05-29-2012, 06:59 PM | #1 |
Member Sales Rating: (25)
Member#: 232458
SWIC
Vehicle:2005 & 2008 STi Cobb 20g & EFR 7670 |
Turn in Concepts (TiC) new EBCS! Review
First I'd like to that Clint for choosing me to be one of his product testers. It's nice to have vendors be active in a way like this; seeing what the people want, getting feedback, then producing parts that have been proven to work on our specific vehicles. So keep up the good work!
So being a test product the EBCS is unbranded. I am going to assume that the final piece will have some type of logo or engraving with TiC on it. Upon opening the box I noticed the EBCS to be very small, sleek, and attractive! Contents were: EBCS, 3 barb fittings, setup instructions, and Clint's card as well as some TiC stickers (that now decorate my work bench). What I loved about this is that it was plug and play!! So no splicing or soldering, just unplug the old one and plug in the new one! After looking at it a bit more I noticed the barb fittings to be just a tad short. They worked fine for the install, but they could be just a little bit longer. I connected it up (I have a TwinScroll kit) in a fashion most don't because I need "Tee's" for all connections. But now going from a MBC to this enabled me to get my SI-Drive back! Finally! No more pulling over and turning the knob up or down. Just turn the switch and have boost settings on the fly! Setup was easy, just follow the instructions. Now for tuning it: Cameron @CAMTuning.com did the tuning. You all know he has skills so tuning this was no big deal. Once I was able to do pulls I noticed that boost was solid, quick and consistent! At the turn of the knob, SI-Drive bumped up target boost to 25psi and the TiC EBCS responded instantly: 25psi! Up to 30 next! I have an Omni power MAP sensor so controlling boost up there was not an issue. Again the EBCS was flawless. With such a small piece of hardware, this has really changed the way the car performs. Takes one more step out of the equation with me having to go manually turn up boost. Solid piece of equipment, solid performance! Thanks again Turn in Concepts for the easy plug-in-play EBCS!! Last edited by wgr73; 05-29-2012 at 07:13 PM. |
05-29-2012, 09:19 PM | #2 |
Vendor Sales Rating: (159)
Member#: 93646
MWSOC
Vehicle:Many Track Records Let us help you go fast! |
There are a couple of things to note on this one.
First, it's not a TiC product, but the result of a manufacturer we've been working with for a while who wants to go more mainstream. That company is Motive Autoworks. You may also see the name tossed around a bit due to the composite TGV risers we're also currently having tested. Some of the feedback we've gotten so far is this: 1) needs a bracket - this they have been working on, but they really wanted to get the valve tested first so sans bracket on the testers. 2) needs a 90* fitting in the middle, and all the fittings need to be a little longer as those short ones can be a pain in the butt. We passed that along, and they were able to source some double barb longer fittings for more practical use.
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. __________________ |
05-29-2012, 10:08 PM | #3 | |
Member Sales Rating: (17)
Member#: 261612
Vehicle:2002 WRX - 750WHP 9.5s @ 150mph |
05-29-2012, 09:25 PM | #4 |
Member#: 232458
SWIC
Gotcha.
1) I mounted mine just fine. A bracket will only be a plus! 2) This will make things easier as well! Thanks for those double barbs, will be great for peace of mind. This will turn out well. Great product! |
05-29-2012, 09:25 PM | #5 |
Member#: 232458
SWIC
Gotcha.
05-30-2012, 08:01 AM | #7 |
Member Sales Rating: (32)
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
I recived this unit as well and is a very nice piece. I love that it doesn't require splicing like the unit that was previously installed on my car .
05-30-2012, 09:47 AM | #8 |
Member#: 93646
MWSOC
__________________
07-10-2012, 10:26 AM | #14 |
Member Sales Rating: (3)
Member#: 254148
South East
Vehicle:2006 WRX Sportwagon Steel Grey Metallic |
Lolz, Tom owns Kartboy guys, I'm pretty sure he was joking. I'm psyched for this unit, I've been eyeing the Grimmspeed unit for a while now and I got in on TiC's TVG groupbuy so I'm def. going to pick one of these up when it comes time for final payment.
07-12-2012, 07:25 PM | #15 |
Member Sales Rating: (24)
Member#: 188705
Vehicle:GD Widebody STI Lexus Pearl White |
Just wondering is this the same as MAC Boost Control Solenoid valve sells on Ebay?
http://www.ebay.com/itm/Boost-Contro...ht_1569wt_1229 |
07-15-2012, 01:40 PM | #17 |
Member Sales Rating: (37)
Member#: 202736
SCIC
Vehicle:2002 WRX- 6spd - MBP 1992 Civic VX 40MPG |
Also... The important part are the specs of the valve, voltage, amps l, frequency, normal open or close. They may look the same by can be different. Luke an sti and Wrx. The body is the same, but spec are different.
03-13-2013, 02:26 PM | #19 |
Member Sales Rating: (6)
Member#: 340451
SWIC
Vehicle:2008 Corvette Z06 Atomic Orange |
Have there been any reports of these being impossible to tune? Any failures? The one that is currently on the site looks to be as solid, if not more so than the Cobb 3 port. Motive Autowerks is looking to be my choice in 3 port, but I don't want to fall into the trap of judging a book by its cover.
03-13-2013, 03:08 PM | #21 |
Member#: 93646
MWSOC
__________________
Similar Threads | ||||
Turn In Concepts Xbrace Review! | Strider327 | Car Part Reviews | 66 | 08-06-2018 03:21 AM |
FS : OEM 04 WRX downpipe, Turn In Concepts 5MT Linkage Update, FREE TD04, EBC, Airbox, etc | kylej | NESIC Private Classifieds | 14 | 04-01-2012 09:33 AM |
Turn in concepts suspension package review (Tokico-Dspecs and RCE Yellows) | Elemento1991 | Car Part Reviews | 2 | 09-16-2011 10:29 AM |
Turn In Concepts (TiC) Now available from Vaughn Performance!!! | Vaughn Performance | Drivetrain | 66 | 12-22-2008 05:43 PM |
