05-18-2003, 10:47 AM | #1 |
Member#: 14115
Vehicle:2003 Impreza WRX WR Pearl Blue |
URGENT: Electrical Issues Need Help!
Dear Subie Pals:
I urgently need some assistance with the following problem: I have a 2003 WRX Turbo Sedan, and my Morrette low beam head lights (not HID) are not coming on. I have checked the following: High beam, parking light, brake lights, fog lights, dome light, stereo, fans, AC, and turn signals all function fine. Fuses for lights appear to be ok. Could not check relay as I do not have a spare. Bulbs on lights appear to be OK, tungston intact, no obvious discoloration from blown bulb. Checked head light wiring harness underhood, no obvious signs of wear or loose connections. What further problem determination steps can I perform? Could there be a problem with the Morette headlight wiring harness? How could I verify that? Where can I probe with a Volt Ohm meter to check? Anyone else with a similar experience, how did they resolve the issue? Thanks in advance for any assistance! Regards, mRgUnN
05-18-2003, 11:47 AM | #2 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
One quick question - were they working, and they they stopped, or did you just install them and they ceased functioning? If it's the latter, there have been a number of posts about "plug-n-play" harnesses which weren't wired correctly...
05-18-2003, 02:24 PM | #3 |
Member#: 14115
Were Working
Dear Subie Pals:
The Morette headlights were functioning fine for the last 10 months. Regards, mRgUnN |
05-18-2003, 05:32 PM | #4 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
Try unplugging all the connectors and bulbs, looking for corrosion and/or burnt contacts. Check all bulbs/fuses with a meter, I have seen both bulbs and fuses which appeared intact but were in fact blown. Try tapping the relay, gently, with a screwdriver handle or some such object. Look for a burnt/broken/frayed wire.
05-18-2003, 09:36 PM | #5 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
In the Morettes the highs are powered directly from the battery so if you have a power problem that would explain why the highs work but not the lows. However, there is an independent fuse and relay for the headlight power on each side so it is unlikely that they are both blown at the same time.
Definitely check the bulbs with an ohmeter as suggested, they could very possibly be bad and look ok to the eye. If the bulbs check out use a meter or test light to verify whether or not you are getting power and ground to the lights and if not to trace the cause. |
05-19-2003, 10:27 AM | #6 |
Member#: 14115
FYI Parking Lights Function
Dear Subie Pals;;
FYI the Daytime running lights are working fine. I am told they are on the same circut. I will test and report back. Regards, mRgUnN |
05-19-2003, 01:59 PM | #7 |
Member#: 14115
DOHH!!! Problem Found L"User" Error
Dear Subie Pals:
I found the problem, l"user" error, . It appears my initial Problem Determination was flawed. I did not checked the thick outer set of bulbs, I simply assumed they were the HBs. Today I came home for lunch and decided that I should retrace all of my PD steps again. I again visually inspected all of the fuses, verified all cables were seated properly. Then I retested the lights, it was at this time I noticed I had examined the wrong set of bulbs on my previous PD attempt. So this time I actually removed the bulbs and checked them visually. DOOHHH!!!! Sure enough both blubs are blown. So now I know all I need is 2 new low beam replacement bulbs. Now I am wondering.... why would both bulbs burn out at the same time, this seems odd to me. Any way I learned somethings from my pals on the forum, and will be more diligent next time. Many thanks to everyone who assisted. Regards, mRgUnN |
05-19-2003, 09:33 PM | #8 |
Trust no one
If your low beams were burned out there is no way the DRLs could have been working since they operate the low beams at reduced brightness. Are you perhaps referring to the small "city lights" which are located in the high beam housing on the Morettes and come on with the parking lights?
05-20-2003, 04:31 AM | #9 | |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! White |
MAJOR electrical issue!!! please help... stranged | NNJ_wrx | Newbies & FAQs | 30 | 06-09-2009 04:01 PM |
strange electrical issue, need diagnosis | Squeakywaffle | Newbies & FAQs | 9 | 04-30-2007 10:04 AM |
electrical issues, please help. | buzzword | Service & Maintenance | 6 | 09-14-2006 09:29 PM |
Electrical Issues/Need to Borrow | Pat Green | North West Impreza Club Forum -- NWIC | 7 | 08-22-2006 02:29 AM |
URGENT: Electrical Issues Need Help | mRgUnN | South East Region Forum | 5 | 05-19-2003 01:56 PM |
