Brakes & Suspension Forum sponsored by The Tire Rack |
06-16-2009, 06:50 PM | #1 |
Member#: 134764
RMIC
Vehicle:04 sti java black pearl |
Yes another alignment thread. Experts please look.
So I got my alignment done today and I just wanted everyone to look at it. And there is some questions below.
Before Before left front___________Before Right front Camber -2.8 _______________-2.8 Caster ___5.8_______________5.6 toe_____ 0.11_______________0.06 total toe_______0.16 steer ahead____0.03 Left rear_____________Right rear Camber__-1.3_______________-2.3 toe_____0.26_______________-0.15 total toe________ 0.11 thrust angle _____0.20 After After left front___________ After Right front Camber__-2.8_______________-2.8 Caster___5.8_______________5.6 toe_____-.02_______________0.01 SAI_____16.6_______________16.8 total toe______ -0.01 steer ahead____-0.01 --------Left rear_____________Right rear Camber__-1.2 ________________-2.3 toe_____-0.02_______________-0.04 total toe_______-0.06 thrust angle____ 0.01 Why is my right rear camber so much more then my left rear and is it not adjustable? Why is my caster different? thanks my mods are RCE yellow springs whiteline anti lift kit (sport) Free caster mod Whiteline Roll center adj. GTworx Camber plates 22 rear sway 25.4 front sway kartboy endlinks.
06-16-2009, 07:45 PM | #2 |
Member#: 100271
South East
Is ride height on both rear sides the same?
06-16-2009, 09:27 PM | #3 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
yer toe is whack
get it WAY closer to '0' and you have issues in the rear....likely bent lateral link(s) forget the caster |
06-17-2009, 01:39 AM | #4 |
Member#: 29845
RMIC
Vehicle:2005 STi OBP & 1999 Forester L |
Dylan, are you still using your front camber bolts? Your rear camber is WAY off, they should be able to even it out, even though there are no camber adj bolts back there. Caster is close, seems to be a hair off on most everyone elses' numbers too.
btw, when you going coilovers?! |
06-17-2009, 01:50 AM | #5 |
Member#: 174476
NWIC
Vehicle:2002 Impreza RS BRP |
you right rear camber needs to be looked at something is hinky.
06-17-2009, 09:41 AM | #6 | |
Member#: 134764
RMIC
06-23-2009, 09:19 PM | #7 |
Member#: 134764
RMIC
So I put camber bolts in the rear top position on the right i made them go to full positive and on the left full negative and now my camber is like -3 on the left and -.5 on the right
Can I adjust the camber with the bolts by rotating them? Or are they going to slip? Also do I need to rotate the washer when I move the bolt? I read the camber bolt sticky and it doesn't say anything about it in there about dialing in camber with them. |
06-24-2009, 11:57 AM | #8 |
Member#: 134764
RMIC
bump for some help
06-24-2009, 12:11 PM | #9 |
Member#: 141040
BAIC
Vehicle:07 2.5i wagon UGM |
Something is bent. Take all the crash bolts out, put the stock bolts in, then figure out which, if not both, of the left rear lateral links is bent. Replace it.
Have you hit anything while doing donuts? |
06-24-2009, 07:26 PM | #10 |
Member#: 134764
RMIC
I've never hit anything. And I looked under the car and could not see any bent lateral links or the sub frame everything looks strait. But no there is like 1/4" clearance between my strut and wheel on the left side and about an 1" on the right cause of the camber bolts. Is there anyway to adjust camber without the crash bolts??
06-25-2009, 06:30 AM | #11 |
Member#: 120463
rear subframe off centre?
install some subframe lock bolts to true it up |
06-25-2009, 09:29 AM | #12 |
Member#: 134764
RMIC
I have some already.
Check my alignment specs...Experts please! | azscooby | Brakes, Steering & Suspension | 36 | 12-12-2009 06:35 PM |
Yes...yet another alignment thread | Mr_Snips | Brakes, Steering & Suspension | 1 | 02-29-2008 07:48 PM |
Alright who can help me with an exhaust?? YES ANOTHER EXHAUST THREAD!! | Silver on Blacks | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 14 | 10-09-2005 12:16 AM |
M1 Garand What do you know about it: yes another gun thread... | scottjua | Off-Topic | 49 | 11-12-2003 04:21 PM |
Gun people - Kimber Pro Tac II, or HK USP compact??? Yes, ANOTHER gun thread..... | Subasaurus Rex | Off-Topic | 9 | 11-11-2003 11:24 PM |
