06-02-2003, 11:42 PM | #1 |
Member#: 18466
Vehicle:2003 GT35r Evo VIII 10.402@138 |
02 2.5RS seats in 2000 2.5RS? (GDB IN GC8?)
ANYONE DONE THIS?
how complicated is it? How long will it take an average person and what do i do? ERIK
06-03-2003, 12:59 AM | #2 |
Member#: 24827
Vehicle:2008 Kia Spectra |
Well logically I would assume they'd just bolt right in. I mean, if the v7 seats will bolt right into a GDB and the v7 seats will bolt right into a GC8, then i'd assume GDB's would bolt into a GC8.
06-03-2003, 04:21 AM | #3 |
Member#: 8877
NWIC
Vehicle:2000 Impreza 2.5RS (sept '01-jan '04) |
Yes it will fit, it's 4 bolts per seat. Plan on spending between 15-50 minutes. I think the bolt is 14mm? maybe 15mm?
-s- |
06-03-2003, 08:05 AM | #4 |
Member#: 733
Vehicle:'18 WRX Frozen White |
Yes they fit...
There are only a few visual thing that aren't 100% with the rear seat swap: 1) Door panels don't match seat pattern...duh. 2) The "gap" in the seat bottom. 3) There is a space between the seat back and the package tray that you can see the seat foam when you look into the car from the back window. 4) The upper sides of the seat back are sorta wedged into the sides since it's a bit narrower on the GC. I don't have the cargo passthrough working because I couldn't get the parts needed before the donor WRX had to be taken away. The front seats swap w/o much hassle. For F R double E, this was the bestest mod I've do to my car so far. -mykr. |
06-04-2003, 04:21 AM | #5 | |
Member#: 6489
Vehicle:01' GM6 Black |
Re: Yes they fit...
I don't get it. What parts do you need to get the passthrough working? I thought it's just a simple openning and wahlah, there is the rear trunk space.
06-04-2003, 05:52 AM | #6 | |
Member#: 733
Re: Re: Yes they fit...
The sound deadening material (corrugated plastic panel and felt/rubber pad) are also different due to the passthrough. I couldn't get these item off the donor WRX in time to make it work properly and I didn't want to sacrifice the noise levels in my car to just pull the sound deadening to use the passthrough. I've got a nice armrest back there now. If I ever take my Scooby to go snowboarding I'll just get a roof rack anyway. -mykr. |
STi seats into 2000 2.5RS | eastcoastGC8G | Subaru Conversions | 6 | 12-02-2009 11:15 AM |
WTT: 05 WRX seats w/ black seats for 2000 2.5RS | fusionchicken | SCIC Private Classifieds | 21 | 04-23-2008 08:57 PM |
will sti type ra gear set fit in 2000 2.5rs | billyr2.5 | Transmission (AT/MT) & Driveline | 2 | 04-02-2004 08:36 AM |
WRX IC fitment in 2000 2.5RS | AntonioS | Normally Aspirated with bolt-on Forced Induction Powertrain | 2 | 09-10-2003 07:12 PM |
Any Interest in 2000 2.5RS seats? | WRSport | Bay Area Impreza Club Forum -- BAIC | 2 | 11-25-2001 02:32 AM |
