04-22-2006, 11:08 PM | #1 |
Member#: 49978
NESIC
Vehicle:2002 WRX w/ JDM STi 6spd, EJ255, VF39 & EWG |
JDM LGT Spec B swap into WRX, could using 91 instead of 96 be causing my misfires?
So, it's supposed to be running on 96, but the highest we have here in OK is 91...I'm just under half so I'm going to go get some unleaded race fuel if possible and see how she runs, think this could cure misfire problems in all 4 cylinders? Motor has under 1000 miles and has brand new spark plugs.
04-22-2006, 11:33 PM | #2 |
Member#: 22290
TXIC
Vehicle:2002 STI Ver 9 Spec C Wagon |
What ECU and injectors are you running?
04-23-2006, 12:22 AM | #3 |
Member#: 48291
Vehicle:02 EJ207RA/JDM6 Still truckin' |
I would say don't even drive till you get your octane up. We just reflashed my V7 STi ecu to run on 93 octane, and the base timing map was insane! We kept pulling and pulling timing to keep the ecu happy. I was running ~95 octane at first and the ecu didn't like it a whole lot. To answer your question, if ou have to drive it, get some 110 mix in there, then get ECUteked or another flash program. We beta'd ECUedit and the enginuity software on my car and it worked flawlessly.
good luck Hunter |
04-23-2006, 01:17 AM | #4 | |
Member#: 49978
NESIC
04-23-2006, 02:27 AM | #5 |
Top Scoob 024
Member#: 56364
International
Vehicle:RIP stompr :( bagged vulvva |
it is a complete spec b motor with a usdm ECU?
04-23-2006, 03:05 PM | #6 |
Member#: 49978
NESIC
No, it is a spec b longblock, no turbo, injectors, exhaust or intake mani's.
04-23-2006, 05:18 PM | #7 |
Member#: 48291
um, ya. If the motor is AVCS equipped and your ecu is not, I could see that causing some problems. It sounds like you've got some stuff going on that I didn't take into account. Give us a detailed list of turbo, injectors, wiring done, ecu ect to figure it out.
I'm pretty durn sure that ecu should not run your motor tho. let alone the fact that 2.5 L would require a signifigant retune to run with your ecu. |
04-23-2006, 08:50 PM | #8 |
Member#: 49978
NESIC
skiblur, this is a 2.0L motor, pretty much internally the same as ours with the exception of the pistons. I'm still running TD04, stock 380cc injectors. As far as I know, there has been some wiring done with respect to the front driver's side cam position sensor. It is being taken to MZM International tomorrow for them to take a look and fix the problems, and for an ECUTek reflash. Oh and AVCS is not hooked up.
What could be causing my engine stalling? | anthonywrx | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 6 | 12-05-2007 05:47 PM |
FS: 2002 JDM STI SPEC-C Swapped WRX Stoptech BBK, Enkei, 6spd, Takata, 411whp!!! | gregfeder | Private Vehicle 'For Sale' Classifieds | 62 | 07-22-2006 02:01 AM |
to anyone w/a wrx swap into their rs using rs tranny and lightened flywheel: | legacy2003 | Subaru Conversions | 1 | 11-01-2005 09:29 PM |
Jdm ej207 swap into wrx is finished. Its crazy. | WRXerRacer | Subaru Conversions | 10 | 01-03-2005 07:17 PM |
What could be causing my "ping"? | Reflex-Arc | Normally Aspirated Powertrain | 8 | 07-13-2002 03:26 AM |
