01-02-2010, 03:00 AM | #1 |
Member#: 157758
South East
Vehicle:2004 Wrx sti Fp green |
wgdc problem with ewg
Buddy has an ewg and prodrive bcs, at 100% wgdc he has 10 psi but at 0% wgdc it will overboost badley. The lines to the ewg are hooked up via a how to thread in this forum. What could cause wgdc to be backwards?
The line is in loop from the top of ewg to the bottom of ewg with a T from the loop to boost source.
01-02-2010, 03:14 AM | #2 |
Member#: 143149
Vehicle:2006 gmc envoy stealth |
The top port is connected to the bottom port? That is bad. There should be a t on the line from the BCS to the line on the bottom port of the wastegate, with the source and the top port using the other two lines from the bcs.
Similar Threads | ||||
Is there engine problem with the 2011 STI? | speed12sil | Warranty Issues & SOA Problems | 19 | 06-14-2010 11:10 AM |
VF39 EWG, With EWG pipe, Shorty Dump Tube, and 38mm EWG. | alieus | Engine/Power/Exhaust | 5 | 05-06-2010 12:06 PM |
Ewg. Setup Tail Wastgate, Gt Spec Headers And Up Pipe With Ewg Flang | j1168osh | Engine/Power/Exhaust | 14 | 06-13-2008 01:31 AM |
what is your WGDC % with the Perrin EBCS? | mogrl840 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 08-01-2007 08:51 PM |
Need Help with Boost control Problem sz49/EWG/MBC | Zornorph | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 10 | 03-11-2007 09:32 AM |
