Brakes & Suspension Forum sponsored by The Tire Rack |
06-04-2006, 11:49 PM | #1 |
Member#: 49852
BAIC
Vehicle:2004 Impreza WRX STi BMW #400 / Steel Grey! |
'04 STi on Tanabe GF210 ... problem!
So I've had my GF210s on my car for about 12000 miles with no problems, ride has been decent with nothing else really bothering me. Within the last 1000 miles though, my car has been leaning more to the left side...it's now at quite an extreme angle compared to the other side. On the driver-side of my car, I can barely fit a finger from the top of the fender wall to top of my tire. On the passenger side I can fit 2 or 3 fingers without a problem. When you view the car from the front or rear, it is tilting at a pretty heavy angle to the driver side of the car. Drives completely normal though, not even alignment issues. Any ideas?
06-05-2006, 09:07 AM | #2 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
Which version of the springs do you have? The 05 version was supposed to fix this problem.
06-05-2006, 02:59 PM | #3 |
Member#: 49852
BAIC
The '04 version...so this was a known problem? o.O
06-08-2006, 10:32 PM | #4 |
Member#: 37546
VIC
Vehicle:2004 Impreza WRX STi WRB |
Ummm, I'm a little concerned now as well. I just installed the 04-specific GF210s in my 2004 STi and I'v got a bigger fender gap on the passenger side already..... if this is a common problem then I'm really, really upset.
06-19-2006, 02:24 AM | #5 |
Member#: 68602
Vehicle:02 STi Wagon |
Has anyone else had this problem? I'm looking at the 04 or 05 GF210s to put on my wagon.
06-19-2006, 10:45 AM | #6 |
Member#: 20107
Vehicle:2004 STi WRB |
Its normal for the passenger side to be higher then the driver side. The car is like this even stock, springs just make it look more pronounced. Its uaually a finer and 1/2 or somewhere between there. However when looking at the car from the front or rear its definitly not noticeable, and thats what sounds odd about your situation.
06-19-2006, 11:19 AM | #7 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
swaybar flipped?
06-19-2006, 04:48 PM | #8 |
Member#: 17975
Vehicle:2023 Macan GTS Python Green |
I had the same problem with the STi pinks on my '04. Dealership told me I had a hyper-extended strut and replaced it 3 times (covered under warranty). It would fix it, temporarily, then it would come back. If it happens to me again (I'm over my 36,000 miles) I might just buy coilovers
06-19-2006, 06:45 PM | #9 |
Member#: 64660
NWIC
Vehicle:2003 WRX Silver & Dirt |
Why is it normal for the passenger side to be higher than the driver's side? What's different about the setup on that side?
Instead of fingers, what's the height from ground to the apex of the wheel well on each side in inches? |
06-19-2006, 07:54 PM | #10 | |
Member#: 10854
SCIC
Vehicle:'02 WRX; '08 OBXT; '08 G37 (S/C'd); '09 XF |
05's sit a litle higher in the rear. might suit the wagon better. however spring rates are up all around, for the 05 spec, so you might want to consider that as well. |
Request: 06-07s on Tanabe GF210s | Subydude81 | Member's Car Gallery | 11 | 05-19-2007 02:47 PM |
04 sti struts/tanabe gf210 springs combo on 05' WRX? | spooln407 | Brakes, Steering & Suspension | 9 | 07-18-2006 07:46 PM |
06 WRX lowered on Tanabe GF210s | ommmjido | Member's Car Gallery | 29 | 04-15-2006 10:39 PM |
Info Needed on Tanabe GF210 Springs | 1331 | Brakes, Steering & Suspension | 39 | 08-19-2005 11:17 PM |
NEED a PIC of WRX on tanabe GF210 | impr25rs | Member's Car Gallery | 11 | 07-10-2005 04:57 AM |
