05-20-2008, 11:52 PM | #1 |
Member#: 177726
Vehicle:2005 WRX (STI TRANS) Blue |
STI clutch VS WRX clutch
So i am trying to do a swap, putting the STI into my WRX. Everywhere i read it says i need the 6 speed clutch and flywheel to do the swap.
My question is WHY???? The clutch in my car is in good shape, and i cant see what the differences are between the two. I have the 6 speed one, and it looks to me like its in much worse shape than mine is. So if i dont HAVE to change them, i would much rather not.
05-21-2008, 01:18 AM | #2 |
Member#: 141517
SWIC
Vehicle:02 WRX Now AW 2016 Forester XT |
what year is ur car? if its an 02-05 then u should be fine using the wrx clutch they are the same style as the sti its just the sti clutch and flywheel are alittle bigger in diameter
05-21-2008, 01:29 AM | #3 |
Member#: 177726
my car is an 05 and the transmission is an 06
05-21-2008, 07:03 AM | #4 |
Big Ron
Super Moderator Member#: 18062
You don't NEED at 6MT clutch now as long as your 5MT one will hold your torque level. When you upgrade though, you should swap over to the 6MT stuff though.
05-22-2008, 01:10 AM | #5 |
Member#: 146819
NESIC
Vehicle:'02 WRB VF-39'd WRX W/06 STi Drivetrain swap |
clutch and flywheel not needed, shift fork and slave cylinder will be needed.
05-22-2008, 01:28 AM | #6 |
Member#: 15543
Vehicle:555 Having a Subaru shop means too many cars |
Any reason to not use the STI clutch? I had the two side by side recently and I can't see anyone intentionally choosing the WRX unit except the flywheel might be lighter.
act clutch vs exedy clutch | gi2005 | Transmission (AT/MT) & Driveline | 27 | 07-29-2007 09:50 PM |
STI clutch vs WRX clutch | d40winker | Transmission (AT/MT) & Driveline | 1 | 01-23-2007 05:02 PM |
STi vs. WRX clutch/cover | MarkRx | Transmission (AT/MT) & Driveline | 5 | 01-21-2004 08:56 PM |
button clutch vs regular clutch | baldcherub | Transmission (AT/MT) & Driveline | 3 | 12-14-2001 11:28 PM |
