08-13-2004, 03:07 PM | #1 |
Member#: 57449
Vehicle:07 Legacy spec B |
turboxs up-pipe vs. Perrin up-pipe?
08-13-2004, 03:10 PM | #2 |
Member#: 39149
Same thing basically. perrin's is shiny. I personally have the turbo xs and have not had a single problem with it. Just a matter of what you want.
08-13-2004, 03:12 PM | #3 |
Member#: 23934
here....check this thread.
http://forums.nasioc.com/forums/showthread.php?t=606627 and while you're at it, look up unabomber's thread on uppipes. |
08-13-2004, 06:58 PM | #4 |
Member#: 39462
Vehicle:04 STi Type R Spec Broken Wallet |
6 or one half dozen of the other. I'll take the half dozen.
I have the Perrin *sticks tongue out* Its blang blang shiny polished. No problems with it. All it needs to do is fit and not leak. PipesaPipesaPipe |
08-13-2004, 07:05 PM | #5 | |
Member#: 9749
SWIC
Vehicle:- |
Also coastal dyno makes some custom uppipes, he focus's on the diameter of the pipe, and suposedly it nets some pretty sick tq gains combined with a port matched stock manifold.. |
08-14-2004, 10:01 AM | #6 |
Member#: 9041
Vehicle:2002 WRX blaze yellow 1-450 |
go sti uppipe its got the flex joint and fits like stock and no dreaded egt sensor put in the 10 cent resistor and ur gold no leaks and high flow nekard on this site has em 250 hpc coated shipped with the resistor. NO ONE has leaks with this piece. fool the dealers thinking its stock as well.
Scott |
09 WRX: Cobb vs. Perrin down pipe | Liquidr1 | Newbies & FAQs | 27 | 02-28-2010 01:09 AM |
gutted stock up-pipe VS sti up-pipe | mhorn0817 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 08-01-2009 10:42 AM |
small up-pipe vs larger up-pipe | OvrClkdPmp | Newbies & FAQs | 5 | 07-13-2006 02:42 AM |
STI up pipe vs. aftermarket up pipe | bluimpreza00 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 36 | 05-20-2005 09:03 AM |
solid up-pipe vs. flex up-pipe | r_master | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 07-25-2002 03:20 AM |
