08-14-2002, 08:48 PM | #1 |
Member#: 8662
Vehicle:2002 WRX White |
Cold start problem..
If I start the engine when its cold it will throw a cel and it will idle rough. The idle goes up and down between 1000 and 1300 rpm. Now if I reset the ecu when the engine is still cold it dosen't go away. But if I warm up the engine and then reset the ecu the cel goes away and the car is normal.
What is happening to my car? Has this happened to anyone else? This started happening 2 days ago and it is annoying. Any help would be appreciated.. Alan
08-14-2002, 09:13 PM | #2 |
Member#: 17193
Vehicle:1991 Legacy RS White |
What mods to your car? or is it stock?
08-14-2002, 09:50 PM | #3 |
Member#: 8662
All I have is apexi intake,PDE uppipe, down pipe and HKS exhaust. Thats why I don't want to take it to the dealer. But If nobody has any ideas about whats wrong, I guess I'm forced to make it stock and battle the dealer again.
08-15-2002, 01:28 AM | #4 |
Member#: 6971
NWIC
Vehicle:2008 WRX STi SSM |
It's probably your MAF sensor, did you bump it or something while you were putting in your intake? Is your air filter oiled?
08-15-2002, 02:11 AM | #5 |
Member#: 8662
My intake has been in for over a month now and I haven't touched it since then.
08-15-2002, 03:42 AM | #6 |
Member#: 6971
NWIC
Is the filter element oiled or not? Sometimes excess oil fouls up the MAF, it doesn't matter if you've touched it lately or not. Stranger things have happend
08-15-2002, 04:36 PM | #7 |
Member#: 8662
The filter is paper but it doesn't seem oily. Is there a way to check if its the maf?
COld start problems | Sobelizard109 | New England Impreza Club Forum -- NESIC | 7 | 12-03-2002 10:25 PM |
2.2L engine cold start problems | wslk | Service & Maintenance | 13 | 10-30-2002 12:53 AM |
Cold start problems | wslk | Normally Aspirated Powertrain | 1 | 10-18-2002 11:21 PM |
Can the unichip cause cold-start problems | MARTY5446 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 23 | 01-04-2002 02:00 PM |
Cold Start Problems? | Kapwi | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 08-10-2001 04:36 PM |
