04-26-2006, 05:35 AM | #26 |
Member#: 37059
Vehicle:03 WRX World Rally Blue |
does anyone have a diagram of a turbo that describes where is the "oil outlet hard pipe" and the "oil return hard pipe"? I'm kinda confused on what's what in terms of those hard pipes that are sticking out on my vf39 I'm going to install into my 03 wrx.
Also, in what step would the uppipe install come into play? Would it be where you removed the 3 14mm bolts that hold turbo on uppipe flange?
05-08-2006, 07:40 PM | #27 |
Member#: 33223
Vehicle:2003 '03 WRX Vf39 blue pearl |
How many gaskets are there for the turbo install? I want to make sure I get all new gaskets. There is one that connects the dp to the turbo and one that connects the uppipe to the turbo.
That's 2 total. Are there any others I need? |
05-08-2006, 08:49 PM | #28 |
Member#: 32459
Vehicle:02 WRX VF34 (SOLD) Junior Tuned 301whp |
You probably won't need new gaskets during turbo install. Majority of people reuse stock gaskets without much problem. Mine had over 60k miles and was still in excellent condition.
05-08-2006, 09:57 PM | #29 |
Member#: 33223
Thanks for the advice...but I don't mind spending the extra money. So are there a total of 2 gaskets needed?
05-08-2006, 10:12 PM | #30 |
Member#: 32459
Yes, there are two gaskets. Good luck with the install.
05-08-2006, 10:30 PM | #31 |
Member#: 114480
Vehicle:02 wrx |
nice write-up thank's for sharing.by the way why didn't you get new gasket?i hope there wont be any leak.
06-02-2006, 02:42 AM | #32 |
Member#: 33223
What's the best way to plug up the coolant lines on the turbo?
06-02-2006, 03:23 AM | #33 |
Member#: 24096
Vehicle:2015 STi Red/white |
just unplug them and put them vertical as fast as you can to avoid spilling the most coolant. We never figured out a good way to do this as cleanly as possible. at least thats my exp. in 5 turbo installs. just put more coolant back in and burp it via radiator hose (edit: when done installing everything)
^^correct me if i've been doing this wrong the whole time. |
06-02-2006, 10:28 AM | #34 |
Member#: 33223
Should I disconnect the top coolant line on the turbo first and then the bottom coolant line? Won't there still be coolant inside the turbo that will leak out of the hardlines or do I just worry about the soft hoses?
06-02-2006, 10:35 AM | #35 |
Member#: 62197
South East
Vehicle:2008 WRX DGM |
Yes coolant will still leak out of the turbo. You will not be able to do it cleanly. It doesn't really matter though. You just refill as needed.
The oil return line is the one directly on the bottom of the turbo pointing down. If you are replacing this, you will need an additional gasket. |
06-02-2006, 10:38 AM | #36 |
Member#: 33223
I have the oil return line gasket already. Do I have to worry about losing oil when changing out the turbo?
I want as clean as an install as possible. I was thinking about just shoving a lot of towels towards the base fo the turbo. |
06-02-2006, 11:19 AM | #37 |
Member#: 62197
South East
The turbo will be empty of oil. It drains out when the car is not running.
06-03-2006, 02:58 AM | #38 |
Member#: 24096
just put newspaper and some towels under the general area of the turbo/coolant and it'll catch most of it. it sucks but its messy
i.e. on the floor etc, there is no way to get around it really |
06-08-2006, 11:07 PM | #39 |
Member#: 33223
I'm planning to do fuel pump, injectors, and turbo all at once with my brother. If I leave the car sitting for a couple of days, will the fuel depressurize enough so that it won't spray all over the place? He's gonna be doing the fuel pump while I work on the turbo and injectors.
06-08-2006, 11:20 PM | #40 |
Member#: 32459
There is a proper way to depressurize the system by pulling a plug by glove box. However, I never had problem of fuel spraying all over the place...
06-09-2006, 01:34 AM | #41 | |
Member#: 103320
Vehicle:1998 swapped Forester L |
06-09-2006, 03:03 AM | #42 | |
Member#: 33223
06-24-2006, 03:55 PM | #43 |
Member#: 103320
fuel pump is quite easy, you just have to be careful as it is a complicated apparatus and don't want to bend anything. Changing the actual pump in the bracket took about 2 minutes.
To depressurize the system before installing my 255 pump, I unhooked the power from the fuel pump while the car was running via the white harness. |
08-05-2006, 12:02 AM | #44 |
Member#: 32459
in fact, I never had to depressurize the system when I installed fuel pump... never had any problem of fuel spraying all over the place. Maybe tiny 100mL of fuel spilled over...
08-05-2006, 04:27 AM | #45 |
Member#: 81013
very nice write up man
08-05-2006, 04:47 AM | #46 | |
Member#: 94141
TXIC
Vehicle:2002 WRX Platinum Silver Metallic |
this took away much of my fear of doing a swap. The injector swap looks to be more of a pain. Shane |
08-05-2006, 09:50 PM | #47 |
Member#: 32459
Yeah, it is not as difficult as you might think. All you need is right tools and patience. Just take time and watch out for any leaks post install.
08-05-2006, 11:01 PM | #48 |
Member#: 82391
Vehicle:08 OBP Sti |
Took me a little over 3 hours on the injectors fun stuff just have to remember the car doesnt start next time if theres any lost bolts in the engine bay.
One more thing that makes the turbo super easy to install is replacing the oil line hose clip down below the uppipe. I could never get that thing to stop sliding back down the oil line every time i push the turbo in place. Major PITA |
08-05-2006, 11:05 PM | #49 |
Member#: 32459
having small hand really helps...
08-06-2006, 03:30 PM | #50 |
Member#: 48831
SWIC
Vehicle:2002 Protuned Wagon Bugeyes Forever |
Good write up, txl146.
Similar Threads | ||||
Will a OEM Flywheel for a 2.5L fit on a 2.0L WRX? | em199si | Transmission (AT/MT) & Driveline | 13 | 11-23-2010 08:23 AM |
'05 2.0L WRX VF34 dyno results | Acingteam | Proven Power Bragging | 17 | 01-07-2009 01:58 PM |
Will coilpacks from 2.5L WRX or STI fit on 2.0L WRX? | gopsu | Service & Maintenance | 7 | 10-08-2008 11:31 AM |
2.0l wrx with vf34 | kmt | Proven Power Bragging | 26 | 06-01-2007 11:36 PM |
2.5L Oil Pan on 2.0L WRX | theostubbs | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 12-20-2006 09:02 AM |
