04-28-2015, 07:45 PM | #1 |
Vendor Sales Rating: (44)
Member#: 220100
Vehicle:2008 Toyota Tundra Green |
*Sonic Motor Suspension Source - FEAL, ISC, BC Racing, Megan Racing, GSP, and more!**
Sonic Motor is your number once source for all things suspension for your beloved Subaru! We carry everything you need from Coilovers, Arms, Camber kits, Braces, and MORE! Don't see what you're looking for? CONTACT ME! Let me help you save money on anything you may want. FEAL 441 Coilovers - The best in the business. Specs/features: - One way adjustable, 30 click spectrum - Monotube - Japanese Swift springs - Assembled in house, U.S.A. - Rebuildable and revalvable in house, U.S.A. - Independant height adjustment - Teflon injected spherical bearing top mounts front and rear (MacPherson applications) - Aluminum top mounts - Camber adjustable front top mounts (MacPherson applications) - Slotted rear coilover mounting hole for camber adjustability (MacPherson applications) - Corrosion resistant coating + Anodized aluminum parts - High quality low friction seals and rod guide bushings - High flow pistons (allows super high range of damping tuning) Applications: 1993-2001 Subaru Impreza GC Chassis 2002-2007 Subaru Impreza WRX 2004 Subaru Impreza STI 2005-2007 Subaru Impreza STI 2008-2014 Subaru WRX 2015 Subaru WRX 2008-2015 Subaru STI 2012+ Subaru BR-Z / Scion FR-S 2009-2013 Subaru Forester 2014 Subaru Forester 2005-2009 Subaru Legacy 2009-2014 Subaru Legacy --------- GODSPEED Coilovers MONO-MAX - Insanely high quality, at a fraction at the cost of other kits! PRICE: $790 shipped in the lower 48 states! Features: -Front camber plates with pillowball mount for camber adjustment -40 precise levels of damper adjustment -Monotube shock design -Powder coated shock body -Lightweight aluminium shock body and brackets -52mm shock body with a 44mm internal piston -Independent ride height and spring preload adjustments -Italian IP F.A made shock oil with a high viscosity index -1 Year Warranty from Date of Purchase Applications: 12+ Subaru BR-Z 2015+ Subaru Impreza STI 2002-2007 Subaru Impreza WRX 2004 Subaru Impreza STI 2008-2014 Subaru WRX 2015+ Subaru WRX 2005-2007 Subaru Impreza STI 2008-2014 Subaru Impreza STI GODSPEED MONO-RS Price: $690 shipped in the lower 48 states Applications: 2003-2008 Subaru Legacy 1993-2001 Subaru Impreza GC Chassis 2002-2007 Subaru WRX 2004 Subaru Impreza STI 2005-2007 Subaru Impreza STI 2008-2012 Subaru WRX 2008-2012 Subaru Impreza STI --------- CONTACT: Zach @ Sonic Motor CELL (CALL OR TEXT): 626-214-6695 Shop Phone: 626-363-9036 Email: [email protected] AIM: Empizach
__________________
[CENTER][I] [B][SIZE="3"][COLOR="red"]~[/COLOR][COLOR="Red"]SONIC MOTOR[/COLOR] [COLOR="red"]- YOUR ONE STOP SHOP FOR ALL THINGS SUBARU~[/COLOR][/SIZE][/B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/I][/CENTER] Last edited by Sonic Motor; 04-28-2015 at 08:10 PM. |
04-28-2015, 08:18 PM | #2 |
Member#: 220100
ISC N1 Coilover Kits - Tried and True for Subaru Details: ISO9001:2000R Certified ARTC Certified -5 Year Warranty 32 Step Damper Adjustable: -Rebound/ Compression adjusted in unison via 32 step adjustment Pillowball Upper mounts: -For optimal performance Pillowball Upper mounts are a great feature. ISC Coilovers include pillowball upper mounts on all N1's. Thrust Bearing Kit: -We will not charge you 50.00- 100.00 to upgrade to a thrust bearing kit, these are a FREE upgrade on all ISC N1's. This helps eliminate the chance of spring bind; a common side effect of running aftermarket coilovers. Front Camber Plates: -When your vehicle's suspension geometry allows (vehicle specific, please check our application guide) all ISC N1's come with adjustable camber plates standard. Piston Rod Design: -High rigidity steel piston rods -Meets with race/sport standards -Shafts are valved according to the spring rate you choose. A Shock Dyno is used to ensure quality and consistent results. Single Cylinder Design: -Larger cylinder and piston design to advance driving stability and dexterity. Mono-Tube damper with high pressure nitrogen -Threaded portion of shaft is powder coated then salt spray coated for optimum street durability (We suggest also using anti seize or other protective products when you install your coilovers for even further protection from the elements if you are exposed to snow and salt.) Sports Spring: -Made from high quality SAE9254 steel -Dyno tested over 500,000 times on compression inspection with less than 5% deformation. -Fully Customizable Spring Rates: (spring rates vary depending on application, custom spring rates are available). We understand each driver has unique demands and we are happy to offer you a custom set for your vehicle. Ride Height Adjustable: -Full length height adjustable- 3 inches or more on most applications -High quality T6061 aluminum alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force. -Bound Adjustable with Separate Spring Locks -Preload is separate from ride height -T6061 Aluminum Brackets APPLICATIONS: Subaru Impreza GC8 92-01 Subaru WRX 02-07 Subaru WRX 08-14 Subaru WRX 15+ Subaru Impreza STI 04+ Subaru Impreza STI 05-07 Subaru Impreza STI 08-14 Subaru Impreza STI 15+ Subaru Legacy 99-03 Subaru Legacy 04-09 Subaru Legacy 2010+ Subaru Forester 03-07 Subaru Forester 08+ CONTACT: Zach @ Sonic Motor Cell: 626-214-6695 (CALL OR TEXT) Shop: 626-363-9036 Email: [email protected]
__________________
[CENTER][I] [B][SIZE="3"][COLOR="red"]~[/COLOR][COLOR="Red"]SONIC MOTOR[/COLOR] [COLOR="red"]- YOUR ONE STOP SHOP FOR ALL THINGS SUBARU~[/COLOR][/SIZE][/B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/I][/CENTER] Last edited by Sonic Motor; 04-28-2015 at 08:28 PM. |
04-28-2015, 08:36 PM | #3 |
Member#: 220100
Post Reserved [ksport & d2]
__________________
[CENTER][I] [B][SIZE="3"][COLOR="red"]~[/COLOR][COLOR="Red"]SONIC MOTOR[/COLOR] [COLOR="red"]- YOUR ONE STOP SHOP FOR ALL THINGS SUBARU~[/COLOR][/SIZE][/B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/I][/CENTER] |
04-28-2015, 08:36 PM | #4 |
Member#: 220100
Post Reserved [JDM brands]
__________________
04-29-2015, 02:20 PM | #5 |
Member#: 220100
ISC Suspension and more is ready for order! Best deals on all kits from Sonic Motor
__________________
04-30-2015, 02:25 PM | #6 |
Member#: 220100
COILOVER deals running now on all sets! ISC, FEAL, Megan, and more!
__________________
05-01-2015, 02:46 PM | #7 |
Member#: 220100
Special suspension deals running now for my NASIOC family! Contact me today for the lowest prices on all parts!
__________________
05-06-2015, 05:26 PM | #8 |
Member#: 220100
ALL PM'S RESPONDED! Thanks NASIOC! Contact me today for all of your parts needs!
__________________
05-09-2015, 03:41 PM | #9 |
Member#: 220100
All coilovers are ready for order! ALL PM's responded!
__________________
05-11-2015, 06:10 PM | #11 |
Member#: 220100
PM'd!
__________________
05-13-2015, 08:43 PM | #12 |
Member#: 220100
All PM's replied! Thank you Nasioc!
__________________
05-14-2015, 04:31 PM | #13 |
Member#: 220100
GODSPEED, Megan Racing, FEAL, and more are ready for order!
__________________
05-15-2015, 02:08 PM | #14 |
Member#: 220100
Megan Racing, Godspeed Project, FEAL, ISC, and more available for order today! Let us help you get the suspension perfect for your application!
All PM's responded, thanks NASIOC!
__________________
05-16-2015, 02:26 PM | #15 |
Member#: 220100
Great deals on ALL GODSPEED Coilovers now!
__________________
05-18-2015, 07:22 PM | #16 |
Member#: 220100
Sonic Motor is your source for all the suspenion you'd want!
AIR SUSPENSION and CUP KITS also available!
__________________
05-19-2015, 09:02 PM | #17 |
Member#: 220100
All of the coilovers, are ready for order! :P
I also carry BLITZ, APEXI, HKS, and many more! Contact me today for any of your coilover needs!
__________________
05-20-2015, 02:04 PM | #18 |
Member#: 220100
Sonic Motor has all suspension ready for order! GODSPEED's at insanely low pricing!
__________________
05-21-2015, 06:55 PM | #19 |
Member#: 220100
All coilover kits have shipped out! Thank you NASIOC!
__________________
05-22-2015, 06:51 PM | #20 |
Member#: 220100
All PM's replied!
__________________
05-26-2015, 06:06 PM | #21 |
Member#: 220100
All of the suspension you could ever want is available with Sonic Motor! Don't see what you need? Feel free to contact us for any other goodies you may want!
__________________
05-27-2015, 03:41 PM | #22 |
Member#: 220100
Special deals now on all GODSPEED MONO-MAX, Megan Racing, ISC, and FEAL! Contact me today for your quote.
All suspension orders have shipped!
__________________
05-28-2015, 05:21 PM | #23 |
Member#: 220100
So many coilover brands, and so many subarus! Most coilover kits are ready to ship!
ALL PM'S RESPONDED!
__________________
05-30-2015, 04:19 PM | #24 |
Member#: 220100
Coilovers are ready for order! Don't see what you want? Let me know, and I'll make sure I can get it for you!
ALL ORDERS SHIPPED! Thank you Nasioc!
__________________
06-02-2015, 01:22 PM | #25 |
Member#: 220100
Coilover suspension is ready for order!
__________________
