Brakes & Suspension Forum sponsored by The Tire Rack |
02-18-2002, 07:26 PM | #1 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
The new MRT adjustable top mounts vs. the old ones - what the hell happened??
I've been looking into buying some MRT adjustable front top mounts. I like the MRT design because, unlike most other "pillow ball mounts" I've seen (Cusco, for instance), the MRT top mount has a poly bushing surrounding the spherical bearing. I figured that would help keep the NVH increase down.
Here is a picture of the old MRT top mounts: Edit: MRT updated their website, so the nice old top mounts are no longer pictured. Sorry. 6/4/02 So I start calling around to MRT dealers here in the US and Bill Harvey at Exeter Subaru tells me they've got two sets coming in today. He called me today and told me he wanted to email a picture of them, because they were totally different. Here's what they look like now: You can see another shot of these top mounts on Teague's webpage http://home.att.net/~teaguesauto/suspension.htm . Is it just me or do these things look really ghetto? And, no, I don't mean aesthetically, I mean functionally. It doesn't look to me like there would be any way to mark your settings on the new top mounts, so you would have to have the car aligned on a rack each time you wanted to change the settings. I'm not impressed by the change, and from talking to Teague's and Exeter it appears they were caught completely by surprise when these new parts showed up. Pat Olsen '97 Legacy 2.5GT sedan
02-18-2002, 08:18 PM | #2 |
Member#: 437
NESIC
Pat,
I hadn't seen the new or the old, so thanks for bringing this up. You make very valid points. I wonder what caused the change. It would be interesting to see what MRT has to say about it. Paul G. |
02-18-2002, 11:19 PM | #3 |
Member#: 1605
NESIC
Vehicle:1997 1.8L Brighton NESIC TrackH0z member#1 |
Looks as if you can do camber and caster on the second one. Of course, there is no way to mark where you were! I guess you would need one of those portable wheel alignment tools. From what I hear, caster would be a good way to get max grip in the turns without losing braking grip like you do with camber.
Later, Seth E. |
02-18-2002, 11:38 PM | #4 |
Member#: 4181
Vehicle:2003 Lancer Evo 8 It's Blue, ok? |
That sucks. I was going to get a pair when I had the chance.
oh well. the search continues for a caster adjustable camber plate. |
02-19-2002, 12:52 AM | #5 | |
Member#: 120
AKIC
Chris - If you're looking for separate caster and camber adjustability then I don't think you should immediately discount that new design. As Seth said, it sure appears in the pictrre that you can adjust either parameter independently. It looks to me like the three mounting bolts serve a dual purpose - holding the top mount in place, and also clamping down on the portion of the top mount that moves. That plate just has big notches at each corner, so it appears you could get both camber and caster adjusted.
Seth - I know with Mustangs (which also use a Mcpherson strut-type front suspension, albeit one with lousy geometry) everyone says for good handling to max out the positive caster. There are guys who run as much at +6 or +7deg with good C/C plates. I should be in the +5 to +6 range with my Mustang, I think, after the next round of suspension mods. From what I understand, adding more positive caster reduces camber gain during cornering. If you can run lots of positive caster, you'll be able to get away with running less static negative camber, because your dynamic camber change in the corners will be smaller. That's a good thing. I emailed MRT about it and their reply was: Quote:
Pat |
02-19-2002, 01:33 AM | #6 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
Wow $700 for a set of strut tops? I bet those aren't built for low NVH
Isn't caster adjustment only allowed in SM in SCCA autox? Doesn't STX/STS allow camber adjustment, but not caster? If so, these would not be for autox junkies. Hmm... I decided to search and answer my own question: (STS rules) E. On vehicles with strut-type suspensions, adjustable camber plates may be installed at the top of the strut, and the original upper mounting holes may be slotted. The drilling of holes in order to perform the installation is permitted. The center clearance hole may not be modified. Any type of bearing or bushing may be used in the adjustable camber plate attachment to the strut. The installation may incorporate an alternate upper spring perch/seat and/or mounting block (bearing mount). Any ride height change resulting from installation of camber plates is allowed. Caster changes resulting from the use of camber places are permitted. (/STS rules) That last sentece is misleading, I don't think these would be legal in STS/STX, as they probably don't mean camber plates which are specifically designed to allow changes to caster also. But it's open to interpretation, I suppose. |
02-19-2002, 10:07 AM | #7 |
Member#: 1605
NESIC
Confused!
The message that Pat got back from MRT seems a bit confusing. Okay....the origional picture from the MRT site are the old ones which were discontinued and no longer supplied. Second, who the hell makes the crap ones? Does MRT make them? If so, why are they selling such a crappy product? MRT even calls them "cheap". What does this $700 mount look like? Is it the same as the "old style"? Why in the hell would it cost $700 for a set of adjustible mounts?!?!?! When were they ever in stock? What do they look like? It seems that MRT never gives a decisive answer.
Later, Seth E. |
02-19-2002, 10:54 AM | #8 |
Member#: 1133
Vehicle:09 GTR, 02 996 C4S 95 993 C4, 71 911, 04 STI |
Jeez, how hard is it for the manufacturers to give us what we want? From reading the various camber plate threads, it seems to me that 75% of performance-minded Subaru owners would want the following specs:
- independently adjustable camber and caster, with the ability to adjust one without adjusting the other. - tick marks or calibrations on the plate(s) so you can move between known settings without a re-alignment. - polyurethane or hardened rubber mount to minimize flex without the metal-on-metal click-click-click noises. - a price < $400 for the pair. There you go MRT/ISR/Cobb/whoever: make/source these and I'll bet you'll sell hundreds of them! |
02-19-2002, 11:02 AM | #9 |
Member#: 120
AKIC
Aaaamen, Brother Jon. This doesn't seem like such a difficult thing to me, either, but nobody seems to be able to produce. them with the characteristics you listed. The thing that really confuses me is the lack of independent caster/camber adjustability.
Seth, Ben said those super-whamodyne $700 top mounts just became available, hence the lack of pictures. I don't know what they look like or why they cost $700, but they are definitely not the same as the "old style" (which sold for under $200). Pat |
02-19-2002, 12:26 PM | #10 |
Member#: 618
Vehicle:2000 2.5 RS #89 STS MODERacing / Bridgestone |
You nailed it Jon! That's exactly what I want, I hope some manufacturers are listening. I was about to order the MRT mounts untill I saw this post, thanks for brining this up.
Corey |
02-19-2002, 12:30 PM | #11 |
Member#: 437
NESIC
Is this something that Kartboy could make? Looks like it. You guys should send him this post and let him know. If anyone can do it, he could (if he has the time). It might be more expensive, but if he offered a group buy or something before the autox/track season starts, I bet he'd get lots of interest.
Paul G. |
02-19-2002, 06:06 PM | #12 |
Member#: 1512
Vehicle:99 2.5RS Rally Blue and Black |
Ground Control?
Has anyone checked out ground control's camber plates?
They don't have Subaru's listed, but they seem pretty universal and I think Gary Sheehan might be using them on his race car. Plus, they're one of the only ones I've seen that use a thrust plate/bearing to take the load off the spherical bearing. Ground Control -Steve [email protected] |
02-19-2002, 06:10 PM | #13 |
Member#: 1512
Answered my own question ... Ground Control camber plates on Gary's car:
Sorry for the big pic ... -Steve [email protected] |
02-19-2002, 06:25 PM | #14 |
Member#: 287
Vehicle:2019 Outback Blue |
Anyone know which application they used on the Subaru? I checked the STS and SP rules and we are allowed to drill holes to mount the plates (if you didn't notice the GC plate had four bolts to hold it down while the Subaru strut mount uses three).
Other than some careful measuring it doesn't seem to be a hard install. Anyone know for sure? Tony |
02-19-2002, 06:36 PM | #15 |
Member#: 6495
Vehicle:2002 WRX Black |
Adjustable camber caster plates are legal in STS. The STS rules are just a carry-over from the street prepared rules and they are definately legal there...
Ground Control is working on a set of camber/caster plates that will work with the stock Subaru mounting holes... The drawings are done for them and they hope to start production soon. I believe I will be recieving the first (if not the first) set. I will let you know how it goes. Jason Uyeda |
02-19-2002, 06:37 PM | #16 |
Member#: 1512
I'd guess that they just found something with the correct shaft diameter. Tom (kartboy) and Joel Gat work with/on the car and would probably know.
02-19-2002, 06:39 PM | #17 |
Member#: 4414
1) Better never ever want to use a strut bar if you use the GC plates. (probably not an issue for most)
2) Gary has no concern for NVH, and this is what the whole thing stemmed from initially by Pat wanting the MRT plates over the Cusco full metal PBMs. Can anyone comment on the NVH with the GC plates? Anyone have price info on the GC plates? Edit others are quicker typers...please keep us informed spaf, though I do like how they totally maxed out the caster by changing the mounting holes such that the plate is pretty much as far back as possible. Probably not possible with mounts that go in the stock holes, or without changing the clearance of the hole for the strut, so probably not STS legal to put it so far back. |
02-20-2002, 01:49 AM | #18 |
Vendor
Member#: 14494
Vehicle:WRX Porsche 996 blue & black |
Hello,
Joel here. See the leading edge of the GC plate as shown in the pic of the race car? See how it's worn out? Wonder where that's from? Gotta love Big O. We were out of time, early in the season, and wanted to laser verify our basic alignment so that all our changes would have some reasonably verified starting point. So we asked Big O to align the car. They did. They wanted more castor. They took a BFH (Big F-ing Hammer) and slammed the bejeezus out of the plates. Oh yeah. Quality work, those fellows. Quality work with a hammer. Joel |
02-20-2002, 08:49 AM | #19 |
Member#: 7089
NWIC
Vehicle:2016 STi |
I was at DMS-USA's shop a couple weeks ago, and Dave showed me some pics of a caster/camber plate made by DMS. Looked to be *very* high quality - basically a camber plate in a caster plate, independantly adjustable and both well marked/graduated... I've never seen those dms plates for sale though...
02-20-2002, 11:07 AM | #20 |
Member#: 618
Here is the major issue for me.
From Jon's spec's: -polyurethane or hardened rubber mount to minimize flex without the metal-on-metal click-click-click noises. What we need is are mounts that have this! Corey |
02-20-2002, 11:07 AM | #21 |
Member#: 120
AKIC
I've heard of the DMS plates, but have never seen any pictures or prices. I searched on here a while back and found one post by a guy who had gotten them and said they were crap, and another post by a guy who had gotten them and said they were the greatest thing since sliced bread. Ahhhh, gotta love the iClub.
Pat |
02-20-2002, 11:23 AM | #22 |
Member#: 2184
Vehicle:2005 Legacy GT wagon Platinum Silver Metallic |
Kevin |
02-20-2002, 12:05 PM | #23 |
Member#: 1133
Ground control already makes exactly what we need--just for E46 BMWs. It looks like castor is not adjustable on the fly, but that wouldn't be a huge drawback as you can add an add'l degree or so of castor in the shop then play with camber at the track.
http://www.ground-control.com/e46_m3_street_camber.htm |
02-20-2002, 01:30 PM | #24 |
Member#: 1512
The metal to metal clanking noise is from the spherical bearing in the plate. They're not designed to take large axial loads (like the force of a car bouncing around) and they tend to get sloppy really fast. Also, the bearings that most people sell are pretty lousy to begin with and have slop built in. It is my assumption that because Ground Control uses a thrust bearing that takes the vertical load that they wouldn't clank nearly as much and the spherical bearing would last longer. I could be wrong, but that's the theory behind it.
02-20-2002, 02:30 PM | #25 | |
Member#: 4181
I think they are from DMS japan. |
WTT: MRT HUGE top mount Spearco top mount | axelthrasher | Engine/Power/Exhaust | 0 | 07-25-2007 06:31 PM |
One more time: WRX/STI top mounts VS Gpn | ShawnRS | Brakes, Steering & Suspension | 1 | 08-20-2005 01:06 PM |
ProDrive muffler, comparing the old one to the new one | ImprezaWRXFan | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 11-15-2004 02:22 PM |
Group N Sti top mounts vs. Stock STi top mounts | psaeko | Brakes, Steering & Suspension | 21 | 04-04-2003 09:51 AM |
ANyone know of a vendor with MRT adjustable top mounts in stock? | Patrick Olsen | Brakes, Steering & Suspension | 4 | 02-14-2002 07:56 PM |
