Tire & Wheel Forum sponsored by The Tire Rack |
07-31-2003, 11:23 AM | #1 |
Member#: 7446
Vehicle:2002 Impreza RS 2009 Forester Limited |
Effect of wider wheel? (same diameter and weight)
I'm looking at getting the ASA LW5 wheels in 16x7.5. The weight on these is 16.3 lbs vs. 16.5 (I've heard) for the stockers.
My question is: will the wider rim increase rotational inertia the same way that a taller (i.e 17/18") wheel would? I'd like to avoid too much resistance if at all possible seeing as how my car came without one of those turbo-thingies. Thank you! ~Paul
07-31-2003, 09:25 PM | #2 |
Member#: 30039
Vehicle:2002 wrx wagon dirt slvr |
no
07-31-2003, 11:01 PM | #3 |
Member#: 3841
Vehicle:2004 WRX Wagon UTEC+VF22+WI |
You're oversimplifying it. Two wheels of the same weight can have that weight located in different places. It's perfectly conceivable that two wheels that are the exact same width, diameter, and weight, could have drastically different rotating inertia because of where the weight is located. There's really no way of knowing unless you're talking about multi-piece wheels and you can weigh the seperate pieces. However, I think you can assume that for a "normal" wheel the difference will be very, very small by adding an inch of width.
08-01-2003, 10:03 AM | #4 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
there will be very little if any changes in the rotational interia of the 2 wheels in question .... now, if you were Mario Andretti in one of those F1 type cars you might feel some sort of difference or might not ... I wouldn't worry about it ....... pull the trigger and enjoy your better looking bhetter performing new wheels and get a set of 225/50-16's to go with them
wheel linky |
Similar Threads | ||||
effects of varying intake pipe diameter? (pre and post turbo) | happasaiyan | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 31 | 12-24-2019 04:48 PM |
want to know effect of wider trackwidth with steelies | eraser_rx | Brakes, Steering & Suspension | 3 | 06-16-2009 09:46 PM |
new wheels same diameter, do i need alignment? | NorCalSubie07 | Brakes, Steering & Suspension | 12 | 06-12-2008 02:17 PM |
Calculating the effects of larger wheels and tires, and loss in performance | Yoo Shin | General Community | 25 | 10-10-2007 09:51 AM |
Effect of different wheel/tire sizes on roller dyno's | mynew02 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 10-22-2002 11:49 PM |
