08-12-2010, 01:42 PM | #1 |
Member#: 248626
Power shut off for a brief second while driving
Has anyone experienced an issue where the whole power in the car shuts off for a brief second while you are driving. I was driving to work this morning several times the power shut off, headlights, radio, and any other electrical components. I was still driving, the car itself did not shut off. I've been having issues since I installed my fogs. Occasionally the car doesnt turn on and I have to pop the hood and wiggle the negative terminal. Could a bad terminal wire cause the issue stated above even though the car is already running?
08-12-2010, 08:20 PM | #2 |
Member#: 53443
Vehicle:2001 LL Bean Outback Winestone |
The battery connections should be snug enough they don't turn when pushed on. I suggest you clean the battery connections and tighten them correctly. If that doesn't solve the trouble then there may be an ignition switch problem.
Similar Threads | ||||
After a long drive and shut off for 10 minutes, wouldn't start afterwards... | elitescouter | Newbies & FAQs | 4 | 03-14-2010 12:24 AM |
car shuts off while driving | reeksti | Service & Maintenance | 5 | 03-07-2006 10:40 AM |
Car shuts off while driving (post for a friend) | BlueTDimly | Normally Aspirated Powertrain | 4 | 12-30-2002 11:25 AM |
Engine shut off while driving | I drive a WRX wagon | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 04-10-2002 02:51 PM |
car shuts off while driving.... | sethiscope | Service & Maintenance | 3 | 03-11-2002 02:36 PM |
