08-23-2006, 06:33 PM | #1 |
Member#: 43105
WRX brakes on 2000 RS????
Ok, I'm looking for a simple answer but what else is needed to put my stock 2002 WRX front brakes onto my 2000 2.5RS?? I already have new stainless lines, brake pads and rotors, but do I need to use WRX caliper bolts or will the stock RS bolts work? Need the info asap b/c the car is due for state inspection at the end of the month and the brakes are shot! Thanks
08-23-2006, 06:51 PM | #2 |
Member#: 16274
Vehicle:2001 GM6 2.0L vf30 e30 black/rust |
All you need for the wrx conversion is the wrx caliper bracket, pads and the rotors.. Everything else is the same. aka, bolts,etc.
I upgraded mine with a 04 wrx setup. I reused my stainless lines.. I switched out the calipers, but upon further inspection, they are exactly the same. |
08-23-2006, 07:08 PM | #3 |
Member#: 43105
Thanks and what I have available to me is the entire front brake assembly from my WRX b/c I went to a big brake upgrade on that car, so I should be in good shape! Also, the WRX calipers have 15,000 miles on them compared to the 145,000 miles on my current RS brakes. Thanks again!
08-23-2006, 11:07 PM | #4 |
Member#: 16274
well, with that kinda mileage, better off just switching out the calipers also..
08-24-2006, 10:49 PM | #5 |
Member#: 3363
NWIC
Vehicle:1982 Reynard Blue, Red, and White |
??? A caliper rebuild is a piece of cake. The kit is about $25 from Subaru and labor is easy. A brake caliper is one of the most basic mechanical systems known to man... Anyone that is even the least mechanically inclined can rebuild them.
08-27-2006, 11:58 AM | #6 |
Member#: 8037
Vehicle:1998 2.5RS - black 2iggpoints |
i bought the entire wrx brake assy to do the conversion on my RS for 25 dollars a side.
including brackets, bolts, and calipers. i bought cheap slotted rotors on ebay and oem subaru pads the calipers are not the same, the wrx calipers are significantly larger than the RS calipers. at least they were on my 98. the entire reason i upgraded was because my calipers seized. |
08-27-2006, 12:19 PM | #7 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
2002 to early 2003 WRX calipers are the same as the RS front calipers(even 98's) mid year 2003 Subaru went with a different supplied(Tokico) and the physical size of the caliper changed. The piston diameter changed and the caliper housing god larger but the pads got smaller.
Basically to be sure, get Pads, Rotors, and Calipers, the brake hoses are all the same |
08-30-2006, 02:17 AM | #8 |
Member#: 96315
SWIC
Vehicle:1995 STi V5 replica World rally blue |
what about a 95 L with rear drums to WRX disk brakes? what would you need?
08-30-2006, 02:26 AM | #9 | |
Member#: 6551
Backing Plates from a RS Front Calipers w/ Brackets Front Brake hoses Front Rotors Rear: Rear Knuckle assemblies with E-brake items still attached(cables and all) Rear Calipers w/ Brackets Rear Brake Hoses Rear Rotors |
wrx brakes and H6 rear brakes to 2000 RS-What do I need? | 15secWRX | Subaru Conversions | 3 | 06-25-2007 10:32 AM |
WRX Brakes on an RS | dawoniyi | Brakes, Steering & Suspension | 3 | 07-03-2005 02:02 PM |
wrx brakes on 98 RS...need new lockwashers? | IllNastyImpreza | Brakes, Steering & Suspension | 18 | 02-18-2005 08:32 AM |
'03 WRX wheels fit on 2000 RS? | Psydotek | Tire & Wheel | 4 | 08-13-2004 01:06 AM |
2002 WRX seats on 2000 RS? | t.rod | Interior & Exterior Modification | 1 | 04-12-2001 07:24 AM |
