06-28-2002, 12:02 AM | #1 |
Member#: 20617
Vehicle:2002 2.5RS Impreza blue |
Engine Misfiring & Starting Hesit.ATTN Nick
I bought an 2002 Impreza last August. I filed for Arbitration because an ASE Cert. Mechanic told me I had Engine Misfiring problem and starting hesitation. SOA gave me a new Impreza in April. Low and be-hold, the new vehicle has the same problems. The vehicle has 2,500 miles on it and the dealership won't take it back. I am having to videotape the problems as they occur intermittently. Anyone else hear the "popping" sound, which is the engine misfiring? How about starting hesitation? Thanks for any and all replies.
06-28-2002, 11:53 AM | #2 |
Member#: 13767
Vehicle:2010 JCW Clubman SIlver |
when does your engine pop?
if it's during acceleration above 5k rpm then i have the same problem.. -=GuS=- |
07-21-2002, 10:18 PM | #3 |
Member#: 10706
Vehicle:2005 STI |
YES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
Ahhhh!!!! I have the same problem. My WRX misfires on all cyclinders intermitantly. I have taken the car into the dealership four times now. It is so bad that the car is nearly undrivable, the car drops from having 227 hp to about 50hp. Then the car starts smoking and fills the air with a strong smell exhaust and gasoline.
They had a rep from SOA out to look at it, but the car was not suffering from the problem when the rep came to look at it. They just replaced the MAF but it did no good. celer |
07-22-2002, 06:52 PM | #4 |
Member#: 17187
BAIC
Vehicle:2009 Braun Entervan Gimpy White |
My car is starting to hesitate upon initial acceleration from just after it starts up then then even after it is warm....Should I be worried?
07-22-2002, 11:12 PM | #5 | |
Member#: 10706
Vehicle:2005 STI |
It could be the summer heat and your intercooler not getting much a chance to cool down. celer |
07-22-2002, 11:46 PM | #6 |
Member#: 456
NWIC
Vehicle:2008 Forester XT Steel Gray Metallic |
If your car is exhibiting these systems most likely the MIL (Check Engine Light) would be lit and it would store the misfire info.
Any CELs here? |
07-24-2002, 12:35 PM | #7 |
Member#: 12818
Starting hesitation
I'm not sure if it exactly the same problem but my WRX that I've had for 5 months has always hesitated starting or taken a longer time to crank to start than any other car.
07-24-2002, 01:24 PM | #8 | |
Member#: 10706
Vehicle:2005 STI |
Re: Starting hesitation
07-25-2002, 10:35 AM | #9 | |
Member#: 13767
and it blinks often too. -=GuS=- |
07-25-2002, 10:51 AM | #10 |
Member#: 456
NWIC
Have you pulled the trouble codes and if so what are they?
07-25-2002, 02:56 PM | #11 |
Member#: 13767
there are probably more but so far:
misfire in 1, 2, 3 and 4 cam position sensor and crank position sensor. changed the cam position sensor and the CEL blinks alot more. will prolly change crank sensor next. only mods are HKS TT and SPT (STi) axle back muffler. new air filter (oem) and fuel filter (oem). -=GuS=- you can here the misfire at about 5200rpm at WOT. |
08-06-2002, 01:14 PM | #12 |
Member#: 11926
Vehicle:2011 Outback Limited Dark Grey |
anyone seen this issue
Start the car and it makes a clank like it started in the exhaust stroke and you slowly hit accelerator and it feels like a vibration (like motor is not firing on all 4) Real unbalanced accompanied by funky idle?
(Halp!) Engine cutout & dies intermittently along with hot start issue | DinoGuan | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 03-30-2010 06:30 PM |
vehical started hesitating | xxsive25 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 01-09-2004 02:50 PM |
1000mi WRX starting hesitation | Frederf | Service & Maintenance | 2 | 10-19-2002 05:59 PM |
