07-17-2009, 10:43 AM | #1 |
Member#: 67242
Vehicle:2000 11.7s@119mph Std engine + TD05 16g |
Standard position turbos running 10s 1/4mile?
What standard position turbos are capable and have been proven of running 10s 1/4mile?
Engine/trans/weight/tyres/fuel along with 1/4mile data please.
07-17-2009, 11:09 AM | #2 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
FP red, DOM III, 18G,................
07-17-2009, 12:03 PM | #3 |
Member#: 67242
18G?? TD05-18g?
07-17-2009, 12:16 PM | #4 |
Member#: 133146
07-17-2009, 12:37 PM | #5 |
Member#: 67242
Have just been reading it.
That's seriously impressive! |
07-17-2009, 03:06 PM | #6 |
Member#: 68647
Vehicle:07 STI 35R 05 BMW M3 ZCP |
Without weight reduction and with some great driving you'll probably need a 52 lb/min turbo or something close to it. If you go through some major weight reduction it can be done on a lot of turbos. Xadrian's 18G pass is a great example. Also race gas will more than likely be required with a good tune. Also if you don't mind lag and have your mind set on a 10sec pass, opt for the larger turbine housing.
07-17-2009, 03:17 PM | #7 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
f*kin A juan you're killing me.
FP Red = 1-2 guys have done it Dom3 = 1 guy (possible the best 6speed subaru driver) has done it 18g = 1 guy has done it.....his car weighs 2700 lbs and he has PPG gears. Why give the guy 1 off results that he has 0.0000001% chance of replicating? The FACT is that most people (99%) that are 10.99 and faster on the 11.55 and faster registry have AT LEAST a rotated GT35. The answer to your questions is NONE. There arent 5 people on any given stock location turbo in the 10's. The reason isnt that it cant be done either, just that most poeple that have the supporting mods to run a stock location gt30/35 almost always just go rotated. 11.5XX and Faster Registry.... Last edited by Phatron; 07-17-2009 at 05:14 PM. |
07-17-2009, 04:17 PM | #8 | |
Member#: 133146
07-17-2009, 04:31 PM | #9 |
Member#: 102808
Vehicle:1995 Built EJ207 6sp 30r ***break in*** |
just search.
07-17-2009, 05:10 PM | #10 | |
Member#: 104200
TXIC
Vehicle:000 WHP BUGEYE Street Proven Performance |
07-17-2009, 05:59 PM | #11 |
Member#: 67371
Vehicle:05 BUILT 2.4L STI |
I did it in 2007 with a maxout SZ55 and minor weigth reduction. I bet it's even easier with the HTA Green and bigger turbos. The hard part is doing it with the smaller frame turbos.
07-17-2009, 06:12 PM | #12 |
Member#: 36033
SCIC
^^ Thats the thing.....the people going for fast times wont put on a stock location turbo.
The only people that will do it are the ones going for a record. The same thing with people trying to go fast on smaller turbos. The ONLY point of trying to run 10's on a stock location turbo is to try and set a record. "Normal" people arent running stock location turbos on c16 and motorcycle slicks. |
07-17-2009, 06:17 PM | #13 |
Member#: 182804
Vehicle:2006 Gsxr 1000 Turbo |
I plan on running 10's with a FPred 3", On a 6-speed. Not for a record but just because I had a rotated PT67 turbo that made plenty of power. Now I want to just see if I can make my self happy with the FPred..... I love a challenge and have no doubt it will make enough power to please me. Also wanting to do this on pump gas????
07-17-2009, 06:27 PM | #14 | |
Member#: 114631
Vehicle:2009 GTR, 735whp 13' Benz, 15' WRX |
Im not being negative, but, throw some good gas in there dude. There is a puerto rican car that went 10.6 and was gutted on C16 with soft suspension in the rear for that nice desired squat. |
07-17-2009, 07:02 PM | #15 |
Member#: 205916
South East
Vehicle:2003 Subaru WRX in the 10's and the bends |
people need to not skimp out on octane!
07-17-2009, 07:15 PM | #16 |
Member#: 125913
Vehicle:2002 ECS Built WRX |
FP Red hitting 10s is not impossible but it takes a lot of work to back it up.
07-17-2009, 07:24 PM | #17 |
Member#: 133146
some one send me a red and some 1000cc bosh injectors, and I pretty sure my car will run 10s
If my car doesn't sell thats what I am doing next year |
07-17-2009, 07:31 PM | #18 |
Member#: 67371
Why 10's on the RED? Shoot for 9's!!! That's the next step.
07-17-2009, 09:49 PM | #19 | |
Member#: 137168
South East
Vehicle:06 Built SGM WRX 35r, PPG, 280's, PSS9. |
I feel that it is very very doable with any bolt on over 58+ lbs/min. Honestly, I have yet to see a balls out pass, on a balls out tune with any of the bigger bolt on turbos........ with a few exceptions of course. I feel people with 20g's and up run a few times and are a little dissapointed for whatever reasons. bad launch, weak tune, etc, etc. No one seems to try and max out their turbo before slapping on the rotated gt35r. I really dont see how a WRX with one of these turbos cant hit 10's with 28+ psi. |
07-17-2009, 09:49 PM | #20 |
Member#: 137168
South East
07-17-2009, 10:00 PM | #21 |
Member#: 36033
SCIC
Cause it gets expensive. A wrx will need a built motor and trans, at least $8k right there plus another $6k for turbo, tbe, injectors, intercooler, etc.
07-17-2009, 10:44 PM | #22 |
Member#: 51964
TXIC
Vehicle:2008 STi, OB, EVO Blk Sti and EVO, Navy OB |
This is the biggest reason. It will cost you a bunch of money. If you want to run 10s, you'll need to be a very very good driver to do it without abusing your car and breaking stuff. Putting that kind of power down in a Suby or even an EVO is very abusive to so many parts. Every other trip to the track, I broke something in my EVO. Most people that run these times do, but you never hear about it. It gets very expensive and frankly, you get tired of having your car in the shop.
07-18-2009, 01:23 AM | #23 |
Member#: 36033
SCIC
^^^ thanks. I've been getting sick of all the "u can run10's for $3k" comments lately
07-18-2009, 02:38 AM | #24 |
Member#: 133146
07-18-2009, 03:46 AM | #25 |
Member#: 36033
SCIC
Why haven't u done it yet? If all u fackers are gonna tell people they can run 10's on an 18g you better at least be there yourself or step back into reality.
Similar Threads | ||||
530bhp at HUBS from UK Tuned 2.5 with GT30 standard fit turbo | Shaun@ScoobyNet | Proven Power Bragging | 6 | 05-18-2010 11:35 AM |
FS: FP standard 16g turbo pnp coated | NexRex | Engine/Power/Exhaust | 15 | 04-07-2009 11:36 PM |
GT30 based stock position turbo | Listerofsmeg | Private 'Wanted' Classifieds | 3 | 07-09-2006 02:42 PM |
Element Hydramist runs 10s! | Element Tuning | Proven Power Bragging | 74 | 06-07-2006 03:14 PM |
98 impreza runs 12.8 1/4mile | farrell | Proven Power Bragging | 16 | 12-18-2005 09:32 PM |
