03-02-2008, 09:45 PM | #1 |
Member Sales Rating: (4)
Member#: 34782
Vehicle:2003 Impreza WRX Platinum Silver Metallic |
Lots of '03 WRX Parts, most of two engines
Ok, I have been planing to do some work on these engines and use some of these parts but I need to reclaim some garage space so I'm selling what I can. Pictures are below, if you would like a better picture of anything PM me. Make offers on anything, I want to get rid of this stuff. PM with offers. If there is something you need but isn't listed ask, I might have it. Almost all of this stuff will work with an 02 wrx too.
Cams (2 sets of 4, one set in heads but I'll separate) Cam gears with bolts [sold R-In and L-Ex, still have the other two] Misc timing belt idlers [sold one red one, still have the rest] Timing belt tensioner (I have two, one is a bit rusty) Clutch operating cylinder V-Belt tensioner (alternator one) A/C Compressor Crank pulley (I have two with bolts) Big bucket of hardware (mostly from engine assembly, let me know what you need) Spark plug coil packs [sold both sets] Stock uppipe (I have 3, with EGT sensors) [sold one, two left] Plastic timing covers (both front and back, most of two sets) [full set sold, have a few pieces from the other set] Misc heat shields Valve covers Green brackets of death Exhaust manifold (I have two) [sold both] Intake manifold (I have two, one had a slight fuel leak) [both sold] Cylinder heads (with valves, some are bent) [sold] Cylinder heads (from the long block which I'll remove, good valves, with cams, needs new cam seals) Short block and internals (one cylinder spun rod bearing, was running when I ripped it out) Long block (see photos, was running but leaking oil from at least one cam seal when it was removed) Stock rear sway bar Set of stock injectors (34k miles on them, you can mod em for cheap) [sold] Throttle body [sold] Intake manifold wiring Oil pump (I have two) I'm also willing to tear down the short/long block for parts if you need them. Let me know. Alternator [sold] Stock turbo charger [sold] Power steering pump with fluid tank, hoses and hard lines [sold] Water pump [threw out because it was rusty] Coolant fill tanks (I have 2) [sold both]
03-13-2008, 02:48 PM | #9 |
Member Sales Rating: (63)
Member#: 152036
E. Canada
Vehicle:2005 Sti Wrb rhd |
Exhaust manifold
are u willing to just sell the 2 ends of this and is the fitment good for a 04 sti? and how much are u looking to get |
04-01-2008, 09:01 PM | #22 |
Member Sales Rating: (49)
Member#: 36367
SWIC
Vehicle:87 Old Skool RX White |
How much for the Oil cooler and hard line.The one the oil filter mounts to and the hard line that runs right over the center exhaust manifold piece.And the Hard coolant lines
The ones circled in red Last edited by 2K4 STI; 04-01-2008 at 09:12 PM. |
SoCal: Lots of STi/WRX parts- JDM Headlights, STi parts, etc. | STIcky WRX AWD | Private 'For Sale' Classifieds | 34 | 03-26-2005 12:33 AM |
FS: Lots of used WRX parts | burt_poppenga | North West Impreza Club Forum -- NWIC | 7 | 02-29-2004 11:05 AM |
WTB: Lots of Stock WRX Parts | Soon2BturbodRS | Private 'Wanted' Classifieds | 4 | 01-06-2004 04:50 AM |
Lots of 2002 WRX parts for Sale Ebay | jccog | Private 'For Sale' Classifieds | 2 | 10-27-2003 10:01 PM |
lots of stock wrx parts | beobe99 | Tri-State Area Forum | 0 | 02-12-2002 03:17 PM |
