07-05-2013, 04:57 AM | #801 |
Member#: 57441
VIC
Vehicle:07 STI CGM |
but Hummel, it wouldn't fit in with your Cusco widebody. You need a voltex wing! =p
07-07-2013, 08:51 PM | #802 |
Member#: 220153
Vehicle:'05 WRX JBP WFC#207 GTX3076 ViPec V44 |
07-07-2013, 09:42 PM | #803 |
Member#: 223181
Vehicle:05 WRX, stage mehh hybrid built SOLD!!! :( |
I wanna see more of the tow set up
07-16-2013, 02:31 AM | #804 |
Member#: 134949
VIC
Vehicle:'07 SWP STi Instagram | arthurlam89 |
It's about time I got this done!
Cosworth gaskets finally in. Cometics were blown on both sides. Took only about 27psi. Can't wait to get it back in and turn up the boost. Last edited by alcoolaid; 12-21-2013 at 12:23 AM. |
07-16-2013, 02:41 AM | #805 |
Member#: 329344
South East
Vehicle:2008 Forester XT DGM |
By far my favorite build on here. Looking forward to the future videos once the engine is back in. Whats your target boost with the new cosworth gasket?
07-16-2013, 02:53 AM | #806 |
Member#: 134949
VIC
Thanks! Probably going to see what the s300 83-75 can do at 32 pounds? It already starts falling down at around 27 pounds at 7000 ish rpm I think. But would be cool to see how much torque 32 psi gives me haha
07-16-2013, 02:58 AM | #807 |
Member#: 134949
VIC
While I was down at MPS with the motor, brought down my friends Miata to have tuned again with his Vi-Pec V88. Dom worked his magic and the engine is super smooth!
07-16-2013, 03:26 AM | #808 |
Member#: 92894
BAIC
Vehicle:2015 Wrx - fury kit silver duh |
Did you resurface the heads and the block with the new gaskets?? Also did you use the copper spray as well?
07-16-2013, 03:27 AM | #809 |
Member#: 134949
VIC
And last update before bed. Picked up my stoptech trophy 6 piston bbk for the front.
Can't wait to test these babies out. Anyone have hook ups for PFC brake pads? Probably going to try out the PFC 08 pads. Last edited by alcoolaid; 12-21-2013 at 12:24 AM. |
07-16-2013, 03:29 AM | #810 |
Member#: 134949
VIC
Nope, just checked for straightness, cleaned them and put it all back together. Should be good for up to 35-37psi. After that going to need to o-ring the block I guess.
07-20-2013, 06:15 PM | #811 |
Member#: 212926
Vehicle:97 Wrx Black |
07-20-2013, 09:27 PM | #812 |
Member#: 134949
VIC
07-21-2013, 11:59 AM | #813 |
Member#: 327495
Vehicle:2012 Impreza WRX 5DR Plasma Blue |
You have a fast car ;o
07-24-2013, 11:55 PM | #814 |
Member#: 247850
South East
Vehicle:2007 SWP STi CGM '07 Forester |
08-04-2013, 11:05 PM | #815 |
Member#: 134949
VIC
Finally got some free time from work this weekend (long weekend in Canada). Was on vacation 2 weeks ago in Hawaii so last week was busy.
Finished off the extended studs on the driver side and got the brakes in. Prepping for the track day at the Ridge Motorsports Park with Turn 2 Lapping on August 16. Stock vs st60 Passenger side in Clearance issue with backing plates... had to do some bending The money shot Waiting on my rear shocks to come back from KW this week. After that I can test out these brakes and get some street tuning done. Last edited by alcoolaid; 12-21-2013 at 12:25 AM. |
08-05-2013, 03:35 AM | #816 |
Member#: 291602
RMIC
Vehicle:2007 Limited STI#464 Satin White Pearl |
Looks great! As always you have out done your self!
08-19-2013, 12:56 AM | #817 |
Member#: 134949
VIC
Fun day at the ridge! Was going so fast down the straight during the open session that the welds on my splitter cracked off... talk about downforce. Two people could stand on it and it wouldn't even break.
08-19-2013, 12:59 AM | #818 |
Member#: 134949
VIC
Need more spring rate! Adjusting camber after lunch Last edited by alcoolaid; 12-21-2013 at 12:26 AM. |
08-19-2013, 01:20 AM | #819 |
Member#: 220153
track photos are amazing! good one sir!
09-21-2013, 07:05 AM | #820 |
Member#: 134949
VIC
Had some time to do some work on the car today. Been meaning to put AC back in the car but the downpipe needed to be modified so I can get more clearance for the AC lines.
Tig welding underneath a car sucks. Especially when no one is there to help you hold things while you tack weld... oh well! Chopped up and moved Was thinking of starting it up like this but it got late haha Tacked together Weld on flex Butt weld Finished!! I used solar flux this time around instead of back purging with argon. The results are pretty good! Forgot to take pictures of inside. |
09-21-2013, 10:21 AM | #821 |
Member#: 82864
NWIC
Vehicle:2005 MPS Wagon HTA35 Domtuned Stage $$$$$ |
You are getting good at this!!
09-21-2013, 10:38 AM | #822 |
Member#: 247850
South East
Track video looks like so much fun! I can't wait for the day..
Did you know how to weld prior to making your splitter and what not or are you just learning as you go? The downpipe looks good! |
09-21-2013, 02:59 PM | #823 |
Member#: 319109
NWIC
Vehicle:2006 Forester XT |
So much respect for you building this thing yourself from the ground up! Awesome car!
Also I liked watching the things on your keys lay out almost horizontal in corners haha, gives a good sense of how much lateral g's youre generating |
09-21-2013, 03:43 PM | #824 |
Member#: 134949
VIC
Didn't know at all but had a friend that did so I got to pick his brain a bit. Rest was all reading online, watching some videos then learning myself with practice. Only reason I decided to learn was because I thought to myself why pay someone like $1000 for labour to build it when I can get a cheap welder for like $600-700 and build it myself. Plus I can use it for other projects.
09-21-2013, 03:44 PM | #825 |
Member#: 134949
VIC
Thanks for the kind words! Yeah these new slicks I'm on are pretty. Never felt so much grip in my life before lol
04 STi Weekend Warrior | Blazin | Brakes, Steering & Suspension | 2 | 03-07-2008 02:10 PM |
So I just found out I need hand surgery tomorrow...Weekend warriors be careful! | Neek | Off-Topic | 45 | 12-12-2006 09:30 AM |
Attention Car Enthusiast’s, Car clubs, & Weekend Warriors | GotTurbo | Tri-State Area Forum | 15 | 08-11-2006 02:46 PM |
Optimum weekend warrior suspension set up? | EarlQHan | Brakes, Steering & Suspension | 15 | 11-03-2005 01:18 AM |
What pads are folks using for daily driver/weekend warrior? | Mephiska | Brakes, Steering & Suspension | 6 | 06-28-2002 02:08 PM |
