08-24-2003, 02:15 PM | #1 |
Member#: 24956
Vehicle:1997 Impreza WRX Steel Blue Mica |
What are you using for a fuel pressure regulator?
just wanna see what people are using. if they went aftermarket or used another OEM regulator from another car. thanks.
Brent
08-24-2003, 02:22 PM | #2 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
SVX FPR.
08-24-2003, 02:47 PM | #3 |
Member#: 39387
Vehicle:2002 Impreza 2.5RS Aspen White |
I am using the same...you can find one usually at a recking yard. I got mine for $5 because moron had no idea what it was...If you are having a hard time finding one I might be able to see if the place has another one...
08-24-2003, 03:26 PM | #4 | |
Member#: 24956
Brent |
08-25-2003, 08:36 AM | #5 |
Member#: 22828
SCIC
Vehicle:02 Impreza Sedona Red Pearl |
Ok so SVX fpr
Okay so use an svx fpr, i am also assuming it will be a direct swap? also what gains are expected of the svx? and when is a person need this item?
08-25-2003, 02:27 PM | #6 |
Yes, direct swap.
Those of us using regulators are using them because we are using higher pressure fuel pumps that can't be dealt with correctly by our stock FPR's. The fuel pump rises 10-15psi and doesn't react correctly to vacuum/atmospheric pressure feed changes. |
08-25-2003, 02:34 PM | #7 |
Member#: 4461
NWIC
Vehicle:02 2.slow |
svx fpr and wrx fuel pump. I'm running those because I am running a 75 shot of nitrous *cough*dry*cough*.. And as lazy bastard said we should be able to get another svx fpr for fairly cheap.
08-25-2003, 03:18 PM | #8 |
Member#: 94
Vehicle:1999 2.5 RS-T RBP EJ257 Hybrid Link'd |
I'm sure this has been covered like 50 times but will the SVX FPR adjust 1:1 in boost? I have both an SVX one and an Aeromotive uninstalled at the moment, if the SVX raises 1:1 then I can hold off on the Aeromotive till I get some rails
08-25-2003, 04:24 PM | #9 |
Member#: 22828
SCIC
ok not to sound like a rookie.
ok not to sound like a rookie but, when should someone get this fuel pump?
guys/gals with dss stg 5 rears, what are you using for lugs? | z/ssti | Tire & Wheel | 6 | 04-03-2008 11:54 PM |
UK300 users..What are you using for bulbs. | enewtabie | Electrical & Lighting | 1 | 08-11-2004 11:55 PM |
Upgraded TMIC owners....what are you using for a "seal"? | mav1c | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 04-30-2004 12:05 PM |
Track Whores: What are you using for rotors? | redobs | New England Impreza Club Forum -- NESIC | 53 | 03-12-2004 02:02 PM |
DIY fuel mixers...What are you using for containers? | QA Guy | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 19 | 08-10-2003 11:19 PM |
