Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 06-02-2006, 02:41 AM   #1
obyone
Member#: 16523
Default So what the hell is a P1101 "Neutral Position Switch Circuit Malfunction (M/T)"???
Had my CEL checked and it read: P1101 "Neutral Position Switch Circuit Malfunction (M/T)"
Soooo...what does that mean? Emission time is comming up and I needs to get it fixed.
obyone is offline   Reply With Quote
Old 06-02-2006, 02:43 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
i dunno but i threw the same code after i did my swap. Check to see if you are leaking any trans fluid from around the switch, i have a feeling the switches go bad internally and actually cause the trans to leak. I have to look into fixing mine but with the swap it's a P0851
Old 06-02-2006, 04:09 AM   #3
nate49509
Member#: 22452
2018 STi
Not really much on this board about that code. Seems to be a rare one. I'd bet it's just a bad sensor or maybe a loose connector.
nate49509 is offline   Reply With Quote
Old 06-02-2006, 08:31 AM   #4
WR^2X
Member#: 37617
Start driving, set your cruise control, and shift into neutral (when you press the clutch in, the cruise control will disengage - but should still be on) Now try to resume cruise control. This should not work. If it does, there's a problem with your neutral position switch.
Mine broke once and then magically started working again.
And I am 99% sure they're impossible to replace without dropping the transmission. At least on the 6 speed.
WR^2X is offline   Reply With Quote
Old 06-02-2006, 11:33 PM   #5
obyone
Member#: 16523
Oh god I sure hope not! Luckly, I have a 00 RS 5spd.
Old 06-03-2006, 12:46 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
on the 5mt's they are on the side of the trans
Old 06-03-2006, 11:29 AM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Did you have a remote start installed? If so, maybe some bad wiring there wore through and pulled it out of a switch or something.
I think you can pass OBD-II tests with that code thrown, though... it has nothing to do with emissions and all those tests should be passed. That is unless they decided that they don't even want to hook up any car with a CEL period (which IMO is just wrong since a CEL can be thrown for non-emissions related items).
Old 06-07-2006, 12:19 AM   #8
obyone
Member#: 16523
That's Illinois for you. From what I remember, they won't even bother if they see the light on.
BTW...I did have a Remote start installed and I guess it makes sense since the gear shift safety has failed in the past months.....I umm...found my car on the front lawn after trying to remote start it one time.
Old 06-07-2006, 02:32 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
if there are any codes stored the vehicle is rejected, which as you personally said is rediculous since the code is a non-emissions efecting componet
Old 06-07-2006, 09:32 AM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Yup, sounds like you need to find/replace that switch. Now for two reasons... emissions, and keeping your car off your lawn.
Old 06-07-2006, 10:05 AM   #11
explicithero
Member#: 15893
2004 STi
The color of the burgh
I did a swap and I am throwing the 0851 code. I am not leakin ne fluid. I haven't installed the dccd could that b the issue. I also don't have cruise control bc I disconnected and pulled it out.
explicithero is offline   Reply With Quote
Old 06-07-2006, 11:48 AM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
nope because that's the VERY same code i throw now since i have done my swap, i am wondering if the WRX/RS switches are slightly different
Old 06-07-2006, 12:05 PM   #13
explicithero
Member#: 15893
2004 STi
I'm running a 6spd in a wrx wagon. so u think its a bad sensor?
Old 06-07-2006, 12:06 PM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
oh, so you are running a 6mt, i am running a 5mt with a WRX ECu, but i throw that same code
Old 06-07-2006, 12:17 PM   #15
explicithero
Member#: 15893
2004 STi
oh crap . well looks like I'm up the creek. I will have to get on the horn
Old 06-07-2006, 04:01 PM   #16
eddy@cc-b
Member#: 11614
2009 nothing, really
bland
Were you short on letters when you wrote this?
eddy@cc-b is offline   Reply With Quote
Old 06-07-2006, 04:08 PM   #17
explicithero
Member#: 15893
2004 STi
I was actually writing it on a treo 650 in the middle of a meeting.
Old 06-08-2006, 12:52 AM   #18
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
i wonder if maybe not having the cruise control plugged in has something to do with it, because mine is unplugged as well
What the hell is wheatgrass, and why is it so expensive? plunk10 Off-Topic 16 03-27-2008 10:15 PM
What the HELL is America thinking!? Tara Conner (Not Sarah Conna') is not hot!!! brucelee Off-Topic 31 08-29-2007 12:01 AM
So what the hell did the dealer do to my car? Please help. Louros Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 10-22-2004 12:18 AM
So who the hell is the guy I keep waving to on RT.100? STR8OUT Tri-State Area Forum 6 08-23-2002 12:23 PM
so many sightings! what the hell is happening! KillerTHC Bay Area Impreza Club Forum -- BAIC 14 09-22-2001 12:47 AM
