04-21-2010, 11:06 PM | #1 |
Member#: 215239
Laminovia Oil Coolers
Anyone using these water to oil coolers? Results good or bad?
04-22-2010, 12:26 PM | #2 |
Member#: 80524
i got 4 cores here sitting for over 2 years.. couldnt get around the fact that i needed a huge heat exchanger... i have a design (on paper) where you integrate the cores into the STi intake manifold, pretty cool but no testing yet..air to air does the job well for us. Do some search on the off road forums, there are guys who are running these already..but they dont reach the speeds we do on hi speed tracks.
04-22-2010, 03:25 PM | #3 | |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
I've never used a Laminova personally, but from what I've read they seem to be very effective. Assuming, of course, that your coolant system has the capacity to handle the added heat load. Pat Olsen |
04-22-2010, 03:54 PM | #4 | |
Member#: 80524
04-22-2010, 02:15 PM | #5 |
Member#: 98961
MAIC
Vehicle:2003 WRX Black |
Why not just use the water lines from the existing oil cooler? I've been thinking about using one for my M3 but, it doesn't really have a natural hookup point like the STI/WRX does. I'd probably have to use the heater lines and have to remove the heater control valve or maybe the throttle body heater circuit might work too.
04-22-2010, 03:24 PM | #6 | |
Member#: 80524
laminova is very tempting but i just cant think of a good enough reason to do the setup..maybe if i was a drag racer |
Similar Threads | ||||
oil cooler issue | 06D | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 06-07-2010 04:26 AM |
Top mount Oil cooler/tran cooler | ColesSTi | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 08-31-2006 08:10 AM |
Leaking Oil from oil filter/oil cooler | AustinSTi | Normally Aspirated Powertrain | 3 | 01-08-2004 12:42 AM |
Where are my oil cooler and trans cooler located at? | Hit Man X | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 10-28-2002 09:40 AM |
spark plugs, oil coolers, transmission coolers, upgraded radiator, who has them? | ChristophWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 06-04-2002 12:48 AM |
