11-14-2002, 02:05 PM | #1 |
Member#: 16755
what to do with uppipe factory egt if using defi egt
if i put a defi egt probe in my godspeed uppipe what do i do with the factory egt probe?
thansk
11-14-2002, 02:09 PM | #2 |
Member#: 8945
TXIC
Vehicle:MY02 WRX Blue |
How do you plan to put your defi egt probe in the factory style bung?
The bung is a 12x1.25mm straight tap with a tapered seat. Your egt probe probably requires a tapered thread (prolly npt or bspt) hole. |
11-14-2002, 02:09 PM | #3 |
Member#: 8945
TXIC
If you want to do away with the factory EGT probe, replace it with a 2.2Kohm resistor.
11-14-2002, 06:53 PM | #4 |
Member#: 16755
yea i jsut realized that, i was posting from school and i came home and tried the fitting...so i am going to tap the manifold whoopee what fun
11-20-2002, 05:07 PM | #5 |
Member#: 28268
NWIC
Vehicle:2002 WRX Sedan WRB |
So is it safe to say to spend a little more and get an up-pipe without the EGT bung [ie: Perrin]?
_Owen_ |
11-20-2002, 05:15 PM | #6 |
Member#: 15533
Vehicle:2010 Dodge Ram Hemi boat, dirt bikes, bobcat |
Tap at the manifold for acurrit readings. I am installing one this weekend into mine. Should be cool.
11-20-2002, 07:58 PM | #7 |
Member#: 14919
Vehicle:2008 LegacyGT SpecB |
EGT readings from the uppipe won't be as accurate as those in the headers or manifold. I suggest leaving factory uppipe egt bung there and tapping another spot for your gauge. Much easier access than the uppipe too in case you've got some problems.
11-21-2002, 12:11 AM | #8 |
Member#: 16755
yea i decied to tap the manifold..dong this weekend as well
11-21-2002, 04:17 PM | #9 |
Member#: 24399
Vehicle:2003 White WRX 89 240 / 90 240 |
I have to do mine like next week......so its safe to say that the manifold should be tapped??
Also, are you all pulling the manifold completely off in order to tap it....just to make sure filings dont get into the turbo? |
11-21-2002, 04:52 PM | #10 |
Member#: 9073
NWIC
Vehicle:2006 ariel atom wrb/bbs gold frame |
If you're going to get an uppipe as well, wait until you get it. As long as you have to take the manifold off to drill and tap it (and yes, you DO want to take it off), you might as well do the uppipe as well!
11-21-2002, 04:57 PM | #11 |
Member#: 24399
good point, i might get that gruppe-s uppipe, and it'd be a good time to go it all......
what do you think about warrenties and uppipe? I'll probably have to change it evertime i'd need something claimed right? |
Mechanically knowledgeable but I dont wont to do the work.. what to do with $2000.00 | motormojo | Newbies & FAQs | 15 | 01-14-2006 11:30 PM |
What to do with used brake fluids + coolant | realwomble | Service & Maintenance | 8 | 03-16-2005 03:09 AM |
What to do with used oil filters? | Bottom Feeder | Service & Maintenance | 3 | 11-30-2001 05:09 PM |
What to do with flatted tire? Use the donut? | hkwan | Brakes, Steering & Suspension | 12 | 11-20-2001 06:36 PM |
What to do with keyless entry with add-on alarm | eaz | Car Audio, Video & Security | 3 | 05-10-2001 07:05 PM |
