10-25-2010, 02:46 PM | #1 |
Member#: 252663
HIIC
Vehicle:2002 WRX Silver |
Oil cooler (Need some advice)
So im kinda stuck in a corner here, im very limited on funds and the amount that i want to spend. Im looking right around the area of $200 all said an done. The cars gonna see the track so the factory one isnt going to do it and is gonna be deleted.
Im looking at a B&M 20,000 BTU stacked plate cooler, Jegs Flex 200 Hoses, and Jegs -10 AN (5/8's) fittings. Im stuck at a Sandwich plate though, I want one thats thermostatic. But all the ones that are realisticly priced have 3/8 NPT fittings (-6 AN basicly) Which IMO will cause alot of pressure drop and hurt my oil pressure. All the sandwich plates with the fitting sizes i want are non thermostatic, which wouldnt be a big deal but it does get pretty cold here in the winter. The only one i found that was thermostatic is the Greddy, buts its $120 by it self...
10-25-2010, 04:22 PM | #2 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
What part number are you looking at for Greddy? Maybe I'm just not looking in the right place, but I'm not finding a thermostatic sandwich adapter from them.
Mocal makes one that is right around $100. However, that doesn't include the fittings, so it's probably about $120 once you add the BSP-to-AN fittings and Dowty seals. Looks like Racer Parts Wholesale's price is about $10 better than BAT, inc. |
10-25-2010, 06:29 PM | #3 | |
Member#: 252663
HIIC
Idealy i would just do a seperate oil thermostat. The thing is though there $~60 without fittings. So add 8 fittings onto that and your looking at an extra $70 in fittings on top of what i already have... Edit: if you google search Greddy Thermostatic Sandwich you should get a link to it, its ~$120 but has -10 fittings Edit #2: http://www.240sxmotoring.com/groilcoadw.html |
10-25-2010, 08:52 PM | #4 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
This is the question I ask all my cutomers that tell me they want to know what oil cooler to use. Do you know you need one? Most really don't know. Without knowing for certain you may be spending money that could otherwise be spent on something more useful.
If you must have one, you're going the right route with a themostatically contolled piece. $200 is a stretch and lines/fittings are not piece I'd cheap out on. |
10-25-2010, 09:06 PM | #5 |
Member#: 23553
Vehicle:2005 STI - Insanity! 2014 WRX - Daily |
Call BAT Inc. and they will fix you right up. I have a Mocal sandwich adapter with -10 fittings on it and it works perfectly. Check out this thread for details on my oil cooler setup. KillerB is correct though, this is NOT something that you want to go cheap on. Cheap oil cooler cores cause HUGE pressure drops resulting it dangerously low oil pressure. I dont have exact numbers but if I recall correctly, my oil cooler setup was $700-800 after all was said and done. You are on the right track with the -10 lines through. I tried -8 and it didn't work well at all. My final setup is absolutely perfect though.
10-26-2010, 02:23 AM | #6 | |
Member#: 252663
HIIC
As for needing one, i personally believe any wrx with 350+ whp is going to need an aftermarket oil cooler at some point. Mine might not see the track for a little while, but since my factory cooler is now a paper weight because of 2 bad rod bearings. Id rather invest in proper cooling for the future than another $300 factory POS. |
Similar Threads | ||||
Mazda rx7 12A stuff, header, ignition, oil cooler, plus some Subaru stuff | Bonjo2 | NESIC Private Classifieds | 4 | 09-11-2006 11:22 AM |
About to get Subydude oil cooler. need some info. what to do in winter? | vipernj | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 12 | 08-19-2006 11:13 PM |
Civic Motor Swap (i need some advice) | DanMan | Southern California Impreza Club Forum -- SCIC | 46 | 08-05-2003 02:31 PM |
oil cooler needed? | efoo | Technical Forum Archive | 12 | 07-26-2000 06:25 AM |
Installing an oil cooler - need advice | josh | Technical Forum Archive | 0 | 06-14-2000 11:56 AM |
