, then you'll need a tough tranny to keep up...regardless of the clutch you use. Cheers, Trey Cobb Tuning www.cobbtuning.com |
04-07-2001, 08:26 AM | #19 |
Member#: 626
Vehicle:2001 Impreza 2.5 RS Black Diamond Pearl |
I agree.
04-07-2001, 01:44 PM | #20 |
Member#: 585
Before I even got to Trey's post, I was thinking much of the same thing. Maybe I didn't look around hard enough, but ACT was just about the only heavy duty clutch I could find until after April of 2000. When I put the tubro on it seemed like the *only* choice was "Stock or ACT."
-Scott 98 RS (and my tranny w/ Trey right now ) |
04-07-2001, 09:44 PM | #21 |
over boosted again
RMIC
Jay_UK -- I'll try to do better next time How many points do I get for each gear tooth I knock out?
Larry |
04-08-2001, 10:38 PM | #22 |
Member#: 501
International
Vehicle:1998 2.? RS Turbo ;) RBP |
ACT 2. How many pounds of Boost? 8# 3. What gear went? Second gear I do Agree with Trey though..... I don't think it is clutch related, I KNOW, at least in my case, it was the loose nut behind the wheel that caused it!! |
04-09-2001, 07:46 AM | #23 |
Member#: 28
Vehicle:1997 M3 Sedan Blue |
I do agree that the ACT is a very ON/OFF clutch. I wish it were easier to ease into.
also, I wonder if it would be possible to replace just 2nd gear with a 'hardened' unit. |
05 STi swap with blown trannie..got a question | Rei_Akira | Transmission (AT/MT) & Driveline | 1 | 03-19-2009 12:19 AM |
Model years of blown trannies? | SubaFastR | Normally Aspirated with bolt-on Forced Induction Powertrain | 32 | 08-26-2001 03:46 AM |
Blown tranny on white WRX! | Leonardo | Puerto Rico Impreza Club Forum -- PRSIC | 37 | 06-27-2001 09:02 AM |
WRX, 2700 miles, and blown tranny | 2.5 RRRRS | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 41 | 04-20-2001 06:00 AM |
