Brakes & Suspension Forum sponsored by The Tire Rack |
01-09-2002, 09:29 AM | #1 |
Member#: 10676
TXIC
Vehicle:2002 Sold |
I have some questions regarding Cusco Adj sway bar.
In isn't obvious to me and it doesn't help that the directions are in Japanese, what makes the sway bar adjustable. And how do you adjust it?
01-09-2002, 09:52 AM | #2 |
Got the F out
Moderator Member#: 4797
Vehicle:05 05, 01, 98, 95 CGM |
Three bolt holes. Shortest location = stiffest setting. Farthest location = softest setting.
01-09-2002, 09:56 AM | #3 |
Member#: 10676
TXIC
Vehicle:2002 Sold |
that is what I expect to see but.....
on the end there is only one bolt hole.
Thanks for your reply. |
01-09-2002, 10:00 AM | #4 |
Got the F out
You sure it's the adj. model? A friend of mine has the Cusco Adj. it has 3 holes as well. Last edited by Orion; 01-09-2002 at 10:20 AM. |
01-09-2002, 10:21 AM | #5 |
Member#: 10676
TXIC
Vehicle:2002 Sold |
Mystery Solved
I tracked someone down from Tokyo and had them look at the intructions it tunrs out I was sent a front sway bar.
Thanks a bunch for your replies. Later |
01-09-2002, 10:27 AM | #6 |
Got the F out
Sorry to hear that! You may want to keep and use the front though. Especially if you get the Adj. rear.
I have some questions regarding - Version 7 v7 EJ207 into USDM 2004 STi | STepeci | Subaru Conversions | 8 | 09-18-2009 07:26 PM |
06 wrx cusco adj sway bar and strut tower/lower brace. | ldscamaross | Suspension/Brakes/Handling | 19 | 02-07-2008 06:19 PM |
question about cusco front sway bar install | anthonyrb98 | Brakes, Steering & Suspension | 1 | 09-24-2004 04:15 PM |
ACT Clutch Installed: Have some questions regarding engagement | latinskllz | Transmission (AT/MT) & Driveline | 9 | 07-07-2003 11:02 PM |
I have a question about the ADJ sway bar | Boom | Brakes, Steering & Suspension | 2 | 11-03-2000 09:03 AM |
