09-03-2004, 04:42 PM | #1 |
Member#: 57065
Vehicle:2004 GT35R STi PSM |
pardon my stupidity but what is..
utec's launch control what is it? what does it do? also what is "flat foot shifting??"
thanks~
09-03-2004, 05:01 PM | #2 |
Member#: 58251
Vehicle:2004 Sti GT35R 530whp @ 27psi |
flat foot shifting - shifting without letting your foot off the gas... (basically, hold the gas pedal to the floor throughout the entire 1/4 mile, even between gears.)
Launch control allows you to build boost while getting ready to take off. basically, it limits the RPM of the engine to a specified setting, and builds boost at that rpm. So, if you set it to 6000rpm, you could hold the gas to the floor, and the engine wont exceed 6000rpm, then you drop the clutch and take off. This is also critical for flat foot shifting so that you dont overrev the motor between gears. |
09-03-2004, 05:08 PM | #3 |
Member#: 57065
wow that is awesome~ i bet that can significantly help 1/4mile runs!
09-03-2004, 05:09 PM | #4 |
Member#: 53558
NWIC
Vehicle:2005 Baja Turbo White/Silver/Black 3tone |
Overrev + float = nice paperweight
09-03-2004, 05:33 PM | #5 |
Member#: 57065
wait.. one more question... then will i be limited to only 6k rpm inbetween shifts?? isn't shifting near redline ideal?
09-03-2004, 05:37 PM | #6 |
Member#: 24569
South East
Vehicle:2004 Mazda RX8 Titanium |
If you don't know what these terms are, probably not best to try them
09-03-2004, 05:53 PM | #7 |
Member#: 19470
SWIC
Vehicle:1981 Brat GL Blue |
I think that's why he's asking
09-03-2004, 05:57 PM | #8 |
Member#: 24569
South East
Well, 1 more WRX tranny to be griped about, I suppose.
09-03-2004, 05:58 PM | #9 |
Member#: 41215
Vehicle:2018 Forester |
Launch control is extremely stressful on your transmission and it usually isn't recommended unless you're running a much beefier setup in the tranny/gear department.
09-03-2004, 06:01 PM | #10 |
Member#: 39433
Vehicle:2008 Wrx Sedan |
so pretty much its not a good idea unless u got a better tranny
09-03-2004, 07:44 PM | #11 | |
Member#: 53558
NWIC
09-05-2004, 02:07 AM | #12 |
Member#: 29201
NESIC
Vehicle:BMW M3 Honda S2000x2 |
If I had a $25k tranny I'd be launching the snot out of it.
I'll just have to settle for beating the piss out of my $25k car. Pete |
09-05-2004, 02:31 AM | #13 |
Member#: 33460
Vehicle:2003 WRX Wagon |
Assuming the launch control let you set the RPMs where you wanted I don't see why this would put more much stress on the tranny. Say on a manual "launch" you rev the engine at 4500 RPM then slip the clutch and take off. Then using UTEC's launch control you set it at 4500 RPM, slip the clutch and off you go. I don't see how a launch controller alone would make things worse. It seems as long as he is slipping the clutch and not dropping it he will be putting stress on the clutch and not the tranny. Granted, the only knowledge I have of UTEC's device is from this post so please correct me if I am wrong.
09-07-2004, 01:35 AM | #14 |
Member#: 29201
NESIC
You're making boost with the launch control engaged. You have more power if you have 10psi @4500rpm (w/launch control) and less power with 0psi @4500rpm (without launch control). More power makes for a more stressfull launch.
09-07-2004, 02:42 AM | #15 | |
Member#: 53645
09-07-2004, 12:44 PM | #16 |
Member#: 43339
Vehicle:2oo4 STi URgt35r w/t3hM3finj3cki0n |
you understand how a rev limiter works yes?
09-07-2004, 01:02 PM | #17 |
Member#: 19057
Vehicle:2002 WRX & Blue Ford & '72 CB350 |
Also to make boost the throttle must be open, w/o launch control you only need a little throttle opening to rev to 4500, with launch control you cna leave the foot on the floor...... opening the throttle all the way!
09-07-2004, 01:15 PM | #18 | |
Member#: 40431
SCIC
Vehicle:2009 Scion XB |
09-07-2004, 01:18 PM | #19 |
Member#: 35006
Vehicle:2003 WRX HOT PINK |
In the UTEC manual, it says that launch control will mess up your cats also.
09-07-2004, 01:25 PM | #20 |
Member#: 43339
using ignition cut will pass unburnt fuel through your exhauast system, this is will kill your cats. your valve train also does not care for this too much.
launching the car at full torque is what will dammage your motor/tranny/whatnot. |
09-07-2004, 01:27 PM | #21 | |
Member#: 17979
Vehicle:335i Blue |
Torque peak is at 4000rpm. IMO Redline shifting will yield faster times than any other shifting. |
This is stupid but...Whats the silvertips into music? | Super_HKS | North West Impreza Club Forum -- NWIC | 34 | 02-13-2009 04:30 PM |
Please forgive my being dumb, but what is this? | keirnna | Pre-2002 Factory Turbo Powertrain | 6 | 04-13-2008 07:09 AM |
Pardon my ignorance, but what the hell is THIS? | extraducksauce | Off-Topic | 8 | 10-13-2007 02:25 PM |
TEC-II Kit: Pardon my ignorance, but what the heck | latinskllz | Normally Aspirated with bolt-on Forced Induction Powertrain | 10 | 06-17-2002 10:16 PM |
I am stupid but what does MY02 mean? | balajc | Newbies & FAQs | 4 | 02-22-2002 11:41 AM |
