09-18-2008, 06:18 PM | #1 |
Member#: 94099
Vehicle:2002 WRX 02 Silver |
STI Shorkblock swap... Headgasket size?
I bought a sti shortblock and am planning on putting my 2.0 heads on and doing the whole hybrid thing. I was reccommended the 2.5L headgasket with 1.9mm thickness by gruppe-s. Is there any experienced engine builders out there that can comfirm or dent the size? All the internals (ie cams and such) are stock and its a brand new sti shortblock.
Thanks, Tom |
09-18-2008, 11:20 PM | #2 |
Member#: 101865
Vehicle:88 GL-10 STi silver |
if you use the stock EJ257 gaskets you will have a compression ratio of about 8.9:1. if you use the 1.9mm gaskets you will have a compression ratio of about 8.0:1.
the stock SIT EJ257 ratio is about 9.23:1 stock WRX EJ205 is about 8.0:1. Note: this info is from Matt's ratio calc. -=Suberdave=- |
Similar Threads | ||||
STi V6 swap vs. STi V7 swap | moss | Subaru Conversions | 47 | 01-12-2014 03:56 PM |
What headgasket size for 100mm pistons? | DigitalPunk | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 03-05-2009 12:19 PM |
buying a sti with blown headgasket | guiltyone311 | Service & Maintenance | 4 | 11-08-2008 12:09 PM |
Southcentral PA: Need help swapping headgaskets. Anyone? | Siper2 | Mid Atlantic Impreza Club -- MAIC | 2 | 07-10-2006 12:27 PM |
Swapped headgaskets... car won't start. PLEASE HELP! | ilmaestro | Normally Aspirated Powertrain | 20 | 03-31-2004 02:25 AM |
