10-24-2002, 11:43 AM | #1 |
Member#: 8808
NESIC
Vehicle:2011 WRX DGM 5D |
100/80W HB5 bulbs with stock harness?
North Ursalia indicated to me that the 100/80W bulbs from Hella and such should work just fine in the stock WRX headlamp harness without melting.
Has anyone tried this? Thanks, /Andrew
10-24-2002, 12:11 PM | #2 |
Member#: 333
NESIC
Vehicle:98 not a Leg 2.5GT Quicksilver Metallic |
Whassa matta you?? Don't trust his advice???
10-24-2002, 12:14 PM | #3 |
Member#: 437
NESIC
I'd say "no". The stock WRX headlights are plastic, not glass.
That would concern me, and I haven't heard of anyone using a stock harness with those wattages. Maybe 65W/100W, but 80W/100W is pretty risky. Pau G. <--aren't you an electircal engineer? |
10-24-2002, 12:16 PM | #4 | |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
No I have no first-hand experience with it.
What's "should" being based on there? Nothing? Something? He didn't seem too sure 8 months ago Quote:
<Now everyone can commence "Jeff has a vendetta against North Ursalia" speculation and stupidity> EDIT: Fixed "Np" to be "No" Last edited by jblaine; 10-24-2002 at 12:47 PM. |
10-24-2002, 12:31 PM | #5 |
Member#: 8808
NESIC
He said that he's been running the 100/80s in the Morettes for a while, and he certainly doesn't do that "turning-off" thing anymore, so perhaps his confidence level has gone up.
A lot of people on here are running with the 100/80s, and there are a few reports of melted harnesses... it seems to be a luck-of-the-draw kind of thing, unfortunately. It also seems that the people melting harnesses are using no-name 100/80s, versus name-brand (like Hella). The 100/65s will still be dissipating 100W on high-beam, so if anything is going to melt the harness, the 100 on either the 100/65 or 100/80 will do it. The headlamp fuse also won't go at 100/80, which leads me to believe that Subaru's engineers end-to-end certified the circuit for the fuse level. Hmm. Thanks for the tips, folks... /Andrew |
10-24-2002, 12:38 PM | #6 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
I don't know the issues with the plastic, but you can add in a relay for at least the high beams, or 2 to include the low and your own power from the battery, fused, then to the headlights. I regularly do this on my cars to make hi, lo and fogs come on with the high beams. I use 12AWG wire. Way overkill, but I have the wire anyways.
Check the size of the headlight fuse. Fuses are generally rated twice the expected current rating. Now take 100W/12V for 8.33A. Double that to about 17A. If the fuse is smaller than 17, use a relay. jack |
10-24-2002, 12:48 PM | #7 |
Member#: 8512
South East
That's another thing to consider, Andrew -- what Jack mentioned, but more generally just getting better harnesses altogether. I have to believe they can be had from somewhere or made(?).
Oh, I also agree that it seems hit or miss. That, to me, might as well be 100% "miss" though. Not something I'd gamble on. But by all means, feel free to let us all know how it goes Last edited by jblaine; 10-24-2002 at 12:53 PM. |
10-24-2002, 12:53 PM | #8 |
Member#: 8808
NESIC
Yeah, I know. But it starts getting spendy at that point. I'm basically trying to compute how much I can get away with in the stock harness... it appears that the wiring is in the ballpark of 14-16AWG, which should be enough for 8.3A...
I'm mainly looking for the experiences of other locals with the higher-wattage bulbs in the stock harness, more than look for a specific solution for myself. /Andrew |
10-24-2002, 01:00 PM | #9 |
Member#: 3102
NESIC
Vehicle:2018 Mazda CX-5 Storm Trooper White |
Well... 100/80 Hellas melted my harnesses
I upgraded to a generic Pep Boys harness for $3.99 each and have not had any problems with my new 130 / 100 watt lights *Yup, I'm that ******* who blinds you at night* Bry. |
10-24-2002, 01:07 PM | #10 | |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
Brian |
10-25-2002, 09:09 AM | #11 |
Member#: 3800
Vehicle:2002 WRB WRX Sedan 2011 Sky Blue Forester Pr |
I have Hella Optilux 100/80 in the headlamps and yes, I melted, fried, burnt up one of the stock connectors. The wiring was intact but the plug the bulb plugged into looked like someone took an oxyacetylene torch to it. This happened about 3 weeks into it. I replaced it with an aftermarket plug from Advance Autoparts and it's been fine ever since. I also have 100 watters in the fogs and have had no problems with them. But then again, I don't use them unless really necessary.
Wilkey Note: I've been running 100/80s in the Forester for almost two years without incident. |
10-25-2002, 10:33 AM | #12 |
Member#: 2278
NESIC
Vehicle:8Sti | 07 allez White | Comp |
how does one go about replacing the harness? is it straight forward?
AO |
10-25-2002, 10:41 AM | #13 |
Member#: 8808
NESIC
Sweet. I'm ordering them today. If I melt the connector, I don't care, I'll just get another one, and I can always rewire.
Crimpers don't scare me. /Andrew |
10-26-2002, 04:45 AM | #14 |
Member#: 2200
NWIC
Vehicle:2015 Mazda 3 97 Miata, 96 Landcruiser |
I tired 55/100's in mine for about a day. When I would switch to high beam, it would take about a second for the lights to get to full intensity. It looked like it was struggleing to put out the 100W. Took them out.
Curt |
10-27-2002, 10:05 AM | #15 |
Member#: 3800
Aaron,
The harness looks to be a bear. Although I've read that a dealership can replace the whole "Front Wiring Harness" in about 30 minutes. There are 43 connectors on that harness of which two are headlamp, two are turn signal, two turn indicators and two foglamps. I would not mess especially since a lot of it is taped up and in plastic convolute (lflex-loom). The three wires coming out of each connector are easy to splice using 3M weathertite connectors but that still leaves the rest of the wiring running back to the high beam relays, DRL relays, dimmer switches and other stuff. I wouldn't want to mess. Don't aftermarket lights use relays wired directly to the battery? Sorta like the Hella Supertone horns? Wilkey |
FS: 9007 100/80W Headlight Bulbs | Flesher | Private 'For Sale' Classifieds | 0 | 06-27-2005 07:07 PM |
Xenon lamps 9007 12v 100/80w - Help? | Infymus | Electrical & Lighting | 4 | 02-02-2003 06:54 AM |
Review of Hella 100/80W light bulb | hkwan | Interior & Exterior Modification | 33 | 12-04-2002 11:27 AM |
9007 100/80w hyper-white bulbs on ebay - safe? | WRXVII | Interior & Exterior Modification | 2 | 03-24-2002 07:21 AM |
need help with stock harness | merlin8019 | Car Audio, Video & Security | 6 | 08-20-2000 10:30 PM |
