Brakes & Suspension Forum sponsored by The Tire Rack |
08-14-2001, 02:06 PM | #1 |
Member#: 9160
Vehicle:2002 Impreza 2.5RS Platinum Silver |
MY02 Ride Height Variance???
I have owned my 02 RS for less than 2 months and love driving it every day since I got it off the truck. I have noticed that my drivers side ride height is lower than the passenger side. Upon closer inspection, I have measured a .5 to 1 cm difference on both the front and rear (on various level surfaces). I know my tire pressures are all equal @37 PSI.
Is this an engineering design of the car possibly to counter the rotational torqe of the engine / driveshafts? There are no adverse effects to straight line stability or cornering. As a matter of fact I am very pleased with the handling in stock form but I do have plans on upgrading soon. If given the choice what would be the best first upgrade to handling PERFORMANCE: strut bar, sway bar (front or rear), lowering springs???? I am not a speed demon but I LOVE to corner at high speeds and get sideways with the throttle. Any suggestions or comments on my problem would be most appreciated.
08-14-2001, 04:37 PM | #2 |
Member#: 7688
Vehicle:2018 WRX Premium Crystal White Pearl |
well...let's see...driver's side lower?
you may need to cut back on the twinkie consumption! j/k |
08-14-2001, 05:24 PM | #3 |
Member#: 9160
That's pretty funny considering I weigh less than 160 lbs! ...Newark huh, my fiance' is from Bear, DE..small world.
Anyways I forgot to mention that may dealer mechanics checked it out and said everything was at factory spec??? Does that mean everybodies ride is lower on there driver's side!... Please, this is my first thread and I think it's a pretty ligit question...Anybody....Thanks. |
08-14-2001, 09:48 PM | #4 |
Member#: 6935
Vehicle:1999 Impreza 2.5RS Rally Blue |
Get a nice looking lady to sit in the passenger seat and level out the car!
08-15-2001, 07:55 AM | #5 |
Member#: 4817
NESIC
Which side of the car does the gas tank sit on?
-tim |
08-15-2001, 08:00 AM | #6 |
Member#: 6657
got the same thing when I began installing the coilovers. The RR was 3/4 in less.
go figure. I guess this spec. |
08-15-2001, 10:33 PM | #7 |
Member#: 9160
Thought you were on to something with the gas tank thing but I just filled up and did measurements before and after and they were both the same, 1cm lower on drivers side?????
Oh well maybe it's just the springs. Anybody else have this problem with STOCK suspensions?? I am eventually going to upgrade my set-up. Any suggestions on what would be the one most important component to upgrade first?? Springs, Sway bar, Strut bar, 17's w/ good rubber, A good LSD?? Speking of LSD's my car didn't come with one and what better reason than that to justify getting a good aftermarket one? Any suggestions? And what differences would one be to the other (LSD) CUSCO or STI????? |
08-16-2001, 07:57 AM | #8 |
Member#: 4817
NESIC
Quaife makes great diffs for most applications... not sure of how much it would cost for a Subaru setup, but you can't get much better quality then them!
-tim |
Ride height variance | Kean | Brakes, Steering & Suspension | 9 | 02-22-2010 07:03 PM |
lower ride height, maintain stock ride quality ? | IllNastyImpreza | Brakes, Steering & Suspension | 8 | 09-02-2007 09:22 AM |
tein ss - adjusting ride height affect ride comfort? | aznmc16 | Brakes, Steering & Suspension | 1 | 09-01-2006 01:25 PM |
Ride Height on MY02 WRX Sedan - Front Too High? | 02WHITEDUB | Newbies & FAQs | 6 | 10-23-2005 03:58 PM |
Legacy GT ride height question... | gtguy | Legacy Forum | 11 | 02-26-2001 09:33 PM |
