Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 02-28-2011, 02:48 AM   #1
subbiechronic
Member#: 275305
Unhappy Help! noob mistake
so i did a noob mistake, i decided to take off my manifold without disconnecting the batteries first, nyways i unplug everything needed to take the manifold off to fit my new inlet. after i put everything back, my car starts but when i try to reverse she dies, plus running super lean, 16-17, help.. dono if i need a tune or safe map
old turbo 16g, new fp green, cobb v2, 850cc injctrs, perrin front mount, turbo back
subbiechronic is offline   Reply With Quote
Old 02-28-2011, 02:58 AM   #2
subbiechronic
Member#: 275305
also feels like she is going to die at idle
Old 02-28-2011, 03:01 AM   #3
XanRules
Member#: 157348
I Thlammed My
Penith in the Car Door
Replace your manifold gaskets? Hope so.
Check ALL your vacuum connections - something is leaking.
XanRules is offline   Reply With Quote
Old 02-28-2011, 03:22 AM   #4
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
^^^^ +1
If you re-used old manifold gaskets , here is your problem
BTW, pretty good setup for a ...NOOB
Fat Black Pig Sac is offline   Reply With Quote
Old 02-28-2011, 09:49 AM   #5
SubieBlue1
Member#: 264641
2005 WRX STI
Agree with XanRules wrt something's leaking. However, from a 16G to an FP Green with no pro-tune? Also, have you upgraded your fuel pump? Fill out your profile as we don't know what you're driving!
SubieBlue1 is offline   Reply With Quote
Old 02-28-2011, 11:28 AM   #6
XanRules
Member#: 157348
I Thlammed My
Oh god, I couldn't decipher enough of the OP to catch that.
Yeeeeeah, that's a biiiig problem.
Old 02-28-2011, 01:41 PM   #7
raggedoutsti
Member#: 255714
2005 STi
psm
Hopefully he was just trying to install everything before he took it to get tuned. With 850 I'm sure he has a fuel pump, let's not assume he's stupid yet.
raggedoutsti is offline   Reply With Quote
Old 02-28-2011, 06:01 PM   #8
SubieBlue1
Member#: 264641
2005 WRX STI
Which is why I asked the question!! Plenty of folks have made accidental "stupid mistakes".....myself included!
Old 02-28-2011, 11:03 PM   #9
subbiechronic
Member#: 275305
these are my mods, if it helps plz help lol
Cosworth CS600 Block
Cosworth S2 Cams (278intake 274Exhaust)
Forced Performance Green Turbo (3" inlet) with New SS oil line
APS DR725 FMIC
APS 70mm CAI
APS Hard Inlet Pipe
APS EL Header/Uppipe
APS 3.5" TBE
APS Race Fuel System (FRP/01)
APS TGV Deletes
ARC Titanium Pulley Cover
TurboXS Recirculating valve
Optima Red Top Battery
HKS DLI-2 Ignition amplifier
Cusco Engine and Transmission Mounts
Grimmspeed AOS
Stock Subaru Alarm
Stainless Steel Clutch Line
DW 1000CC Injectors
Walbro 255LPH Fuel Pump
PPG Straight Cut Dog Box (1-4) Stock 5th
Cobb Short Shifter
Perrin Shift Knob
Cobb Shifter Bushings
Exedy Stg1 Organic Clutch
ACT Streetlite Flywheel
AEM Triple Gauge Pod
AEM TruBoost Gauge/EBC
AEM UEGO Wideband
Greddy Oil Pressure Gauge
Old 02-28-2011, 11:17 PM   #10
XanRules
Member#: 157348
I Thlammed My
Are you tuned?
Good god almighty, is that what we're calling a n00b mod list these days?
Old 02-28-2011, 11:19 PM   #11
FkVtech
Member#: 198968
2008 WRX
RIP Soccerkid52688
For a noob, you dove head first into a rubber band ball of potential problems.
FkVtech is offline   Reply With Quote
Old 02-28-2011, 11:43 PM   #12
STirocket
Member#: 84006
2005 Impreza WRX STi
WRB with Goldies
Sounds like you've got some good hardware there, but as mentioned you need equally good software/firmware (tune) to support those mods. You mentioned having a problem after you did something to your intake. Was it running well prior to that?
STirocket is offline   Reply With Quote
Old 02-28-2011, 11:59 PM   #13
Brando5185
Member#: 189926
2000 RHD STi
First post says 850cc injectors and a Perrin front mount
Your mod list says 1000cc injectors and an APS frontmount
Doesn't add up...
Brando5185 is offline   Reply With Quote
Old 03-01-2011, 12:44 AM   #14
subbiechronic
Member#: 275305
Sorry thought I wrote the right setup on the first post, but I called my brother to send me the full list, he built the car for me
Old 03-01-2011, 12:46 AM   #15
subbiechronic
Member#: 275305
It ran perfect before I decided to take out the manifold
Old 03-01-2011, 12:55 AM   #16
Brando5185
Member#: 189926
2000 RHD STi
So you have had the 1000cc injectors the whole time? Or did you switch from the 850cc to the 1000cc because that could cause horrible idle and stalling as well if they have not been scaled.
If all you did was the manifold then it does sound like a vacumn leak somewhere.
Old 03-01-2011, 12:57 AM   #17
nattywrx
Member#: 271998
Phatbotti tuned 16GXT E85
OMG, all those mods and no tune Throw the stock intake back on and see if that helps a little.
nattywrx is offline   Reply With Quote
Old 03-01-2011, 02:30 AM   #18
subbiechronic
Member#: 275305
yes i had the 1000c all this time lol sorry im a noob,. but yes she was tuned when i had the 18g, i recently got the fp green getting tuned in 2wks, hopefully i can fix her by then. thnx for the help all
Old 03-01-2011, 02:45 AM   #19
XanRules
Member#: 157348
I Thlammed My
The leak, plus the fact that you don't have a tune, is what's causing your problems.
Jesus.
Old 03-01-2011, 03:36 AM   #20
Wunder
Member#: 260232
2005 FXT
If your brother built the car, have him fix the car. He obviously knows, judging by that mod list..
Wunder is offline   Reply With Quote
Old 03-01-2011, 04:40 AM   #21
nasiocjunkie
Member#: 80864
I'll have the tuna.
No crust.
have you tried resetting your ecu?
nasiocjunkie is offline   Reply With Quote
Old 03-01-2011, 09:09 AM   #22
army21b
Member#: 228116
1998 Forester
When i put on my manifold i had to adjust my idle up a good bit. Once i got it tuned i didnt have to. so adjust idle or get a tune
army21b is offline   Reply With Quote
Old 03-01-2011, 01:58 PM   #23
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
You should be trailering that car to the shop to get tuned and not attempting to drive it at all. Or risk a 6k motor, your choice. Pull the manifold back off, replace the gaskets, reinstall the manifold, and let the car sit until it gets tuned. I also would have gone with a larger fuel pump, but it may be too late for that now.
The Satch is offline   Reply With Quote
Old 03-01-2011, 04:24 PM   #24
subbiechronic
Member#: 275305
shoots wish my bro was here, he's all the way in the east coast and im stuck here in hawaii lol., but thnx all i will try and do all the advices u guys gave thnx again
Short Shifter Help! noob! TypeRAWR Newbies & FAQs 5 07-12-2010 12:13 AM
utec help/ noob wasey13 UTEC 12 10-29-2006 02:05 PM
sedan exhaust fit the wagon? help noob! bebop.faye Newbies & FAQs 3 08-29-2006 09:43 PM
UHhh **** noob mistake 1m4dSTI Interior & Exterior Modification 5 04-24-2006 11:44 PM
help... noob on fire jonah_walks Car Audio, Video & Security 5 11-18-2005 02:03 PM
