02-01-2004, 10:54 AM | #1 |
Member#: 44589
oil sandwich adapter for oil supply?
Can I just use one of these, my turbo is being mounted down low. Thanks
02-01-2004, 03:00 PM | #2 |
Member#: 37196
no you can't.
Has something to do w/ too much oil pressure. It would blow the seals in your turbo. -Jake |
02-01-2004, 03:29 PM | #3 |
Member#: 5349
Where can I get one of the sandwiches for an oil cooler - anyway?
02-01-2004, 04:04 PM | #4 |
Member#: 1676
NESIC
Vehicle:98RS w/ EJ257/Dom 2014 Tesla Model S P85 |
Summitracing sells them for $30.
part number is FLX-3965. You can also get them in kits. In case you're curious Subaru uses a M20x1.5 filter thread with a 2.5" bore. |
02-01-2004, 04:08 PM | #5 |
Member#: 44589
Even with an inline restrictor?
02-01-2004, 06:18 PM | #6 | |
Member#: 1197
Vehicle:2013 BMW X1 Pearl White |
Re: oil sandwich adapter for oil supply?
_Jeff |
02-02-2004, 01:14 AM | #7 |
Member#: 37196
Let me answer everyone's questions
______________________________ Normal Oil flow: Block-> Oil Filter -> Block Oil Adapter/Cooler kit: Block->Adapter->Cooler->adapter->Oil Filter-> Block His idea is to put the turbo in place of the cooler. Thus it would flow like this: Idea 1: Block->Adapter->Turbo->Adapter->Oil Filter->Block This WILL NOT WORK, because oil pressure is too high, and will blow turbo Seals. Then someone said put a restrictor in like this: Idea 2: Block->Adapter->Restrictor->Turbo->Adapter->Oil Filter->Block This WILL NOT WORK. Because now you have just restricted your main oil flow through the filter. This is an AWESOME way to blow up your engine Hope that helps. -Jake |
02-02-2004, 01:22 PM | #8 |
Member#: 5692
Vehicle:WTF? YES! I am better than you! |
It would be:
Block-Adapter-Restrictor-Turbo-Turbo return line (to pan) and plug the other adapter hole. BUT ONLY IF you used an adapter like a defi one. (for gauges instead of cooler) |
looking for oil sandwich adaptor for oil cooler | berdugo | Built Motor Discussion | 0 | 08-18-2009 11:30 PM |
has anyone drilled into the oil sandwich adapter for a gauge? | verc | Motorsports | 5 | 06-26-2009 02:20 PM |
Subaru OEM Oil Galley Adapter for oil pressure gauge | 02BlueSuperRoo | Private 'For Sale' Classifieds | 4 | 12-14-2005 12:34 AM |
Sandwich Adapter for oil press/temp | mlovro32 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 09-08-2005 04:38 PM |
