01-24-2005, 02:32 PM | #1 |
Member#: 38419
Vehicle:2002 WRX Red |
airbag light is on and no cruise control
A couple weeks ago my airbag light came on, 02 wrx, but when I shut the car off it went away. My cruise control also stopped working, but worked later that day. Yesterday it did it again, but now the airbag light is permanently on, and cruise is not working.
The car was in an accident, but the bags werent popped. I'm thinking clock spring. The horn still works. Is there any way to scan the airbag light? A regular scanner shows no codes. thanks Eric
01-24-2005, 06:34 PM | #2 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
Good bet on the clock spring.
Jay |
01-24-2005, 10:01 PM | #3 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
The airbag codes won't show up in the engine ECU. There is a procedure in the service manual to read out the codes by counting flashes of the airbag light while in a diagnostic mode.
01-24-2005, 10:26 PM | #4 |
Member#: 42270
South East
Vehicle:2003 A&P IA ww.flyingleafaviation.com |
I've done that procedure after installing my seats (airbag delete), It's an easy function to perform, there is a 3 wire harness behind the fuse box, 1 plug and 2 pins. You insert the pins as specified in the manual, and the airbag light will blink the code (also found in the manual). You then can reset the light. If I could post it for you, I would. Get the manuals if you don't have them, worth their cost, for just such an occasion
Similar Threads | ||||
Check engine light, VDC light is on, and cruise control light is flashing | grimace09 | Normally Aspirated Powertrain | 7 | 08-09-2012 03:42 PM |
Check engine light, VDC light is on, and cruise control and sport light is flashing | Legacymun2k6 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 01-30-2010 12:47 PM |
Airbag light is on, aftermarket seats, 4 airbag cords? | subierider | Interior & Exterior Modification | 7 | 10-26-2008 05:00 PM |
CEL and No Cruise Control? | Bearkat | Service & Maintenance | 7 | 04-04-2006 02:05 PM |
No horn, Cruise control's bad and my Airbag light is on? | Paxtonb | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 14 | 07-04-2004 12:22 PM |
