12-28-2007, 03:14 PM | #1 |
Vendor Sales Rating: (30)
Member#: 54202
Vehicle:ASK ABOUT NEW RCE SWAY BARS FOR STI |
Racecomp Engineering Suspension and Brake Parts!!!
Racecomp Engineering Suspension and Brake Parts Racecomp Engineering has developed the following parts for the Subaru Impreza, Subaru Legacy, and Mitsubishi Lancer Evolution. After emerging as an exceptional knowledge resource for Impreza suspension applications through years of first hand experience with nearly every suspension option available for the Subaru Impreza and Mitsubishi Evolution, Racecomp Engineering can now provide their own solutions that truly caters to the core of Subaru track day and race enthusiasts. Racecomp Engineering/GTWORX.com 6360 Suite J South Hanover Rd. Elkridge, Maryland21075 410-579-1501 – [email protected] __________________________________________ Racecomp Engineering Tarmac Coilovers Racecomp Engineering Tarmac II Coilovers for Subaru Impreza Racecomp Engineering Tarmac 2 coilovers are comprised of stainless steel dampers mated to linear race springs, incorporating a 2 way design with separate compression and rebound adjustments, motorsports level spring rates, composite locking perches with safety perches added, piggyback reservoirs on all front dampers, and will feature a limited lifetime warranty. Racecomp Engineering chose KW Suspension to co-brand the Tarmac 2 coilovers due to their remarkable racing heritage, consistent and impressive build quality, and phenomenal presence and support in the United States. Racecomp is happy to announce the option of having the RCE Tarmac 2 coilovers fully assembled with either Group N strut top mounts or RCE Camber Plates and Rear Pillowball mounts. Available for: 2002 - 2007 Subaru Impreza STI, WRX sedan, WRX Wagon, and 2.5RS 1993 - 2001 Subaru Impreza Coupe, Sedan, and Wagon $1899 shipped With Group N strut top mounts front and rear - $2299 shipped With RCE Camber Plates and RCE Rear Pillowball Mounts - $2749 shipped __________________________________________ Racecomp Engineering Tarmac I Coilovers for Subaru Legacy Following the successful release of our coilovers for Subaru Impreza, Racecomp Engineering decided to extend their coilover line to include 2005+ Subaru Legacy. Featuring the same stainless steel technology, limited lifetime warranty, and KW quality as the Tarmac II’s, these coilovers were designed with linear spring rates and valving that mates perfectly for the Subaru Legacy street/track driver. Available for: 2005 - 2008 Subaru Legacy GT, Spec B, and 2.5i Sedan and Wagon $1399 shipped! __________________ Call us for an appointment for installation www.racecompengineering.com --- www.GTWORX.com Cobb - Swift – Whiteline - Cusco - Alpinestars - Prodrive Ohlins - Moton - KW - Bilstein - STi - Pagid - Ferodo - Piloti Racecomp Engineering www.racecompengineering.com 6360 Unit J South Hanover Rd. Elkridge, Maryland 21075 410-579-1501 Phone 443-370-9000 Mobile
12-28-2007, 03:15 PM | #2 |
Member#: 54202
Racecomp Engineering Lowering Springs Line-up __________________________________ Yellow for STi Rates Front - 295 lbs/in Rear - 275 lbs/in Drop Front - 23 mm Rear - 20 mm $339 shipped _________________________________________________ Regular Guy “RCE Blacks” for STi Rates Front - 285 lbs/in Rear - 269 lbs/in Drop Front - 15 mm Rear - 10 mm $339 shipped _________________________________________________ WRX Wagon Rates Front - 278 lbs/in Rear - 259 lbs/in Drop Front - 28 mm (from WRX height) Rear - 24 mm (from WRX height) $339 shipped |
12-28-2007, 03:16 PM | #3 |
Member#: 54202
Racecomp Engineering Camber Plates and Pillowballs __________________________________ Racecomp Engineering Lowering Camber Plates These front camber plates were designed to be used with a conventional spring, lowering spring or coilover. Made of aircraft grade T6 7075 alloy, these units alow up to -3 degrees camber. These come anodized in motorsport gold and work very well with lowering springs as they lower any car by 3/8" WITHOUT sacrificing suspension travel. Available for: 2002 - 2007 Subaru Impreza WRX, STi, and 2.5RS $449 shipped __________________________________ Racecomp Engineering Non-Lowering Camber Plates These front camber platers were designed to be used with a conventional spring, lowering spring or coilover. Made of aircraft grade T6 7075 alloy, these units alow up to -3 degrees camber. These come anodized in motorsport gold and work very well with lowering springs. These do not lower or raise the car, and DO NOT sacrifice suspension travel. Available for: 2002 - 2007 Subaru Impreza WRX, STi, and 2.5RS $449 shipped __________________________________ Racecomp Engineering Rear Pillowball Mounts for Impreza Made with the highest quality available aircraft grade 7075 T651 aluminum and using a new extra heavy duty spherical bearing, these pillowball mounts will be up to the task of both heavy track and street duty. These solid mounts provide quicker reactions, more feedback, and a more direct feel from your suspension. Our Rear Pillowball Mounts were developed specifically to provide a solution for Racecomp Engineering Tarmac II coilover users looking for the maximum possible performance out of their coilover system. Available for: 2002 - 2007 Subaru Impreza WRX, STi, and 2.5RS. Fits coilovers only. $339 shipped Last edited by RaceComp Engineering; 01-24-2008 at 11:39 AM. |
12-28-2007, 03:17 PM | #4 |
Member#: 54202
Racecomp Engineering Brake Parts ___________________________ Racecomp Engineering CARBON FIBER Kool Brake Kit Reduce rotor temperatures by ducting air to the center of the rotors. Comes with two brake ducts, two 300 degree temp duct hosing and 2 stainless steel hose clamps. Available for: 2004 - 2007 Subaru Impreza STi Coming soon for 08+ WRX and STi Special INTRO ONLY Price - $339 ____________________________________ Racecomp Engineering/GTWORX.com 6360 Suite J South Hanover Rd. Elkridge, Maryland21075 410-579-1501 [email protected] Last edited by RaceComp Engineering; 01-29-2008 at 04:48 PM. |
12-31-2007, 05:30 PM | #7 |
Member Sales Rating: (110)
Member#: 144779
Vehicle:200X ZOMG a car 100% crabon fibre girlfrendorz |
Would it be possible to run the brake ducting kits utilizing the fog light location (without the black scoops included in the kit)?
01-02-2008, 11:54 AM | #9 | |
Member#: 54202
- Andrew |
01-03-2008, 11:44 AM | #11 |
Member#: 54202
Variant 1's are only adjustable for height. Great for a street car and if you don't plan on messing with too many settings. They come preset for great handling and ride quality. They still rock on the track.
Variant 3's are height adjustable, but they also have seperate adjustments for compression and rebound. So basically, you can tune these to behave the way you want them to. Can be a bit complicated, and overkill for a street car. But you can get great handling and ride quality out of them if you play with it. Let me know if you have any questions! - Andrew |
01-14-2008, 04:15 PM | #16 |
Member Sales Rating: (2)
Member#: 18619
South East
Vehicle:'02 WRX Black |
I don't suppose the wagon specific springs work well with stock struts?
I've got an 05 wagon, which seems to have limited aftermarket strut options. |
01-15-2008, 10:28 AM | #17 |
Member#: 54202
They don't....you definitely want to upgrade to Konis. You can get Tokico D Specs and get some camber bolts to correct the wagon differences.
Koni's are the best way to go though. - Andrew |
01-18-2008, 06:25 PM | #21 |
Member#: 83952
NWIC
Vehicle:2004 Stg 2 Wagon JBP 1990 Turbo Miata |
What to get
Finally decided to snag some suspension but I cant decide between KW V3's or your RCE Tarmac II's, what would you say the differences are as well as + and -'s of both. I've got an 04 WRX sport wagon if that makes any difference. looking for any help i can get, feel free to PM me if you would like.
Thanks Gary |
Cheap Suspension and Brake Parts. Hawk, Brake Quip, Monroe, Kartboy. | roofis | Suspension/Brakes/Handling | 11 | 12-23-2009 12:52 AM |
FS: OH 2003 WRX Suspension and brakes part-out | Joe_M | Suspension/Brakes/Handling | 1 | 07-05-2007 10:39 PM |
22b suede steering wheel and other suspension and brakes parts...... | RaceComp Engineering | Brakes, Steering & Suspension | 10 | 11-11-2006 11:00 AM |
Suspension and Brake Parts for Sale | SpeedElement | Private 'For Sale' Classifieds | 14 | 02-05-2005 12:00 PM |
