12-15-2011, 12:31 PM | #1 |
Member#: 206851
MWSOC
Vehicle:56 Belair Pro Street |
HLA G valvetrain rpm limits
Mechanically, the G HLAs appear to be exact to the EG33 valvetrain, which I am intimately familiar with. The one difference I see is that the G does not use dual springs, where the EG does.
The EG tolerates 7800rpm (valvetrain limited) easily. I see a 7400 ceiling noted with the G. I am curious to see if we can cram the inner spring off an EG into the G. Of course we'd need to compare the lift values and such between the two. Could this give the resilience to reach 7800 safely? |
12-15-2011, 01:40 PM | #2 |
Member#: 51480
International
Vehicle:1984 AM5, 1984 AF1, 1994 BC4, 2015 Outback |
HLA EJ20G 7200 with moderate boost, above it or with more boost valve float will occur.
You cannot use EG33 HLA on an 1992-1996 EJ20G HLA as the diameters are different (EG is bigger, 33 mm whereas EJ20G is 30 mm). You could use those lifters on 1997-1998 EJ20G/K/R heads (same diameter of buckets) if you also use EG33 valves and springs. |
12-15-2011, 01:45 PM | #3 |
Member#: 206851
MWSOC
Thanks as always Marnix.
So a certain no to using just EG inner springs with the G primary springs? |
12-15-2011, 01:51 PM | #4 |
Member#: 51480
International
I've never checked that in details but I doubt it.
02-07-2012, 10:03 AM | #5 |
Member#: 51480
International
I have ordered valve springs, seat, retainer and intake valve for an SVX to check if they work on EJ20G/K heads.
02-08-2012, 11:08 AM | #6 |
Member#: 296056
Vehicle:1993 Turbo legacy Metalic silver |
The HLA's out of phase one EJ22's will work in the EJ20G heads also.
02-08-2012, 12:23 PM | #7 |
Member#: 16819
SCIC
02-08-2012, 12:45 PM | #8 |
Member#: 51480
International
Correct, only 1989-1993 Legacy GT/RS heads with 57cc combustion chambers and rockers.
02-19-2012, 02:32 PM | #9 |
Member#: 94268
TXIC
Vehicle:1995 JDM STi RA ver2 2010 Exige S240 |
Even thought my G says 7300ish RPM, I shift at 7.
02-20-2012, 12:09 AM | #10 |
Member#: 51480
International
The 1994-1996 EJ20G type RA and STI RA engine has a 7500 rpm redline but come w/o HLAs.
Similar Threads | ||||
RPM limit | SW00P_G | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 04-13-2004 06:59 PM |
stock 2002 WRX RPM limiter | JHSPayBar | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 10-10-2002 11:18 AM |
RPM limiter in WRX? | wReXeRw | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 20 | 07-02-2002 08:26 AM |
RPM Limiter | Lord-Atak | WRX Forum Archive | 2 | 02-15-2001 01:49 PM |
