Tire & Wheel Forum sponsored by The Tire Rack |
08-16-2010, 09:06 PM | #1451 |
Member#: 250295
Vehicle:2010 Outback Sport Black |
Hey guys. Thinking about painting my stock OBS wheels black. I'm leaning more towards flat black, but i thought i'd get a general consensus first. Flat or gloss?
And if i were to go for the flat look, what would i need to do as far as technique and/or product that i use. Like is there a type of paint or clear coat that gives more of a matte finish? Sorry if i sound like a n00bz0rz. I am. I've only had the car for like 2 months.
08-18-2010, 08:26 AM | #1452 |
Member#: 235305
Vehicle:2002 blob swap wrx was wrb |
Here's mine. Wasn't really trying to match the stock color but it is hard to tell the difference. Out of like 15 silver colors to chose from at Advance Auto, I chose Platinum Silver Metallic. I wet sanded first with 400, metal etch primed, re-sanded, painted, and then got my body shop guy to clear coat. The stock 06-07 WRX wheels are worse than my 02-05 WRX wheels. Just primer on the back, no paint, and no clear from factory.
My untouched spare on left above and below. |
08-27-2010, 12:57 AM | #1453 |
Member#: 206022
RMIC
Vehicle:2005 STI CGM |
06/07 Stock WRX TR Rims
3 coats of Rustoleum Midnight Black Metallic 2 coats of Rustoleum Clear Coat Only prep work was sanding , no primer |
08-27-2010, 09:29 AM | #1454 |
Member#: 90513
Anybody use VHT engine metallic gold flake (SP404) yet?
08-29-2010, 11:28 PM | #1455 |
Member#: 223305
International
Vehicle:2016 WRX CVT Red |
Diamond Grey version 7's |
09-30-2010, 05:35 PM | #1456 |
Member#: 247574
Vehicle:2013 PBP GV STI 2008 Impreza 2.5i |
MY02 OEM color change
Well, I found a deal on 6 OEM wheels a while back. They're 16", but will be prefect for winter. I found some tires to suit the needs of our winters, Michelin X-ICE 225/50/R16 (physically same height/width of stock 225/45/R17). They are a little wide for the 6.5" 16" wheel, but should be fine, especially since I got a good rebate on the Michelins. I tried to match the factory color of my MY10 WRX wheels as close as I could. "Graphite" was the most plentiful. So, after about $35 worth of primer, paint and clearcoat; $200 worth of TPM sensors, and ~$500 worth of tires, I have my winter set ready to go!!
Before (spare 2 wheels/tires) Primer after 3 coats! Graphite paint after 3 coats! Clearcoat after 2 heavy coats! Inside of wheel (no clearcoat) Centercaps after paint and clearcoat Ready to be mounted! Only thing left is to do is a little finishing touches to the center caps. I'm thinking of filling in the "Subaru" with blue to match the car color. Won't be long before they will need to be put on. Cold weather's coming fast! I just installed mudflaps last night. I'll have a picture show of them in the "interior/exterior" forum. Last edited by ki4syr; 09-30-2010 at 06:21 PM. |
09-30-2010, 05:44 PM | #1457 |
Member#: 107618
Vehicle:06 GG WRX / 09 FXT @florencedestinedfxt |
great job, brother. don't forget to show us how it turns out with them mounted.
I need to start working on my winters as well... |
10-05-2010, 10:40 PM | #1458 |
Member#: 248293
Vehicle:2010 2.5i hatch SSM |
anyone have a 08+ 2.5i sotcker painted black? I was thinking about doing this. Wanted to know how it would look. Color of the car doesn't matter but silver would be prefered
10-07-2010, 03:34 PM | #1459 |
Member#: 254097
Vehicle:2010 2014 Impreza |
10-11-2010, 12:43 AM | #1460 |
Member#: 180822
SCIC
Vehicle:1997 vw <3 mean green |
10-19-2010, 06:46 PM | #1461 |
Member#: 252270
E. Canada
Vehicle:2011 WRX 5dr Premium WRB |
If I want to paint a set of 02 wrx wheels gold, should I paint them white first and go with the primer, gold and clearcoat ?
10-22-2010, 05:30 PM | #1462 |
Member#: 238715
Vehicle:2004 STi |
10-23-2010, 05:02 PM | #1463 |
Member#: 225193
Vehicle:08 sti spark silver |
sticky weights
Anyone have issues with sticky weight adhesion to a diy painted wheel? thinking of painting my bbs wheels but wondering if i should just do the face or remove the existing sticky weights and do the inside as well.
10-23-2010, 06:27 PM | #1464 |
Member#: 252270
E. Canada
10-26-2010, 01:32 PM | #1465 |
Member#: 225193
anyone? i want to paint the inside of the wheel but afraid of the stickies peeling off. i'm guessing with proper prep/painting the stickies will stay on?
10-26-2010, 02:00 PM | #1466 |
Member#: 4574
Vehicle:2020 Sierra 1500 AT4 Summit White |
You should have no problem with the weights coming off, you may have a problem with the paint come time to take the weights off.
I have been running stick on weights for 2 years on self painted wheels with no problems |
10-27-2010, 03:56 AM | #1467 |
Member#: 254097
10-27-2010, 01:42 PM | #1468 |
Member#: 181352
Vehicle:2005 Impreza RS Black |
Hey guys, so I'm going to paint my stocks flueorescent yellow in a few weeks. I have to take my summers off of them and put on my winter wheels. Should I take the summers off, paint them, and then get the winters put on. Or should I get the winters put on than paint them. Thanks
10-27-2010, 01:42 PM | #1469 |
Member#: 88501
BAIC
Vehicle:2011 WRX Hatch Dark Grey |
What kind of wheels are these?
I'm finding that I love 16x7 wheels. Slap the right tire on there and it's the most versatile combo... just like the car. It can do DD commute in comfort, or track day (summer tire), or spontaneous romp on the dirt (all season/winter/etc) |
10-27-2010, 01:51 PM | #1470 | |
Member#: 4574
10-28-2010, 12:38 AM | #1471 |
Member#: 252270
E. Canada
Are those product would work good ?
Primer = Dupli-Color Primer Sealer Paint = Dupli-Color Gold Clear = Dupli-Color Acrylic Enamel or Clear Wheel Coating Do I need to sand after some coat of primer ? or just before... And sorry guys to ask you that, but here where I live they don't have those exact products. But in a week im going in Maine for a trip. Do someone know in which store I can find those things ? Thanks ! Last edited by armadatilem; 10-28-2010 at 11:22 AM. |
10-28-2010, 06:50 PM | #1472 |
Member#: 252270
E. Canada
Someone ?
I don't know in which stores I can get that in the US. |
10-28-2010, 10:09 PM | #1473 |
Member#: 254097
That stuff would work fine, my Quebec friend! The more you sand, the smoother it will look. I went with a 'hammered' finish so that it is rougher, and therefore hides the imperfections more.
10-29-2010, 10:15 AM | #1474 |
Member#: 4574
10-29-2010, 03:07 PM | #1475 | |
Member#: 254097
Yup, they're Legacy GT wheels form a '99. 16x6.5 actually. |
Similar Threads | ||||
re-painting already painted stock wheels | subiedriver4444 | Interior & Exterior Modification | 14 | 12-04-2012 08:13 PM |
WANTED: Pics of painted stock wheels on PSM Bugeye.. | vipernj | Member's Car Gallery | 1 | 10-10-2005 07:40 AM |
WTT painted stock wheels for non painted stockers | ErikAnderson | North West Impreza Club Forum -- NWIC | 19 | 05-04-2005 07:47 AM |
Any pictures of painted stock wheels (WRX)?? | eightballrj | Member's Car Gallery | 31 | 11-15-2004 12:08 PM |
Painted stock wheels | WRBlueMeanie | Interior & Exterior Modification | 8 | 04-23-2003 02:35 PM |
