11-25-2008, 09:27 PM | #1 |
Member#: 21481
NESIC
Vehicle:99 2.5RS 14 Impreza STI |
Bad battery terminal. P0340 Camshaft position sensor circuit malfunction. Related?
For the past year, my car has shut off at random every 3 months only to start up within an hour or so and run fine for another 3 months. Every time it resets the ECU, but the last two times I managed to get the code from a CEL mentioned in the title before it disappeared.
This weekend it did not start back up, until just now when I reconnected the negative battery terminal. Could this be related to the CEL I got? Or do I have two separate problems? Lastly, is it possible to have a perfectly fine looking battery terminal + connector thingy and still have it reduce the dependability of the car to 98% (like I said, runs solid between instances)? TIA, Robert PS - car is a 97 L 2.2 |
11-25-2008, 09:34 PM | #2 |
Member#: 32338
E. Canada
Vehicle:2012 WRX |
I had an issue with mine last winter. I thought my battery was going bad - randomly, it wouldn't start unless I jumped it, and after trying, the battery would appear to be dead. I had checked that the terminals were tight, and couldn't figure out what it was. Finally pulled the terminals off, and they were fairly corroded. Cleaned them up with some battery post cleaner and a scotch bright pad, and it started fine after that.
So yeah, I would guess it's possible |
Similar Threads | ||||
PO325 Knock sensor circuit malfunction | Art Hazebrook | Service & Maintenance | 6 | 08-20-2007 05:27 PM |
Can camshaft position sensors go bad? | scooterforever | Service & Maintenance | 6 | 07-07-2006 09:39 PM |
So what the hell is a P1101 "Neutral Position Switch Circuit Malfunction (M/T)"??? | obyone | Mid West Subaru Owners Club Forum -- MWSOC | 17 | 06-08-2006 12:52 AM |
I just got P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) | tmat3 | Normally Aspirated Powertrain | 18 | 03-03-2002 02:25 PM |
OBD code P0340 - Camshaft Position... | bobgrice | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 23 | 12-31-2001 09:28 PM |
