01-22-2010, 11:38 PM | #1 |
Vendor Sales Rating: (25)
Member#: 23931
Reload this Page Check Out These New Defi Advance CR Gauges!!
Introducing the NEW DEFI ADVANCE CR GAUGES PRODUCT FEATURES - Interactive communication advanced system is implemented - Flat glass and precise graduation scale give more needle accuracy and high visibility - LOW mount back case (11% down over currently in use) - Flat glass adopted - Gauges can be controlled from distance with the included switch unit - Opening and closing modes can be selected from 2 variations A. Two Color Flashing Light B. Flashing Type - The installation of additional gauges is easy. Just connect it with the other two gauges and attach the wire to Advance Control Unit - The illumination at night can be switched between 2 different colors (White dial: amber red / blue; Black dial: white / amber red) - The outer edge of the gauge illuminates in red at night - The needle pointer driven by original stepping motor has a smooth instantaneous response to rapid acceleration of high performance vehicles - The microcontroller calibrates up to 270 degree angle in 3027 - 4600 segments (0.088°- 0.059°), and provides accurate vehicle information - Self-diagnosis system turns the warning LED on to indicate any wire disconnection, short circuit and serial communication errors - Warning by buzzer sound when the warning LED is on (buzzer sound can be turned on / off) A. Peak Time B. Warning Time - Peak value and warning value during driving are stored. Driving data can be stored and replayed up to 3 minutes - A mounting bracket, meter cup, regular position bezel are provided with this product - With both fuel pressure gauge and turbo installed, differential pressure can be monitored on the fuel pressure gauge screen - Defi-Link ADVANCE SYSTEM is the next generation system that adopted the interactive communication - The product of Defi-Link ADVANCE SYSTEM cannot be connected with the product of Defi-Link SYSTEM. It is not compatible with the product of Defi-Link SYSTEM Here is a Link to the video so you may see how the gauge operate when turned on & turned off DEFI ADVANCE CR GAUGE LINE UP Retail Price o 60mm TURBO 200KPA in White or Black - $283.00 o 60mm TURBO 120KPA in White or Black - $283.00 o 60mm Manifold Pressure in White or Black - $283.00 o 60mm Oil Pressure in White or Black - $324.00 o 60mm Fuel Pressure in White or Black - $324.00 o 60mm Oil Temperature in White or Black - $229.00 o 60mm Water Temperature in White or Black - $229.00 o 60mm Exhaust Temperature in White or Black - $324.00 o 60mm Tachometer 9000rpm in Black or White - $202.00 Retail Price o 52mm TURBO 200KPA in White or Black - $283.00 o 52mm TURBO 120KPA in White or Black - $283.00 o 52mm Manifold Pressure in White or Black - $283.00 o 52mm Oil Pressure in White or Black - $324.00 o 52mm Fuel Pressure in White or Black - $324.00 o 52mm Oil Temperature in White or Black - $229.00 o 52mm Water Temperature in White or Black - $229.00 o 52mm Exhaust Temperature in White or Black - $324.00 PLEASE PM US FOR PRICING, COMBO PRICES, SHIPPED PRICES, etc.
__________________
[B][U]Headquarters/Chicago Branch[/U][/B] Fizz Chicago 561 Arthur Ave, Arlington Heights, IL 60005 Tel. 847-797-1323 Fax. 847 797-1325[/COLOR] Join us on To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ! And our To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ! |
**Back Up Sensors/ HID Blowout Sale - $179.99 Shipped/ New DEFI ADVANCE CR GAUGES!** | Fizz Autosports | Gauges & Electronics | 132 | 09-01-2010 10:19 AM |
HID Kit Blowout Sale! Any Color! $179.99 Shipped & New DEFI ADVANCE CR Gauges! | Fizz Autosports | Gauges & Electronics | 5 | 02-02-2010 10:21 AM |
Check Out These New Defi Advance CR Gauges!! | Fizz Autosports | Gauges & Electronics | 12 | 01-27-2010 10:42 AM |
NEW Defi Advance CR Gauges!! Lowest Prices & FREE Shipping on 3 or more gauges!! | CygnusPerformance | Gauges & Electronics | 32 | 09-24-2009 11:04 AM |
FS: New Defi Advance CR Gauges with Controller | KAS_Foreigner | Interior/Dressup/Audio & Security | 2 | 07-15-2009 08:07 AM |
